TSM70N10CP ROG
TSM70N10CP ROG
    TAIWANSEMICONDUCTOR(台湾半导体)
    TO-252(DPAK)
    TSM70N10CP ROG
TSM70N10CP ROG 数据手册
TSM70N10 Taiwan Semiconductor N-Channel Power MOSFET 100V, 70A, 13mΩ FEATURES KEY PERFORMANCE PARAMETERS ● Low RDS(ON) to minimize conductive loss ● ● Low gate charge for fast power switching Compliant to RoHS directive 2011/65/EU and in accordance to WEEE 2002/96/EC Halogen-free according to IEC 61249-2-21 ● PARAMETER VALUE UNIT VDS 100 V RDS(on) (max) 13 mΩ Qg 145 nC ● Synchronous Rectifier in SMPS ● LED lighting application ● 48V Battery System TO-251S (IPAK SL) TO-252 (DPAK) mm TO-251 (IPAK) en de d APPLICATION Notes: MSL 3 (Moisture Sensitivity Level) per J-STD-020 eco ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER Drain-Source Voltage Gate-Source Voltage SYMBOL Limit UNIT VDS 100 V VGS ±20 V No tR TC = 25°C Continuous Drain Current (Note 3) TC = 70°C 70 ID TA = 25°C TA = 70°C Drain Current-Pulsed 61 12 A 9 (Note 1) IDM 150 A Avalanche Current, L=0.5mH IAS, IAR 25 A Avalanche Energy, L=0.5mH EAS, EAR 156 mJ TC = 25°C Maximum Power Dissipation (Note 2) 120 TC = 70°C ID TA = 25°C TA = 70°C 8.3 W 5.3 Storage Temperature Range Operating Junction Temperature Range Document Number: DS_P0000135 80 1 TSTG - 55 to +150 °C TJ - 55 to +150 °C Version: E15 TSM70N10 Taiwan Semiconductor THERMAL PERFORMANCE PARAMETER SYMBOL Limit UNIT Thermal Resistance – Junction to Case RӨJC 1 °C/W Thermal Resistance – Junction to Ambient RӨJA 40 °C/W ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER CONDITIONS SYMBOL MIN TYP MAX UNIT 100 -- -- V -- 10 13 mΩ Static VGS = 0V, ID = 250µA BVDSS Drain-Source On-State Resistance VGS = 10V, ID = 30A RDS(ON) Gate Threshold Voltage VDS = VGS, ID = 250µA VGS(TH) 2 3 4 V Zero Gate Voltage Drain Current VDS = 80V, VGS = 0V IDSS -- -- 1 µA Gate Body Leakage VGS = ±20V, VDS = 0V IGSS -- -- ±100 nA Qg -- 145 -- Qgs -- 25 -- Qgd -- 43 -- Ciss -- 4300 -- Coss -- 300 -- Crss -- 120 -- td(on) -- 27 -- tr -- 13 -- td(off) -- 15 -- tf -- 42 -- VGS = 0V, IS = 30A VSD -- 0.8 1.3 V Reverse Recovery Time IS = 30A, TJ = 25°C trr -- 165 -- ns Reverse Recovery Charge dIF/dt = 100A/μs Qrr -- 175 -- nC Total Gate Charge VGS = 10V Gate-Drain Charge Input Capacitance VDS = 30V, VGS = 0V, Output Capacitance VGS = 10V, VDS = 50V, RG = 3Ω, tR Turn-Off Delay Time f = 1.0MHz e co Reverse Transfer Capacitance Turn-On Rise Time mm VDS = 50V, ID = 30A, Gate-Source Charge Turn-On Delay Time de en Dynamic Switching d Drain-Source Breakdown Voltage Turn-Off Fall Time nC pF -- ns Source-Drain Diode No Forward On Voltage Notes: 1. Pulse Test: Pulse Width≦ 300μs, Duty Cycle≦2% 2. RθJA is the sum of the junction-to-case and case-to-ambient thermal resistances. The case thermal reference is defined at the solder mounting surface of the drain pins. RθJA is guaranteed by design while RθCA is determined by the user’s board design. RθJA shown below for single device operation on FR-4PCB in still air. 3. The maximum current is limited by package. Document Number: DS_P0000135 2 Version: E15 TSM70N10 Taiwan Semiconductor ORDERING INFORMATION PACKAGE PACKING TO-252 (DPAK) 2,500pcs / 13” Reel TSM70N10CH C5G TO-251 (IPAK) 75pcs / Tube TSM70N10CH X0G TO-251S (IPAK SL) 75pcs / Tube No tR e co mm en de d PART NO. TSM70N10CP ROG Document Number: DS_P0000135 3 Version: E15 TSM70N10 Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Transfer Characteristics en de d Output Characteristics Gate Charge No tR e co mm On-Resistance vs. Gate-Source Voltage On-Resistance vs. Junction Temperature Document Number: DS_P0000135 Capacitance 4 Version: E15 TSM70N10 Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Maximum Safe Operating Area Threshold Voltage vs. Temperature mm en de d IDS=250µA No tR e co Normalized Thermal Transient Impedance, Junction-to-Ambient Document Number: DS_P0000135 5 Version: E15 TSM70N10 Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS (Unit: Millimeters) tR e co mm SUGGESTED PAD LAYOUT (Unit: Millimeters) en de d TO-252 MARKING DIAGRAM No Y = Year Code M = Month Code for Halogen Free Product O =Jan P =Feb Q =Mar R =Apr S =May T =Jun U =Jul V =Aug W =Sep X =Oct Y =Nov Z =Dec L = Lot Code (1~9, A~Z) Document Number: DS_P0000135 6 Version: E15 TSM70N10 Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS (Unit: Millimeters) en de d TO-251 mm MARKING DIAGRAM No tR e co Y = Year Code M = Month Code for Halogen Free Product O =Jan P =Feb Q =Mar R =Apr S =May T =Jun U =Jul V =Aug W =Sep X =Oct Y =Nov Z =Dec L = Lot Code (1~9, A~Z) Document Number: DS_P0000135 7 Version: E15 TSM70N10 Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS (Unit: Millimeters) en de d TO-251S mm MARKING DIAGRAM No tR e co Y = Year Code M = Month Code for Halogen Free Product O =Jan P =Feb Q =Mar R =Apr S =May T =Jun U =Jul V =Aug W =Sep X =Oct Y =Nov Z =Dec L = Lot Code (1~9, A~Z) Document Number: DS_P0000135 8 Version: E15 TSM70N10 No tR e co mm en de d Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. Document Number: DS_P0000135 9 Version: E15
TSM70N10CP ROG
1. 物料型号:型号为STM32F407IGTR,是ST公司的一款基于ARM Cortex-M4内核的高性能微控制器。
2. 器件简介:该微控制器内置1MB的Flash存储器和192KB的RAM,适用于需要高性能和外设集成的工业应用。
3. 引脚分配:共有216个引脚,包括电源引脚、地引脚、复位引脚、I/O引脚等,具体分配需参考数据手册。
4. 参数特性:主频为168MHz,工作电压为1.8V至3.6V,支持多种通信接口如USB、以太网等。
5. 功能详解:具备高级定时器、ADC、DAC、CAN、SDIO等多种功能模块,适用于复杂的控制任务。
6. 应用信息:广泛应用于工业控制、医疗设备、消费电子等领域。
7. 封装信息:采用LQFP封装,共有216个引脚,适用于表面贴装技术。
TSM70N10CP ROG 价格&库存
很抱歉,暂时无法提供与“TSM70N10CP ROG”相匹配的价格&库存,您可以联系我们找货
