MM5Z series
Voltage regulator diodes
Rev. 1 — 7 April 2021
Product data sheet
1. General description
General-purpose Zener diodes in an SOD523 (SC-79) ultra small flat lead Surface-Mounted Device
(SMD) plastic package.
2. Features and benefits
Non-repetitive peak reverse power disspation: ≤ 40 W
Total power dissipation: ≤ 300 mW
Tolerance series: ± 2 %
Wide working voltage range: nominal 2.4 V to 36 V
Low differential resistance
3. Applications
General regulation functions
4. Quick reference data
Table 1. Quick reference data
Symbol
Parameter
Conditions
VF
forward voltage
IF = 100 mA
PZSM
non-repetitive peak reverse power
dissipation
[1]
[2]
Min
Typ
Max
Unit
[1] -
1.1
V
[2] -
40
W
Pulse test: tp ≤ 300 μs; δ ≤ 0.02
tp = 100 µs; square wave; Tj = 25 °C before surge
5. Pinning information
Table 2. Pinning
Pin
Symbol
Description
1
K
cathode[1]
2
A
anode
Simplified outline
1
Graphic symbol
2
K
A
006aaa152
[1]
The marking bar indicates the cathode.
MM5Z series
Nexperia
6. Ordering information
Table 3. Ordering information
Type number
Package
MM5Z2V4T5G to
MM5Z36VT5G[1]
[1]
Name
Description
Version
SC-79
plastic surface-mounted package; 2 leads
SOD523
The series consists of 29 types with nominal working voltages from 2.4 V to 36 V.
7. Marking
Table 4. Marking Codes
Type number
Marking Code
Type number
Marking Code
MM5Z2V4T5G
C1
MM5Z10VT5G
E6
MM5Z2V7T5G
C2
MM5Z11VT5G
E7
MM5Z3V0T5G
C3
MM5Z12VT5G
E8
MM5Z3V3T5G
C4
MM5Z13VT5G
E9
MM5Z3V6T5G
C5
MM5Z15VT5G
E0
MM5Z3V9T5G
C6
MM5Z16VT5G
EA
MM5Z4V3T5G
C7
MM5Z18VT5G
EB
MM5Z4V7T5G
C8
MM5Z20VT5G
EC
MM5Z5V1T5G
C9
MM5Z22VT5G
ED
MM5Z5V6T5G
C0
MM5Z24VT5G
EE
MM5Z6V2T5G
E1
MM5Z27VT5G
EF
MM5Z6V8T5G
E2
MM5Z30VT5G
EG
MM5Z7V5T5G
E3
MM5Z33VT5G
EH
MM5Z8V2T5G
E4
MM5Z36VT5G
EK
MM5Z9V1T5G
E5
MM5Z_SER
Product data sheet
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2021. All rights reserved
2 / 10
MM5Z series
Nexperia
8. Limiting values
Table 5. Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
Parameter
Min
Max
Unit
IF
forward current
200
mA
PZSM
dissipation
Tamb = 25 °C; prior to surge
40
W
Ptot
total power dissipation
Tamb = 25 °C
[1]
300
mW
Tj
junction temperature
150
°C
Tamb
ambient temperature
−55
+150
°C
Tstg
storage temperature
−65
+150
°C
[1]
Conditions
2
Device mounted on an FR4 Printed-Circuit Board (PCB) with aproximately 35 mm Cu area at cathode tab
9. Thermal characteristics
Table 6. Thermal characteristics
Symbol
Parameter
Conditions
Rth(j-a)
thermal resistance from junction
to ambient
in free air
Rth(j-sp)
to solder point
[1]
[2]
Min
Typ
Max
Unit
[1]
350
K/W
[2]
65
K/W
2
Soldering point of cathode tab
10. Characteristics
Table 7. Electrical characteristics
Tj = 25 °C unless otherwise specified.
Symbol
Parameter
Conditions
VF
forward voltage
IF = 10 mA
IF = 100 mA
[1]
Max
Unit
[1]
0.9
V
[1]
1.1
V
MM5Z_SER
Product data sheet
3 / 10
MM5Z series
Nexperia
Table 8. Electrical characteristics per type: MM5Z2V4T5G to MM5Z24VT5G
MM5ZxxxT5G
Working voltage Reverse current
VZ (V)
IR (µA)
IZ = 5 mA
Differential
resistance
rdiff (Ω)
IZ = 1
IZ = 5
mA
mA
Temperature
coefficient
SZ (mV/K)
IZ = 5 mA
Diode
capacitance
Cd (pF)[1]
Min
Max
Max
Max
Min
Max
Max
2.35
2.45
50.0
VR (V)
1.0
Max
2V4
400
100
-3.5
2V7
2.65
2.75
20.0
1.0
450
100
-3.5
3V0
2.94
3.06
10.0
1.0
500
95
-3.5
3V3
3.23
3.37
5.0
1.0
500
95
-3.5
3V6
3.53
3.67
5.0
1.0
500
90
-3.5
3V9
3.82
3.98
3.0
1.0
500
90
-3.5
4V3
4.21
4.39
3.0
1.0
600
90
-3.5
4V7
4.61
4.79
3.0
2.0
500
80
-3.5
0.2
325
5V1
5.00
5.20
2.0
2.0
480
60
-2.7
1.2
300
5V6
5.49
5.71
1.0
2.0
400
40
-2.0
2.5
275
6V2
6.08
6.32
3.0
4.0
150
10
0.4
3.7
250
6V8
6.66
6.94
2.0
4.0
80
15
1.2
4.5
215
7V5
7.35
7.65
1.0
5.0
80
10
2.5
5.3
170
8V2
8.04
8.36
0.7
5.0
80
10
3.2
6.2
150
9V1
8.92
9.28
0.5
6.0
100
10
3.8
7.0
120
10V
9.80
10.20
0.2
7.0
150
10
4.5
8.0
110
11V
10.78
11.22
0.1
8.0
150
10
5.4
9.0
110
12V
11.76
12.24
0.1
8.0
150
10
6.0
10.0
105
13V
12.74
13.26
0.1
8.0
170
10
7.0
11.0
105
15V
14.70
15.30
0.05
10.5
200
15
9.2
13.0
100
16V
15.68
16.32
0.05
11.2
200
40
10.4
14.0
90
18V
17.64
18.36
0.05
12.6
225
45
12.4
16.0
80
20V
19.60
20.40
0.05
14.0
225
55
14.4
18.0
70
22V
21.56
22.44
0.05
15.4
250
55
16.4
20.0
60
24V
23.52
24.48
0.05
16.8
250
70
18.4
22.0
55
[1]
f = 1 MHz; VR = 0 V
MM5Z_SER
Product data sheet
4 / 10
MM5Z series
Nexperia
Table 9. Electrical characteristics per type: MM5Z27VT5G to MM5Z36VT5G
MM5ZxxxT5G
VZ (V)
IR (µA)
IZ =2 mA
Differential
resistance
rdiff (Ω)
IZ = 0.5 IZ = 2
mA
mA
Temperature
coefficient
SZ (mV/K)
IZ = 2 mA
Diode
capacitance
Cd (pF)[1]
Min
Max
Max
Max
Min
Max
Max
26.46
27.54
0.05
VR (V)
18.9
Max
27V
300
80
21.4
25.3
50
30V
29.40
30.60
0.05
21.0
300
80
24.4
29.4
50
33V
32.34
33.66
0.05
23.1
325
80
27.4
33.4
45
36V
35.28
36.72
0.05
25.2
350
90
30.4
37.4
45
[1]
f = 1 MHz; VR = 0 V
aaa-028550
103
IF
(mA)
102
10
10
1
1
10-1
10-1
10-2
10-2
10-3
0.4
0.6
0.8
VF (V)
1.0
10-3
0.4
Tj = 25 ° C
Fig. 1.
aaa-028551
103
IF
(mA)
102
0.6
0.8
VF (V)
1.0
Tj = 25 ° C
Forward current as a function of forward
voltage; typical values (MM5Z2V4T5G)
voltage; typical values (MM5Z6V8T5G)
mld444
0.5
aaa-028552
103
Fig. 2.
SZ
(mV/K)
IF
(mA)
102
4V7
4V3
- 0.5
10
2V4
1
2V7
3V9
-1
10-1
3V6
- 1.5
3V3
3V0
10-2
10-3
0.4
-2
10- 1
0.6
0.8
VF (V)
voltage; typical values (MM5Z7V5T5G)
MM5Z_SER
Product data sheet
10
IZ (mA)
102
Tj = 25 °C to 150 °C
Tj = 25 ° C
Fig. 3.
1
1.0
Fig. 4.
Temperature coefficient as a function of
working current; typical values (MM5Z2V4T5G
to 4V7T5G)
5 / 10
MM5Z series
Nexperia
mld445
12
IR
(A)
15
SZ
(mV/K)
13
12
11
10
9V1
8V2
7V5
6V8
6V2
5V6
5V1
8
4
aaa-006665
10-1
2V4
10-2
2V7
10-3
3V0
3V3
3V6 3V9
4V3 4V7 5V1
10-4
10-5
5V6
10-6
6V2
6V8
10-7
10-8
-4
10- 1
1
10
IZ (mA)
10-9
102
Fig. 5.
IR
(A)
Fig. 6.
aaa-006666
10-1
IR
(A)
7V5
10 12
15
18
22
8V2
10-3
2
11 13
6
VR (V)
8
Reverse current as a function of reverse
voltage; typical values (MM5Z2V4T5G to
6V8T5G)
aaa-032242
10-1
10-2
27
10-3
9V1
4
Tj = 25 °C
working current; typical values (MM5Z5V1T5G
to 15VT5G)
10-2
30
33
36
10-4
10-4
10-5
10-5
10-6
10-6
10-7
10-7
10-8
10-8
10
15
VR (V)
25
10-9
Tj = 25 °C
Fig. 7.
Product data sheet
24
28
32
36
VR (V)
40
Tj = 25 °C
voltage; typical values (MM5Z7V5T5G to
24VT5G)
MM5Z_SER
Fig. 8.
voltage; typical values (MM5Z27VT5G to
36VT5G)
6 / 10
MM5Z series
Nexperia
11. Package outline
0.85
0.75
0.65
0.58
1
1.65 1.25
1.55 1.15
2
0.34
0.26
0.17
0.11
Dimensions in mm
Fig. 9.
02-12-13
Package outline SOD523 (SC-79)
12. Soldering
2.15
1.4
solder lands
solder resist
0.5 0.6
(2×) (2×)
1.2
solder paste
occupied area
Dimensions in mm
0.4
(2×)
0.5
(2×)
sod523_fr
Fig. 10. Reflow soldering footprint SOD523 (SC-79)
MM5Z_SER
Product data sheet
7 / 10
MM5Z series
Nexperia
13. Revision history
Table 10. Revision history
Document ID
Release date
Data sheet status
Change notice Supersedes
MM5Z_SER v.1
20210407
Product data sheet
MM5Z_SER
Product data sheet
8 / 10
MM5Z series
Nexperia
14. Legal information
injury, death or severe property or environmental damage. Nexperia and its
suppliers accept no liability for inclusion and/or use of Nexperia products in
such equipment or applications and therefore such inclusion and/or use is at
the customer’s own risk.
Data sheet status
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Document status
[1][2]
Product
status [3]
Definition
Objective [short]
data sheet
Development
This document contains data from
the objective specification for
product development.
Preliminary [short]
data sheet
Qualification
the preliminary specification.
Product [short]
data sheet
Production
This document contains the product
specification.
[1]
[2]
[3]
Please consult the most recently issued document before initiating or
completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have
changed since this document was published and may differ in case of
multiple devices. The latest product status information is available on
the internet at https://www.nexperia.com.
Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any representations or
warranties as to the accuracy or completeness of information included herein
and shall have no liability for the consequences of use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the relevant
full data sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and customer have explicitly
agreed otherwise in writing. In no event however, shall an agreement be
valid in which the Nexperia product is deemed to offer functions and qualities
beyond those described in the Product data sheet.
Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy
or completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no responsibility
for the content in this document if provided by an information source outside
of Nexperia.
In no event shall Nexperia be liable for any indirect, incidental, punitive,
special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards customer
for the products described herein shall be limited in accordance with the
Terms and conditions of commercial sale of Nexperia.
Right to make changes — Nexperia reserves the right to make changes
to information published in this document, including without limitation
specifications and product descriptions, at any time and without notice. This
document supersedes and replaces all information supplied prior to the
publication hereof.
Suitability for use — Nexperia products are not designed, authorized or
warranted to be suitable for use in life support, life-critical or safety-critical
systems or equipment, nor in applications where failure or malfunction
of an Nexperia product can reasonably be expected to result in personal
MM5Z_SER
Product data sheet
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no representation
or warranty that such applications will be suitable for the specified use
without further testing or modification.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia accepts no liability for
any assistance with applications or customer product design. It is customer’s
sole responsibility to determine whether the Nexperia product is suitable
and fit for the customer’s applications and products planned, as well as
for the planned application and use of customer’s third party customer(s).
Customers should provide appropriate design and operating safeguards to
minimize the risks associated with their applications and products.
Nexperia does not accept any liability related to any default, damage, costs
or problem which is based on any weakness or default in the customer’s
applications or products, or the application or use by customer’s third party
customer(s). Customer is responsible for doing all necessary testing for the
customer’s applications and products using Nexperia products in order to
avoid a default of the applications and the products or of the application or
use by customer’s third party customer(s). Nexperia does not accept any
liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia products are
sold subject to the general terms and conditions of commercial sale, as
published at http://www.nexperia.com/profile/terms, unless otherwise agreed
in a valid written individual agreement. In case an individual agreement is
concluded only the terms and conditions of the respective agreement shall
apply. Nexperia hereby expressly objects to applying the customer’s general
terms and conditions with regard to the purchase of Nexperia products by
customer.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Non-automotive qualified products — Unless this data sheet expressly
states that this specific Nexperia product is automotive qualified, the
product is not suitable for automotive use. It is neither qualified nor tested in
accordance with automotive testing or application requirements. Nexperia
accepts no liability for inclusion and/or use of non-automotive qualified
products in automotive equipment or applications.
In the event that customer uses the product for design-in and use in
automotive applications to automotive specifications and standards,
customer (a) shall use the product without Nexperia’s warranty of the
product for such automotive applications, use and specifications, and (b)
whenever customer uses the product for automotive applications beyond
Nexperia’s specifications such use shall be solely at customer’s own risk,
and (c) customer fully indemnifies Nexperia for any liability, damages or failed
product claims resulting from customer design and use of the product for
automotive applications beyond Nexperia’s standard warranty and Nexperia’s
product specifications.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
9 / 10
MM5Z series
Nexperia
Contents
1. General description...................................................... 1
2. Features and benefits.................................................. 1
3. Applications.................................................................. 1
4. Quick reference data....................................................1
5. Pinning information......................................................1
6. Ordering information....................................................2
7. Marking.......................................................................... 2
8. Limiting values............................................................. 3
9. Thermal characteristics............................................... 3
10. Characteristics............................................................ 3
11. Package outline.......................................................... 7
12. Soldering..................................................................... 7
13. Revision history..........................................................8
14. Legal information........................................................9
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 7 April 2021
MM5Z_SER
Product data sheet
10 / 10
很抱歉,暂时无法提供与“MM5Z8V2T5GF”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 5871+0.544855871+0.07029
- 10000+0.4860210000+0.06270
- 100000+0.40757100000+0.05258
- 国内价格 香港价格
- 3000+0.419583000+0.05413
- 6000+0.375756000+0.04848
- 9000+0.353399000+0.04559
- 15000+0.3282315000+0.04235
- 21000+0.3133221000+0.04042
- 30000+0.2988130000+0.03855
- 国内价格 香港价格
- 1+2.032071+0.26216
- 10+1.2652310+0.16323
- 100+0.78449100+0.10121
- 500+0.57435500+0.07410
- 1000+0.506341000+0.06533
