BZT52C2V4-G - BZT52C43-G
Taiwan Semiconductor
Small Signal Product
5% Zener Voltage Tolerance Zener Diode
FEATURES
- Wide zener voltage range selection: 2.4V to 43V
- Surface Mount Device Type
- Moisture sensitivity level (MSL): 1
- Compliant to RoHS Directive 2011/65/EU and
in accordance to WEEE 2002/96/EC
- Halogen-free according to IEC 61249-2-21
SOD-123
MECHANICAL DATA
- Case: Bend lead SOD-123 small outline plastic package
- Terminal: Matte tin plated, lead free, solderable
per MIL-STD-202, Method 208 guaranteed
- High temperature soldering guaranteed: 260°C/10s
- Polarity: Indicated by cathode band
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS (TA=25°C unless otherwise noted)
PARAMETER
Forward Voltage (Note2)
@ IF = 10mA
Power Dissipation (Note1)
Thermal Resistance from Junction to Ambient
SYMBOL
VALUE
UNIT
VF
0.9
V
PD
350
mW
RθJA
357
°C/W
°C
Junction Temperature
TJ
150
Storage Temperature
TSTG
- 55 to +150
°C
2
Notes: 1. Device mounted on ceramic PCB: 7.6mm X 9.4mm X 0.87mm with pad areas 25mm
2. Short duration test pulse used to minimize self-heating effect
Version: B1601
(Ratings at TA=25°C ambient temperature unless otherwise specified)
Zener Voltage Range
Device
Type
Maximum Zener Impedance
Marking
code
VZ @ IZT
IZT
Nom(V) Min(V) Max(V)
mA
ZZT @ IZT
ZZk @ Izk
Ohm
Maximum
Reverse
Current
Typical
Temperature
Coefficient
@ IZTC
Test
Current
mV/°C
IZTC
IZT
IR
VR
mA
μA
V
Min
Max
mA
BZT52C2V4-G
WX
2.4
2.2
2.6
5
100
600
1.0
50
1.0
-3.5
BZT52C2V7-G
W1
2.7
2.5
2.9
5
100
600
1.0
-3.5
BZT52C3V0-G
W2
3.0
2.8
3.2
5
95
600
1.0
10
1.0
-3.5
BZT52C3V3-G
W3
3.3
3.1
3.5
5
95
600
1.0
5
1.0
-3.5
BZT52C3V6-G
W4
3.6
3.4
3.8
5
90
600
1.0
5
1.0
-3.5
BZT52C3V9-G
W5
3.9
3.7
4.1
5
90
600
1.0
3
1.0
-3.5
BZT52C4V3-G
W6
4.3
4
4.6
5
90
600
1.0
3
1.0
-3.5
BZT52C4V7-G
W7
4.7
4.4
5.0
5
80
500
1.0
3
2.0
-3.5
0.2
5
BZT52C5V1-G
W8
5.1
4.8
5.4
5
60
480
1.0
2
2.0
-2.7
1.2
5
BZT52C5V6-G
W9
5.6
5.2
6.0
5
40
400
1.0
1
2.0
-2.0
2.5
5
BZT52C6V2-G
WA
6.2
5.8
6.6
5
10
150
1.0
3
4.0
0.4
3.7
5
BZT52C6V8-G
WB
6.8
6.4
7.2
5
15
80
1.0
2
4.0
1.2
4.5
5
BZT52C7V5-G
WC
7.5
7.0
7.9
5
15
80
1.0
1
5.0
2.5
5.3
5
BZT52C8V2-G
WD
8.2
7.7
8.7
5
15
80
1.0
0.7
5.0
3.2
6.2
5
BZT52C9V1-G
WE
9.1
8.5
9.6
5
15
100
1.0
0.5
6.0
3.8
7.0
5
BZT52C10-G
WF
10
9.4
10.6
5
1.0
0.2
7.0
4.5
8.0
5
BZT52C11-G
WG
11
10.4
11.6
5
1.0
0.1
8.0
5.4
9.0
5
BZT52C12-G
WH
12
11.4
12.7
5
25
150
1.0
0.1
8.0
6.0
10.0
5
BZT52C13-G
WI
13
12.4
14.1
5
30
170
1.0
0.1
8.0
7.0
11.0
5
BZT52C15-G
WJ
15
13.8
15.6
5
30
200
1.0
0.1
10.5
9.2
13.0
5
BZT52C16-G
WK
16
15.3
17.1
5
40
200
1.0
0.1
11.2
10.4
14.0
5
BZT52C18-G
WL
18
16.8
19.1
5
45
225
1.0
0.1
12.6
12.4
16.0
5
BZT52C20-G
WM
21.2
5
55
225
1.0
0.1
14.0
14.4
18.0
5
BZT52C22-G
WN
22
20.8
23.3
5
55
250
1.0
0.1
15.4
16.4
20.0
5
BZT52C24-G
WO
24
22.8
25.6
5
70
250
1.0
0.1
16.8
18.4
22.0
5
BZT52C27-G
WP
27
25.1
28.9
2
80
300
0.5
0.1
18.9
21.4
25.3
2
BZT52C30-G
WQ
30
28.0
32.0
2
80
300
0.5
0.1
21.0
24.4
29.4
2
BZT52C33-G
WR
33
31.0
35.0
2
80
325
0.5
0.1
23.1
27.4
33.4
2
BZT52C36-G
WS
36
34.0
38.0
2
90
350
0.5
0.1
25.2
30.4
37.4
2
BZT52C39-G
WT
39
37.0
41.0
2
130
350
0.5
0.1
27.3
33.4
41.2
2
BZT52C43-G
WU
43
40.0
46.0
5
100
700
1.0
0.1
32.0
10.0
12.0
5
Version: B1601
ORDERING INFORMATION
PART NO.
PACKING CODE
BZT52Cxxx-G
(Note 1, 2)
RH
PACKING CODE
SUFFIX
G
PACKAGE
PACKING
SOD-123
3K / 7" Reel
Note 1: "xxx" is device code from "2V4" - "43"
Note 2: Whole series with green compound
EXAMPLE
EXAMPLE P/N
PART NO.
BZT52C2V4-G RHG
BZT52C2V4-G
PACKING
PACKING CODE
CODE
SUFFIX
RH
G
DESCRIPTION
Green compound
Version: B1601
PACKAGE OUTLINE DIMENSIONS
SOD-123
DIM.
Unit (mm)
Unit (inch)
Min
Max
Min
Max
A
1.40
1.80
0.055
0.071
B
3.55
3.85
0.140
0.152
C
0.45
0.70
0.018
0.028
D
2.55
2.85
0.100
0.112
E
0.95
1.35
0.037
0.053
F
0.05
0.15
0.002
0.006
0.50 REF
G
H
0.10
0.02 REF
0.004
SUGGEST PAD LAYOUT
DIM.
Unit (mm)
Unit (inch)
Min
Min
G
2.25
0.089
X
0.90
0.035
X1
4.05
0.159
Y
0.95
0.037
Version: B1601
CREAT BY ART
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf,
assumes no responsibility or liability for any errors or inaccuracies.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC's terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
Version: B1601
很抱歉,暂时无法提供与“BZT52C24-G RHG”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+2.209011+0.28669
- 国内价格 香港价格
- 1+2.021271+0.26233
- 10+1.2489310+0.16209
- 100+0.77415100+0.10047
- 500+0.56585500+0.07344
- 1000+0.498291000+0.06467
