TSM120NA03CR
Taiwan Semiconductor
N-Channel Power MOSFET
30V, 39A, 11.7mΩ
FEATURES
KEY PERFORMANCE PARAMETERS
● Low RDS(ON) to minimize conductive loss
PARAMETER
VALUE
UNIT
VDS
30
V
● Low gate charge for fast power switching
● 100% UIS and Rg tested
● Compliant to RoHS directive 2011/65/EU and in
accordance to WEEE 2002/96/EC
● Halogen-free according to IEC 61249-2-21
RDS(on)
VGS = 10V
11.7
(max)
VGS = 4.5V
14.9
mΩ
Qg
nC
en
de
d
4.5
APPLICATIONS
● DC-DC Converters
● Battery Power Management
● ORing FET/Load Switch
mm
PDFN56
eco
Note: MSL 1 (Moisture Sensitivity Level) per J-STD-020
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
Drain-Source Voltage
No
tR
Gate-Source Voltage
Continuous Drain Current
TC = 25°C
(Note 1)
Pulsed Drain Current
(Note 2)
Single Pulse Avalanche Current
(Note 2)
Single Pulse Avalanche Energy
Total Power Dissipation
LIMIT
UNIT
VDS
30
V
VGS
±20
V
ID
TA = 25°C
SYMBOL
TC = 25°C
TC = 125°C
TA = 25°C
TA = 125°C
Operating Junction and Storage Temperature Range
39
11
A
IDM
156
A
IAS
EAS
15.6
36.5
A
mJ
PD
PD
33
6.6
2.6
0.5
W
W
TJ, TSTG
- 55 to +150
°C
SYMBOL
LIMIT
UNIT
Junction to Case Thermal Resistance
RӨJC
3.8
°C/W
Junction to Ambient Thermal Resistance
RӨJA
48
°C/W
THERMAL PERFORMANCE
PARAMETER
Thermal Performance Note: RӨJA is the sum of the junction-to-case and case-to-ambient thermal resistances. The casethermal reference is defined at the solder mounting surface of the drain pins. RӨJA is guaranteed by design while RӨCA is
determined by the user’s board design.
1
Version: B1610
TSM120NA03CR
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
CONDITIONS
SYMBOL
MIN
TYP
MAX
UNIT
Static
Drain-Source Breakdown Voltage
VGS = 0V, ID = 250µA
BVDSS
30
V
Gate Threshold Voltage
VGS = VDS, ID = 250µA
VGS(TH)
1.2
1.9
2.5
V
Gate-Source Leakage Current
VGS = ±20V, VDS = 0V
IGSS
±100
nA
1
100
Drain-Source Leakage Current
IDSS
VGS = 0V, VDS = 30V
TJ = 125°C
VGS = 10V, ID = 11A
(Note 3)
VGS = 4.5V, ID = 11A
Forward Transconductance
VDS = 5V, ID = 11A
gfs
(Note 4)
VGS = 10V, VDS = 15V,
Total Gate Charge
ID = 11A
Total Gate Charge
ID = 11A
Gate-Drain Charge
Input Capacitance
VGS = 0V, VDS = 15V
Output Capacitance
f = 1.0MHz
Gate Resistance
Switching
e co
Reverse Transfer Capacitance
f = 1.0MHz
(Note 4)
tR
Turn-On Delay Time
8.3
11.7
11.9
14.9
35
Turn-On Rise Time
Turn-Off Delay Time
ID = 7A, RG = 10Ω,
Turn-Off Fall Time
mΩ
S
Qg
9.2
Qg
4.5
Qgs
1.9
Qgd
1.7
Ciss
562
Coss
144
Crss
50
Rg
0.5
1.7
3.4
td(on)
8.4
tr
4.3
td(off)
22.4
tf
3.1
VSD
1.2
V
mm
VGS = 4.5V, VDS = 15V,
Gate-Source Charge
en
Dynamic
(Note 3)
RDS(on)
de
Drain-Source On-State Resistance
µA
d
VGS = 0V, VDS = 30V
nC
pF
Ω
ns
No
Source-Drain Diode
Forward Voltage
(Note 3)
VGS = 0V, IS = 11A
Reverse Recovery Time
IS = 11A ,
trr
14.7
ns
Reverse Recovery Charge
dI/dt = 100A/μs
Qrr
7.3
nC
Notes:
1.
2.
3.
4.
Silicon limited current only.
L = 0.3mH, VGS = 10V, VDS = 25V, RG = 25Ω, IAS = 15.6A, Starting TJ = 25°C
Pulse test: Pulse Width ≤ 300µs, duty cycle ≤ 2%.
Switching time is essentially independent of operating temperature.
ORDERING INFORMATION
PART NO.
TSM120NA03CR RLG
PACKAGE
PACKING
PDFN56
2,500pcs / 13” Reel
2
Version: B1610
TSM120NA03CR
CHARACTERISTICS CURVES
Output Characteristics
Transfer Characteristics
30
12
6
VGS=3V
18
d
18
24
12
25℃
de
VGS=10V
VGS=7V
VGS=5V
VGS=4.5V
VGS=4V
VGS=3.5V
24
ID, Drain Current (A)
30
6
150℃
2
3
en
3
4
Gate-Source Voltage vs. Gate Charge
mm
On-Resistance vs. Drain Current
0.016
VGS=4.5V
0.012
VDS=15V
ID=11A
8
6
e co
0.01
VGS, Gate to Source Voltage (V)
10
0.014
0.008
VGS=10V
0.004
0.002
tR
0.006
6
12
18
24
4
2
No
On-Resistance vs. Junction Temperature
RDS(on), Drain-Source On-Resistance (Ω)
VGS=10V
ID=11A
1.6
1.4
1.2
1
0.8
0.6
-75
-50
-25
50
75
6
8
10
On-Resistance vs. Gate-Source Voltage
2
1.8
4
Qg, Gate Charge (nC)
(Normalized)
2
VDS, Drain to Source Voltage (V)
RDS(ON), Drain-Source On-Resistance (Ω)
-55℃
0.03
0.025
0.02
0.015
ID=11A
0.01
0.005
4
5
6
7
8
9
10
TJ, Junction Temperature (°C)
3
Version: B1610
TSM120NA03CR
BVDSS vs. Junction Temperature
CISS
500
400
300
200
COSS
100
CRSS
10
15
30
1
0.9
0.8
-75
-50
-25
50
75
100 125 150
Maximum Safe Operating Area, Junction-to-Case
Source-Drain Diode Forward Current vs. Voltage
100
100
10
tR
SINGLE PULSE
RӨJC=3.8°C/W
TC=25°C
1
0.1
10
e co
RDS(ON)
IS, Reverse Drain Current (A)
mm
200
1.1
en
ID=1mA
d
C, Capacitance (pF)
600
1.2
de
BVDSS (Normalized)
Capacitance vs. Drain-Source Voltage
700
1
10
150℃
25℃
-55℃
1
0.1
0.2
100
0.4
0.6
0.8
1
1.2
VSD, Body Diode Forward Voltage (V)
No
Normalized Thermal Transient Impedance, Junction-to-Case
Normalized Effective Transient
Thermal Impedance, ZӨJC
10
SINGLE PULSE
RӨJC=3.8°C/W
1
Duty=0.5
Duty=0.2
Duty=0.1
Duty=0.05
Duty=0.02
Duty=0.01
Single
0.1
0.01
0.0001
0.001
Notes:
Duty = t1 / t2
TJ = TC + PDM x ZӨJC x RӨJC
0.01
0.1
t, Square Wave Pulse Duration (sec)
4
Version: B1610
TSM120NA03CR
PACKAGE OUTLINE DIMENSIONS (Unit: Millimeters)
mm
en
de
d
PDFN56
No
tR
e co
SUGGESTED PAD LAYOUT (Unit: Millimeters)
MARKING DIAGRAM
TSC
120NA03
GYWWF
G
Y
WW
F
= Halogen Free
= Year Code
= Week Code (01~52)
= Factory Code
5
Version: B1610
TSM120NA03CR
No
tR
e co
mm
en
de
d
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf,
assumes no responsibility or liability for any errors or inaccuracies.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
6
Version: B1610
