TSM280NB06LCR RLG
TSM280NB06LCR RLG
    TAIWANSEMICONDUCTOR(台湾半导体)
    TDFN-8
TSM280NB06LCR RLG 数据手册
TSM280NB06LCR Taiwan Semiconductor N-Channel Power MOSFET 60V, 28A, 28mΩ FEATURES KEY PERFORMANCE PARAMETERS ● Low RDS(ON) to minimize conductive losses PARAMETER VALUE UNIT VDS 60 V ● Logic level ● Low gate charge for fast power switching ● 100% UIS and Rg tested. RDS(on) (max) ● 175°C Operating Junction Temperature ● Compliant to RoHS directive 2011/65/EU and in accordance to WEEE 2002/96/EC ● Halogen-free according to IEC 61249-2-21 VGS = 10V 28 VGS = 4.5V 39 mΩ Qg 9 nC APPLICATIONS ● ● ● ● BLDC Motor Control Battery Power Management DC-DC converter Secondary Synchronous Rectification PDFN56 Note: MSL 1 (Moisture Sensitivity Level) per J-STD-020 ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER SYMBOL LIMIT UNIT Drain-Source Voltage VDS 60 V Gate-Source Voltage VGS ±20 V Continuous Drain Current TC = 25°C (Note 1) ID TA = 25°C Pulsed Drain Current (Note 2) Single Pulse Avalanche Current (Note 2) Single Pulse Avalanche Energy Total Power Dissipation Total Power Dissipation TC = 25°C TC = 125°C TA = 25°C TA = 125°C Operating Junction and Storage Temperature Range 28 7 A IDM 112 A IAS EAS 12 22 A mJ PD PD 56 19 3.1 1 W W TJ, TSTG - 55 to +175 °C SYMBOL LIMIT UNIT Junction to Case Thermal Resistance RӨJC 2.7 °C/W Junction to Ambient Thermal Resistance RӨJA 48 °C/W THERMAL PERFORMANCE PARAMETER Thermal Performance Note: RӨJA is the sum of the junction-to-case and case-to-ambient thermal resistances. The casethermal reference is defined at the solder mounting surface of the drain pins. R ӨJA is guaranteed by design while RӨCA is 2 determined by the user’s board design. The RӨJA limit presented here is based on mounting on a 1 in pad of 2 oz copper. 1 Version: B1804 TSM280NB06LCR Taiwan Semiconductor ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER CONDITIONS SYMBOL MIN TYP MAX UNIT Static Drain-Source Breakdown Voltage VGS = 0V, ID = 250µA BVDSS 60 -- -- V Gate Threshold Voltage VGS = VDS, ID = 250µA VGS(TH) 1 2 2.5 V Gate-Source Leakage Current VGS = ±20V, VDS = 0V IGSS -- -- ±100 nA -- -- 1 -- -- 100 -- 24 28 -- 32 39 gfs -- 31 -- Qg -- 18 -- Qg -- 9 -- Qgs -- 3 -- Qgd -- 4 -- Ciss -- 969 -- Coss -- 71 -- Crss -- 24 -- Rg 0.7 2.4 4.8 td(on) -- 1 -- tr -- 19 -- td(off) -- 10 -- tf -- 18 -- VSD -- -- 1.2 V VGS = 0V, VDS = 60V Drain-Source Leakage Current IDSS VGS = 0V, VDS = 60V TJ = 125°C Drain-Source On-State Resistance (Note 3) VGS = 10V, ID = 7A RDS(on) VGS = 4.5V, ID = 6A Forward Transconductance Dynamic (Note 3) VDS = 10V, ID = 7A µA mΩ S (Note 4) VGS = 10V, VDS = 30V, Total Gate Charge ID = 7A Total Gate Charge VGS = 4.5V, VDS = 30V, Gate-Source Charge ID = 6A Gate-Drain Charge Input Capacitance VGS = 0V, VDS = 30V Output Capacitance f = 1.0MHz Reverse Transfer Capacitance Gate Resistance Switching f = 1.0MHz nC pF Ω (Note 4) Turn-On Delay Time Turn-On Rise Time VGS = 10V, VDS = 30V, Turn-Off Delay Time ID = 7A, RG = 2Ω Turn-Off Fall Time ns Source-Drain Diode Forward Voltage (Note 3) VGS = 0V, IS = 7A Reverse Recovery Time IS = 7A , trr -- 11 -- ns Reverse Recovery Charge dI/dt = 100A/μs Qrr -- 5 -- nC Notes: 1. 2. 3. 4. Silicon limited current only. L = 0.3mH, VGS = 10V, VDD = 30V, RG = 25Ω, IAS = 12A, Starting TJ = 25°C Pulse test: Pulse Width ≤ 300µs, duty cycle ≤ 2%. Switching time is essentially independent of operating temperature. ORDERING INFORMATION PART NO. PACKAGE PACKING TSM280NB06LCR RLG PDFN56 2,500pcs / 13” Reel 2 Version: B1804 TSM280NB06LCR Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Output Characteristics Transfer Characteristics 25 25 ID, Drain Current (A) 20 15 ID, Drain Current (A) VGS=10V VGS=7V VGS=5V VGS=4.5V VGS=4V VGS=3.5V 10 VGS=3V 5 20 15 25℃ 10 -55℃ 5 175℃ 0 0 0 1 2 3 4 0 5 On-Resistance vs. Drain Current 0.04 VGS=4.5V 0.03 VGS=10V 0.02 0.01 4 5 0 0 5 10 15 20 VDS=30V ID=7A 8 6 4 2 0 25 0 5 VGS=10V ID=7A 2 1.5 1 0.5 0 -75 -50 -25 0 25 50 75 100 125 150 175 15 20 On-Resistance vs. Gate-Source Voltage RDS(on), Drain-Source On-Resistance (Ω) On-Resistance vs. Junction Temperature 3 10 Qg, Gate Charge (nC) ID, Drain Current (A) RDS(on), Drain-Source On-Resistance (Normalized) 3 10 0.05 2.5 2 Gate-Source Voltage vs. Gate Charge 0.06 VGS, Gate to Source Voltage (V) R DS(on), Drain-Source On-Resistance (Ω) 1 VGS, Gate to Source Voltage (V) VDS, Drain to Source Voltage (V) TJ, Junction Temperature (°C) 0.1 0.08 0.06 0.04 0.02 ID=7A 0 3 4 5 6 7 8 9 10 VGS, Gate to Source Voltage (V) 3 Version: B1804 TSM280NB06LCR Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) BVDSS vs. Junction Temperature Capacitance vs. Drain-Source Voltage C, Capacitance (pF) 1200 CISS 1000 800 600 400 1.2 BVDSS (Normalized) Drain-Source Breakdown Voltage 1400 CRSS 200 COSS ID=5mA 1.1 1 0.9 0.8 0 0 10 20 30 40 50 -75 -50 -25 60 VDS, Drain to Source Voltage (V) 25 50 75 100 125 150 175 TJ, Junction Temperature (°C) Maximum Safe Operating Area, Junction-to-Case Source-Drain Diode Forward Current vs. Voltage 100 100 IS, Reverse Drain Current (A) 1000 RDS(ON) 10 1 SINGLE PULSE RӨJC=2.7°C/W TC=25°C 0.1 10 175℃ 1 25℃ -55℃ 0.1 0.1 1 10 100 0.2 VDS, Drain to Source Voltage (V) 0.4 0.6 0.8 1 1.2 VSD, Body Diode Forward Voltage (V) Normalized Thermal Transient Impedance, Junction-to-Case 10 Normalized Effective Transient Thermal Impedance, ZӨJC ID, Drain Current (A) 0 SINGLE PULSE RӨJC=2.7°C/W 1 Duty=0.5 Duty=0.2 Duty=0.1 Duty=0.05 Duty=0.02 Duty=0.01 Single 0.1 0.01 0.0001 0.001 Notes: Duty = t1 / t2 TJ = TC + PDM x ZӨJC x RӨJC 0.01 0.1 t, Square Wave Pulse Duration (sec) 4 Version: B1804 TSM280NB06LCR Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS (Unit: Millimeters) PDFN56 SUGGESTED PAD LAYOUT (Unit: Millimeters) MARKING DIAGRAM TSC 280NB06L GYWWF G Y WW F 5 TSC 280NB06L GYWWF = Halogen Free = Year Code = Week Code (01~52) = Factory Code Version: B1804 TSM280NB06LCR Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 6 Version: B1804
TSM280NB06LCR RLG 价格&库存
很抱歉,暂时无法提供与“TSM280NB06LCR RLG”相匹配的价格&库存,您可以联系我们找货
TSM280NB06LCR RLG
  • 1+10.073711+1.29207
  • 10+6.2899310+0.80675
  • 100+4.12734100+0.52938
  • 500+3.19778500+0.41015
  • 1000+2.898391000+0.37175
库存:6214
TSM280NB06LCR RLG
  • 1+1.96539
  • 200+0.76065
  • 500+0.73386
  • 1000+0.72069
TSM280NB06LCR RLG
  • 2500+2.574192500+0.33017
  • 5000+2.373775000+0.30446
  • 7500+2.271687500+0.29137
  • 12500+2.1570012500+0.27666
  • 17500+2.1179817500+0.27166
库存:6214
TSM280NB06LCR RLG
    库存:5000
