RS3MC
RS3MC
    MDD(辰达半导体)
    SMC(DO-214AB)
    快/超快恢复二极管 独立式 1KV 3A SMC(DO-214AB)
RS3MC 数据手册
RS3AC THRU RS3MC Reverse Voltage - 50 to 1000 Volts Forward Current - 3.0 Ampere SURFACE MOUNT FAST RECOVERY RECTIFIER Features DO-214AB/SMC  The plastic package carries Underwriters Laboratory Flammability Classification 94V-0  Idea for printed circuit board  Open Junction chip 0.245(6.22) 0.220(5.59) 0.126 (3.20) 0.114 (2.90)  Low reverse leakage  High forward surge current capability  High temperature soldering guaranteed: 0.280(7.11) 0.260(6.60) 0.012(0.305) 0.006(0.152) 250℃/ 10 seconds at terminals  Glass passivated chip junction 0.103(2.62) 0.079(2.06) 0.060(1.52) 0.030(0.76) Mechanical Data 0.008(0.203)MAX. 0.320(8.13) 0.305(7.75) Case : JEDEC DO-214AB/SMC Molded plastic body Terminals : Solder plated, solderable per MIL-STD-750,Method 2026 Polarity : Polarity symbol marking on body Mounting Position : Any Weight : 0.0077 ounce, 0.22 grams Dimensions in inches and (millimeters) Maximum Ratings And Electrical Characteristics Ratings at 25 C ambient temperature unless otherwise specified. Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%. RS3AC Parameter SYMBOLS Marking Code RS3BC RS3DC RS3GC RS3JC RS3KC RS3MC MDD MDD MDD MDD MDD MDD MDD RS3AC RS3BC RS3DC RS3GC RS3JC RS3KC RS3MC 50 35 50 100 70 100 200 140 200 400 280 400 600 420 600 800 560 800 1000 700 1000 UNITS V V V Maximum repetitive peak reverse voltage Maximum RMS voltage Maximum DC blocking voltage VRRM Maximum average forward rectified current I(AV) 3.0 A Peak forward surge current 8.3ms single half sine-wave superimposed onrated load (JEDEC Method) IFSM 90 A Maximum instantaneous forward voltage at 3.0A VF 1.30 V Maximum DC reverse current at rated DCblocking voltage IR 5.0 100.0 μA Maximum reverse recovery time TA=25℃ TA=125℃ (NOTE 1) Typical junction capacitance (NOTE 2) Typical thermal resistance (NOTE 3) VRMS VDC trr CJ RJA RθJC Operating junction and storage temperature range TJ,TSTG 150 250 500 ns 40.0 pF 45.0 15.0 ℃/W -55 to +150 ℃ Note:1.Reverse recovery condition IF=0.5A,IR=1.0A,Irr=0.25A 2.Measured at 1MHz and applied reverse voltage of 4.0V D.C. 3.P.C.B. mounted with 2.0”x2.0”(5.0x5.0cm) copper pad areas http://www.microdiode.com Rev:2024A2 Page :1 RS3AC THRU RS3MC Reverse Voltage - 50 to 1000 Volts Forward Current - 3.0 Ampere Ratings And Characteristic Curves Fig.2 Typical Reverse Characteristics Fig.1 Maximum Average Forward Current Rating 4.0 Instaneous Reverse Current(μ A) 100 Average Forward Current (A) 3.5 3.0 2.5 2.0 1.5 1.0 0.5 Single phase half-wave 60 Hz resistive or inductive load 0.0 25 50 75 100 125 150 TJ=125°C 10 1.0 TJ=25°C 0.1 175 00 Case Temperature (°C) 20 40 60 80 100 120 140 percent of Rated Peak Reverse Voltage (%) Fig.3 Typical Instaneous Forward Fig.4 Typical Junction Capacitance Characteristics 10 TJ=25°C TJ=25°C Junction Capacitance (pF) Instaneous Forward Current (A) 100 1.0 0.1 pulse with 300μ s 0.0 0.5 1.0 1.5 2.0 TJ=25°C f = 1.0MHz Vsig = 50mVp-p 1% duty cycle 0.01 10 1 2.5 Instaneous Forward Voltage (V) 0.1 1.0 10 100 Reverse Voltage (V) Fig.5 Maximum Non-Repetitive Peak Forward Surage Current Peak Forward Surage Current (A) 120 100 80 60 40 20 00 8.3 ms Single Half Sine Wave (JEDEC Method) 1 10 100 Number of Cycles The curve above is for reference only. http://www.microdiode.com Rev:2024A2 Page :2 RS3AC THRU RS3MC Reverse Voltage - 50 to 1000 Volts Forward Current - 3.0 Ampere Packing information P0 unit:mm P1 d Item Symbol Tolerance SMC Carrier width Carrier length Carrier depth Sprocket hole 13" Reel outside diameter 13" Reel inner diameter Feed hole diameter Sprocket hole position Punch hole position Punch hole pitch Sprocket hole pitch Embossment center Overall tape thickness Tape width A B C d D D1 D2 E F P P0 P1 T W Reel width W1 0.1 0.1 0.1 0.05 2.0 min 0.5 0.1 0.1 0.1 0.1 0.1 0.1 0.3 1.0 6.15 8.41 2.42 1.50 330.00 50.00 13.00 1.75 7.50 8.00 4.00 2.00 0.25 16.00 16.50 E F B A W P D2 T D1 C W1 D Note:Devices are packed in accor dance with EIA standar RS-481-A and specifications listed above. Reel packing PACKAGE REEL SIZE REEL (pcs) COMPONENT SPACING (mm) SMC 13" 3,000 4.0 INNER BOX (mm) REEL DIA, (mm) 190*190*41 330 BOX (pcs) 6000 CARTON SIZE (mm) 365*365*340 CARTON (pcs) 42000 APPROX. GROSS WEIGHT (kg) 14.0 Suggested Pad Layout http://www.microdiode.com Symbol Unit (mm) A 4.3 0.170 B 0.160 C 4.1 7.9 0.311 D 3.8 0.150 E 12 0.472 Unit (inch) Rev:2024A2 Page :3
RS3MC 价格&库存
很抱歉,暂时无法提供与“RS3MC”相匹配的价格&库存,您可以联系我们找货
RS3MC
  • 1+0.29260
  • 200+0.18920
  • 1500+0.16390
  • 3000+0.14520
库存:9574
RS3MC
  • 10+0.31230
  • 100+0.25808
  • 600+0.23166
  • 1200+0.22819
  • 3000+0.18828
库存:2940
RS3MC
  • 100+0.16781
  • 500+0.15786
库存:1250
RS3MC
  • 20+0.11750
库存:1775
RS3MC
  • 500+0.16781
  • 3000+0.15537
库存:2588
