1SMC5352
Taiwan Semiconductor
5W, 15V Surface Mount Zener Diode
FEATURES
KEY PARAMETERS
Ideal for automated placement
Glass passivated chip junction
Moisture sensitivity level: level 1, per J-STD-020
RoHS Compliant
Halogen-free according to IEC 61249-2-21
APPLICATIONS
● For general purpose regulation and protection applications
PARAMETER
VALUE
UNIT
VZ
15
V
PD
5
W
TJ MAX
150
°C
Package
DO-214AB (SMC)
Configuration
Single die
MECHANICAL DATA
Case:DO-214AB (SMC)
Molding compound meets UL 94V-0 flammability rating
Terminal:Matte tin plated leads, solderable per J-STD-002
Meet JESD 201 class 2 whisker test
Polarity:Indicated by cathode band
Weight:0.260g (approximately)
DO-214AB (SMC)
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
SYMBOL
VALUE
UNIT
Steady state power dissipation at TL = 75°C
PD
5
W
Junction temperature
TJ
-55 to +150
°C
Storage temperature
TSTG
-55 to +150
°C
Maximum ratings are those values beyond which device damage can occur.
Maximum ratings applied to the device are individual stress limit values (not normal operating conditions)
and are not valid simultaneously. If these limits are exceeded, device functional operation is not implied,
damage may occur and reliability may be attached.
THERMAL PERFORMANCE
PARAMETER
Junction-to-ambient thermal resistance
1
SYMBOL
TYP
UNIT
RӨJA
55
°C/W
Version: G2102
1SMC5352
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
Part number
(Note 1)
1SMC5352
Marking
code
352B
Regulator
Voltage
(Note 2)
Test
Current
VZ@IZ
IZ
ZZ
IR
VR
IZM
Maximum
Dynamic
Knee
Impedance
ZZK@1mA
V
mA
Ω
μA
V
mA
Ω
15
75
2.5
1.0
11.5
315
75
Maximum Maximum
I Test
Dynamic Reverse R
Voltage
Impedance Current
Maximum
Regulator
Current
Notes:
1. Tolerance and voltage regulation designation. The type number listed indicates a tolerance of 5%.
2. Zener voltage (VZ) measurement
Nominal Zener voltage is measured with the device junction in thermal equilibrium with ambient temperature
25°C
ORDERING INFORMATION
ORDERING CODE
PACKAGE
PACKING
1SMC5352
DO-214AB (SMC)
3,000 / Tape & Reel
2
Version: G2102
1SMC5352
CHARACTERISTICS CURVES
Fig.1 Effect Of Zener Current
Fig.2 Steady State Power Derating
PD, MAXIMUM POWER DISSIPATION (W)
100
10
1
1
10
7
6
5
4
3
2
1
IZ. ZENER TEST CURRENT (mA)
25
50
75
100
125
150
LEAD TEMPERATURE (°C)
Fig.3 Typical Junction Capacitance
1000
CJ, CAPACITANCE (pF)
Zz, DYNAMIC IMPEDANCE (Ω)
1000
100
10
100
BREAKDOWN VOLTAGE (V)
3
Version: G2102
1SMC5352
PACKAGE OUTLINE DIMENSIONS
DO-214AB (SMC)
SUGGESTED PAD LAYOUT
MARKING DIAGRAM
4
P/N
= Marking Code
G
= Green Compound
YW
= Date Code
F
= Factory Code
Version: G2102
1SMC5352
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf,
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability
for application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
5
Version: G2102
很抱歉,暂时无法提供与“1SMC5352HM6G”相匹配的价格&库存,您可以联系我们找货
