TSM85N10CZ C0G
TSM85N10CZ C0G
    TAIWANSEMICONDUCTOR(台湾半导体)
    TO-220-3
    N沟道,电流:81A,耐压:100V
TSM85N10CZ C0G 数据手册
TSM85N10 Taiwan Semiconductor N-Channel Power MOSFET 100V, 81A, 10mΩ FEATURES KEY PERFORMANCE PARAMETERS ● Advanced Trench Technology ● 100% avalanche tested ● Synchronous Rectification in SMPS ● High Speed Power Switching VALUE UNIT VDS 100 V RDS(on) (max) 10 mΩ Qg 154 nC en de d APPLICATION PARAMETER mm TO-220 ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER Limit UNIT VDS 100 V VGS ±25 V eco Drain-Source Voltage SYMBOL Gate-Source Voltage 81 TC = 70°C 65 TA = 25°C tR Continuous Drain Current (Note 1) TC = 25°C ID TA = 70°C (Note 2) No Pulsed Drain Current Total Power Dissipation 8.7 7 IDM 320 TC = 25°C 210 TC = 70°C 130 TA = 25°C PDTOT TA = 70°C 2.4 1.5 A A A W W Single Pulsed Avalanche Energy (Note 3) EAS, EAR 620 mJ Single Pulsed Avalanche Current (Note 3) IAS, IAR 64 A TJ, TSTG - 55 to +150 °C SYMBOL Limit UNIT Junction to Case Thermal Resistance RӨJC 0.6 °C/W Junction to Ambient Thermal Resistance RӨJA 52.5 °C/W Operating Junction and Storage Temperature Range THERMAL PERFORMANCE PARAMETER Notes: RӨJA is the sum of the junction-to-case and case-to-ambient thermal resistances. The case thermal reference is defined at the solder mounting surface of the drain pins. RӨJA is guaranteed by design while RӨCA is determined by the user’s board design. RӨJA shown below for single device operation on FR-4 PCB in still air. Document Number: DS_P0000148 1 Version: B15 TSM85N10 Taiwan Semiconductor ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER Static CONDITIONS SYMBOL MIN TYP MAX UNIT (Note 4) Drain-Source Breakdown Voltage VGS = 0V, ID = 250µA BVDSS 100 -- -- V Gate Threshold Voltage VDS = VGS, ID = 250µA VGS(TH) 2 3 4 V Gate Body Leakage VGS = ±20V, VDS = 0V IGSS -- -- ±100 nA Zero Gate Voltage Drain Current VDS = 80V, VGS = 0V IDSS -- -- 1 µA Drain-Source On-State Resistance VGS = 10V, ID = 40A RDS(ON) -- 9 10 mΩ Qg VDS = 30V, ID = 40A, Gate-Source Charge -- Qgd -- 45 -- Ciss -- 3900 -- Coss -- 300 -- Crss -- 170 -- Rg -- 1.2 -- Switching td(on) -- 38 -- tr -- 65 -- td(off) -- 218 -- tf -- 72 -- VSD -- 0.8 1.2 V IS = 40A , TJ = 25 C trr -- 62 -- ns dIF/dt = 100A/µs Qrr -- 130 -- nC F = 1MHz, open drain (Note 6) Turn-On Delay Time VDS = 30V, Turn-On Rise Time RGEN = 6Ω, Turn-Off Delay Time e co ID = 1A, VGS = 10V Turn-Off Fall Time Source-Drain Diode IS = 20A, VGS = 0V tR Reverse Recovery Time Reverse Recovery Charge pF Ω ns o Current limited by package No 1. nC (Note 4) Forward Voltage Notes: en f = 1.0MHz mm Gate Resistance -- 4 VDS = 30V, VGS = 0V, Reverse Transfer Capacitance 154 -- Input Capacitance Output Capacitance -- Qgs VGS = 10V Gate-Drain Charge d Total Gate Charge de Dynamic (Note 5) 2. Pulse width limited by the maximum junction temperature 3. L = 0.3mH, IAS = 64A, VDD = 50V, RG = 25Ω, Starting TJ = 25 C 4. Pulse test: PW ≤ 300µs, duty cycle ≤ 2% 5. For DESIGN AID ONLY, not subject to production testing. 6. Switching time is essentially independent of operating temperature. Document Number: DS_P0000148 o 2 Version: B15 TSM85N10 Taiwan Semiconductor ORDERING INFORMATION PART NO. PACKAGE PACKING TO-220 50pcs / Tube TSM85N10CZ C0G No tR e co mm en de d Note: 1. Compliant to RoHS Directive 2011/65/EU and in accordance to WEEE 2002/96/EC 2. Halogen-free according to IEC 61249-2-21 definition Document Number: DS_P0000148 3 Version: B15 TSM85N10 Taiwan Semiconductor CHARACTERISTICS CURVES (TC = 25°C unless otherwise noted) Transfer Characteristics en de d Output Characteristics Gate Charge tR e co mm On-Resistance vs. Gate-Source Voltage Capacitance No On-Resistance vs. Junction Temperature Document Number: DS_P0000148 4 Version: B15 TSM85N10 Taiwan Semiconductor CHARACTERISTICS CURVES (TC = 25°C unless otherwise noted) Normalized Thermal Transient Impedance mm en de d Threshold Voltage vs. Temperature No tR e co Maximum Safe Operating Area Document Number: DS_P0000148 5 Version: B15 TSM85N10 Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS (Unit: Millimeters) en de d TO-220 MARKING DIAGRAM No tR e co mm Y = Year Code M = Month Code for Halogen Free Product O =Jan P =Feb Q =Mar R =Apr V =Aug S =May T =Jun U =Jul W =Sep X =Oct Y =Nov Z =Dec L = Lot Code (1~9, A~Z) Document Number: DS_P0000148 6 Version: B15 TSM85N10 No tR e co mm en de d Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. Document Number: DS_P0000148 7 Version: B15
TSM85N10CZ C0G 价格&库存
很抱歉,暂时无法提供与“TSM85N10CZ C0G”相匹配的价格&库存,您可以联系我们找货
