TSM8N80
Taiwan Semiconductor
N-Channel Power MOSFET
800V, 8A, 1.4Ω
KEY PERFORMANCE PARAMETERS
Features
Low RDS(ON) 1.4Ω (Max.)
Low gate charge typical @ 41nC (Typ.)
Improve dV/dt capability
PARAMETER
VALUE
UNIT
VDS
800
V
RDS(on) (max)
1.4
Ω
Qg
41
nC
Power Supply
Lighting.
en
de
d
APPLICATION
ITO-220
mm
TO-220
Notes: Moisture sensitivity level: level 3. Per J-STD-020
eco
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
SYMBOL
Drain-Source Voltage
Gate-Source Voltage
TC = 25°C
(Note 1)
tR
Continuous Drain Current
Pulsed Drain Current
TC = 100°C
(Note 2)
TO-220
UNIT
VDS
800
V
VGS
±30
V
8
ID
PDTOT
A
4.9
IDM
Total Power Dissipation @ TC = 25°C
ITO-220
32
A
250
40.3
W
(Note 3)
EAS
160
mJ
Single Pulsed Avalanche Current
(Note 3)
IAS
8
A
EAR
25
mJ
dV/dt
4.5
V
TJ, TSTG
- 55 to +150
°C
No
Single Pulsed Avalanche Energy
Repetitive Avalanche Energy
(Note 7)
Peak Diode Recovery
Operating Junction and Storage Temperature Range
THERMAL PERFORMANCE
PARAMETER
SYMBOL
TO-220
ITO-220
UNIT
Junction to Case Thermal Resistance
RӨJC
0.5
3.1
°C/W
Junction to Ambient Thermal Resistance
RӨJA
62.5
°C/W
Notes: RӨJA is the sum of the junction-to-case and case-to-ambient thermal resistances. The case thermal reference is defined
at the solder mounting surface of the drain pins. RӨJA is guaranteed by design while RӨCA is determined by the user’s board
design. RӨJA shown below for single device operation on FR-4 PCB in still air.
Document Number: DS_P0000151
1
Version: D15
TSM8N80
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
Static
CONDITIONS
SYMBOL
MIN
TYP
MAX
UNIT
(Note 4)
VGS = 0V, ID = 250µA
BVDSS
800
V
Gate Threshold Voltage
VDS = VGS, ID = 250µA
VGS(TH)
2.0
4.0
V
Gate Body Leakage
VGS = ±30V, VDS = 0V
IGSS
±100
nA
Zero Gate Voltage Drain Current
VDS = 800V, VGS = 0V
IDSS
10
µA
Drain-Source On-State Resistance
VGS = 10V, ID = 4.0A
RDS(ON)
1.1
1.4
Ω
Forward Transconductance
VDS = 30V, ID = 4.0A
gfs
Diode Forward Voltage
IS = 8A, VGS = 0V
VSD
7
S
1.5
V
41
(Note 5)
Total Gate Charge
Qg
VDS = 640V, ID = 8.0A,
Gate-Source Charge
VGS = 10V
Gate-Drain Charge
VDS = 25V, VGS = 0V,
Output Capacitance
Reverse Transfer Capacitance
Gate Resistance
f = 1.0MHz
F = 1MHz, open drain
e co
(Note 6)
Turn-On Delay Time
VDD = 400V,
Turn-On Rise Time
RGEN = 25Ω,
Turn-Off Delay Time
ID = 8.0A, VGS = 10V,
tR
Turn-Off Fall Time
Source-Drain Diode
Qgs
10
Qgd
11
Ciss
1921
Coss
146
Crss
12
Rg
2.9
td(on)
133
tr
30
td(off)
172
tf
37
VSD
1.5
V
mm
Input Capacitance
Switching
de
en
Dynamic
d
Drain-Source Breakdown Voltage
nC
pF
Ω
ns
(Note 4)
IS = 8.0A, VGS = 0V
Reverse Recovery Time
VGS=0V, IS = 8A
trr
479
ns
dIF/dt = 100A/µs
Qrr
5.5
µC
No
Forward On Voltage
Reverse Recovery Charge
Notes:
1.
Current limited by package.
2.
Pulse width limited by the maximum junction temperature.
3.
L = 5mH, IAS = 8A, VDD = 50V, RG = 25Ω, Starting TJ = 25 C.
4.
Pulse test: PW ≤ 300µs, duty cycle ≤ 2%.
5.
For DESIGN AID ONLY, not subject to production testing.
6.
Switching time is essentially independent of operating temperature.
7.
ISD ≤ 8A, dI/dt ≤ 200A/uS, Vdd ≤ BV, Starting TJ = 25 C.
o
o
2
Version: D15
TSM8N80
ORDERING INFORMATION
PART NO.
PACKAGE
PACKING
TSM8N80CZ C0G
TO-220
50pcs / Tube
TSM8N80CI C0G
ITO-220
50pcs / Tube
No
tR
e co
mm
en
de
d
Note:
1. Compliant to RoHS Directive 2011/65/EU and in accordance to WEEE 2002/96/EC
2. Halogen-free according to IEC 61249-2-21 definition
3
Version: D15
TSM8N80
CHARACTERISTICS CURVES
(TC = 25°C unless otherwise noted)
Transfer Characteristics
en
de
d
Output Characteristics
Gate Charge
tR
e co
mm
On-Resistance vs. Drain Current
Source-Drain Diode Forward Voltage
No
On-Resistance vs. Junction Temperature
4
Version: D15
TSM8N80
BVDSS vs. Junction Temperature
en
de
d
Drain Current vs. Case Temperature
Capacitance vs. Drain-Source Voltage
tR
e co
mm
Maximum Safe Operating Area(TO-220)
No
Maximum Safe Operating Area (ITO-220)
5
Version: D15
TSM8N80
ELECTRICAL CHARACTERISTICS CURVES
en
de
d
Normalized Thermal Transient Impedance, Junction-to-Ambient (TO-220)
No
tR
e co
mm
Normalized Thermal Transient Impedance, Junction-to-Ambient (ITO-220)
6
Version: D15
TSM8N80
PACKAGE OUTLINE DIMENSIONS (Unit: Millimeters)
en
de
d
TO-220
MARKING DIAGRAM
No
tR
e co
mm
Y = Year Code
M = Month Code for Halogen Free Product
O =Jan P =Feb Q =Mar R =Apr
V =Aug
S =May T =Jun U =Jul
W =Sep X =Oct
Y =Nov Z =Dec
L = Lot Code (1~9, A~Z)
7
Version: D15
TSM8N80
en
de
d
ITO-220
= Halogen Free
= Year Code
= Week Code (01~52)
= Factory Code
No
tR
e co
G
Y
WW
F
mm
MARKING DIAGRAM
8
Version: D15
TSM8N80
No
tR
e co
mm
en
de
d
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf,
assumes no responsibility or liability for any errors or inaccuracies.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
9
Version: D15
很抱歉,暂时无法提供与“TSM8N80CZ C0G”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 4000+10.499634000+1.35841
