TSM126CX RFG
TSM126CX RFG
    TAIWANSEMICONDUCTOR(台湾半导体)
    SOT-23
TSM126CX RFG 数据手册
TSM126 N-Channel Depletion-Mode MOSFET SOT-23 PRODUCT SUMMARY VDS (V) RDS(on)(Ω)(max) Pin Definition: 1. Gate 2. Source 3. Drain 600 700 @ VGS = 0V Features ID (A) 0.03 Block Diagram ● Depletion Mode ● Low Gate Charge ● Converters ● Telecom en de d Application Ordering Information Part No. Package Packing SOT-23 3kpcs / 7” Reel TSM126CX RFG N-Channel MOSFET mm Note: “G” denotes Halogen Free Product. Absolute Maximum Ratings (Ta = 25oC unless otherwise noted) Parameter eco Drain-Source Voltage Gate-Source Voltage Continuous Drain Current Tc=25℃ Continuous Drain Current Tc=70℃ a tR Pulsed Drain Current Maximum Power Dissipation Soldering Temperature b No Operating Junction Temperature Operating Junction and Storage Temperature Range Symbol Limit Unit VDS 600 V VGS ±20 V 0.030 A 0.024 A IDM 0.120 A PD 0.5 W TL 300 o C TJ +150 o C TJ, TSTG -55 to +150 o C Symbol Limit ID Thermal Performance Parameter Thermal Resistance, Junction to Ambient RӨJA 250 Unit o C/W Notes: a. Pulse width limited by the Maximum junction temperature b. Distance of 1.6mm from case for 10 seconds. 1/7 Version: A14 TSM126 N-Channel Depletion-Mode MOSFET Electrical Specifications (Tj = 25oC unless otherwise noted) Parameter Static Conditions Symbol Min Typ Max Unit a Drain-Source Breakdown Voltage VGS = -5V, ID = 250µA BVDSS 600 -- -- V Gate Threshold Voltage VDS = 3V, ID = 8µA VGS(TH) -2.7 -1.8 -1.0 V -- -- 0.1 µA 10 µA Drain-Source cutoff current VDS = 600V, VGS = -5V, Ta = 25℃ VDS = 480V, VGS = -5V, IDS(OFF) Ta = 125℃ VGS = ±20V, VDS = 0V IGSS On-state Drain Current VDS = 25V, VGS = 0V IDSS Forward Transconductance VGS = 0V, ID = 3mA VGS = 10V, ID = 16mA | VDS | >2 ID*RDS(ON)max, ID = 0.01A Input Capacitance VDS = 25V, VGS = -5V, Output Capacitance Reverse Transfer Capacitance Total Gate Charge Switching Turn-On Delay Time Turn-On Rise Time VDD = 300V, ID = 0.01A, VGS = -5V to 7V, tR Turn-Off Delay Time VGS = -5V to 5V e co Gate-Drain Charge f = 1.0MHz VDS = 400V, ID = 0.01A, Gate-Source Charge Turn-Off Fall Time RDS(ON) ±10 µA 12 -- -- mA -- 350 700 Ω 400 800 Ω S gfs 0.008 0.017 -- Ciss -- 51.42 -- Coss -- 4.48 -- Crss -- 1.12 -- Qg -- 1.18 -- Qgs -- 0.49 -- Qgd -- 0.365 -- td(on) -- 10.01 -- tr -- 55.7 -- td(off) -- 57.2 -- tf -- 135.5 -- IS -- -- 0.025 A ISM -- -- 0.100 A VSD -- -- 1.2 V trr -- 243.1 -- ns Qrr -- 639 -- nC mm Dynamic -- en Drain-Source On-State Resistance -- de Gate-Source Leakage Current d Drain-Source cutoff current RG = 6Ω pF nC ns Source-Drain Diode No Diode forward Current Continuous Diode Pulse Current Diode Forward Voltage ISD = 16mA, VGS = -5V Reverse Recovery Time IF=0.01A, VGS=-10V dIF/dt=100A/µs, VR=30V Reverse Recovery Charge Notes: a. pulse test: PW ≤380µs, duty cycle ≤2% 2/7 Version: A14 TSM126 N-Channel Depletion-Mode MOSFET Electrical Characteristics Curves (Ta = 25oC, unless otherwise noted) Maximum Power Dissipation vs. Case Temperature Maximum Continuous Drain Current vs. Typical Output Characteristics tR e co mm Case Temperature en de d Maximum Forward Bias Safe Operation Area Drain to Source ON Resistance No Typical Transfer Characteristics vs. Junction Temperature 3/7 Version: A14 TSM126 N-Channel Depletion-Mode MOSFET Electrical Characteristics Curves (Ta = 25oC, unless otherwise noted) Breakdown Voltage vs. Junction Temperature Typical Gate Charge vs. Gate to Source Voltage tR e co mm Typical Capacitance vs. Drain to source Voltage en de d Threshold Voltage vs. Junction Temperature No Typical Body Diode Transfer Characteristics 4/7 Version: A14 TSM126 N-Channel Depletion-Mode MOSFET Electrical Characteristics Curves (Ta = 25oC, unless otherwise noted) No tR e co mm en de d Maximum Peak Current Capability 5/7 Version: A14 TSM126 N-Channel Depletion-Mode MOSFET Unit: Millimeters No tR e co mm en de d SOT-23 Mechanical Drawing 6/7 Version: A14 TSM126 No tR e co mm en de d N-Channel Depletion-Mode MOSFET Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 7/7 Version: A14
TSM126CX RFG 价格&库存
很抱歉,暂时无法提供与“TSM126CX RFG”相匹配的价格&库存,您可以联系我们找货
TSM126CX RFG
  • 3+2.355353+0.30510
  • 25+1.7098125+0.22148
  • 100+1.36087100+0.17628
  • 500+1.22130500+0.15820
  • 3000+1.142783000+0.14803
TSM126CX RFG
  • 3+2.19078
  • 25+1.58948
  • 100+1.26607
  • 500+1.13671
  • 3000+1.06245
