SK510BHM4G
SK510BHM4G
    TAIWANSEMICONDUCTOR(台湾半导体)
    DO214AA
    DIODE SCHOTTKY 100V 5A DO214AA
SK510BHM4G 数据手册
SK52B – SK515B Taiwan Semiconductor 5A, 20V - 150V Schottky Barrier Surface Mount Rectifier FEATURES ● ● ● ● ● ● ● KEY PARAMETERS Low power loss, high efficiency Ideal for automated placement Guard ring for overvoltage protection High surge current capability Moisture sensitivity level: level 1, per J-STD-020 RoHS Compliant Halogen-free according to IEC 61249-2-21 APPLICATIONS ● ● ● ● PARAMETER VALUE UNIT IF 5 A VRRM 20 - 150 V IFSM 120 A TJ MAX 150 °C Package DO-214AA (SMB) Configuration Single die Switching mode power supply (SMPS) Adapters Lighting application Converter MECHANICAL DATA ● ● ● ● ● ● Case: DO-214AA (SMB) Molding compound meets UL 94V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Meet JESD 201 class 2 whisker test Polarity: Indicated by cathode band Weight: 0.100g (approximately) DO-214AA (SMB) ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER SYMBOL Marking code on the device Repetitive peak reverse voltage VRRM Reverse voltage, total rms value VR(RMS) Forward current Surge peak forward current, 8.3ms single half sine-wave superimposed on rated load Critical rate of rise of off-state voltage SK SK SK SK SK SK SK 52B 53B 54B 55B 56B 59B 510B SK SK SK SK SK SK SK 52B 53B 54B 55B 56B 59B 510B 20 30 40 50 60 90 100 14 21 28 35 42 63 70 SK UNIT 515B SK 515B 150 V 105 V IF 5 A IFSM 120 A dV/dt 10,000 V/μs Junction temperature TJ - 55 to +150 °C Storage temperature TSTG - 55 to +150 °C 1 Version: P2102 SK52B – SK515B Taiwan Semiconductor THERMAL PERFORMANCE PARAMETER SYMBOL TYP UNIT Junction-to-lead thermal resistance RӨJL 19 °C/W Junction-to-ambient thermal resistance RӨJA 60 °C/W ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER Forward voltage CONDITIONS (1) Reverse current @ rated VR Reverse current @ rated VR Reverse current @ rated VR (2) (2) (2) SK52B SK53B SK54B SK55B SK56B SK59B SK510B SK515B SK52B SK53B SK54B SK55B SK56B SK59B SK510B SK515B SK52B SK53B SK54B SK55B SK56B SK59B SK510B SK515B SK52B SK53B SK54B SK55B SK56B SK59B SK510B SK515B IF = 5A, TJ = 25°C TJ = 25°C SYMBOL VF TYP MAX UNIT - 0.55 V - 0.75 V - 0.85 V - 0.95 V - 500 µA - 100 µA - 20 mA - 10 mA - - mA - - mA - - mA - 2 mA IR TJ = 100°C TJ = 125°C IR IR Notes: 1. Pulse test with PW = 0.3ms 2. Pulse test with PW = 30ms 2 Version: P2102 SK52B – SK515B Taiwan Semiconductor ORDERING INFORMATION ORDERING CODE(1) PACKAGE PACKING SK5xB DO-214AA (SMB) 3,000 / Tape & Reel Notes: 1. "x" defines voltage from 20V(SK52B) to 150V(SK515B) 3 Version: P2102 SK52B – SK515B Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Forward Current Derating Curve Fig.2 Typical Junction Capacitance 1000 SK52B-SK54B 5 SK55B-SK56B 4 CAPACITANCE (pF) 3 2 100 SK59B-SK515B 1 f=1.0MHz Vsig=50mVp-p 10 0 25 50 75 100 125 0.1 150 1 100 REVERSE VOLTAGE (V) LEAD TEMPERATURE (°C) Fig.3 Typical Reverse Characteristics Fig.4 Typical Forward Characteristics 100 100 =125oC TJ 10 1 0.1 TJ=75oC TJ=25oC 0.01 0.001 SK52B-SK54B SK55B-SK515B 0.0001 10 20 30 40 50 60 70 80 90 INSTANTANEOUS FORWARD CURRENT (A) INSTANTANEOUS REVERSE CURRENT (mA) 10 10 10 TJ=125oC UF1DLW 1 TJ=125°C 1 TJ=25°C 0.1 (A) AVERAGE FORWARD CURRENT (A) 6 =25oC TJ 0.01 0.1 0.001 0.3 0.4 0.5 0.6 0.7 Pulse width SK52B-SK54B SK55B-SK56B 0.8 SK59B-SK515B 0.9 1 1.1 0.01 100 0 PERCENT OF RATED PEAK REVERSE VOLTAGE (%) 0.2 0.4 0.6 0.8 1 1.2 1.4 FORWARD VOLTAGE (V) 4 Version: P2102 1.2 SK52B – SK515B Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.5 Maximum Non-Repetitive Forward Surge Current PEAK FORWARD SURGE CURRENT (A) 140 120 8.3ms single half sine wave 100 80 60 40 20 0 1 10 100 NUMBER OF CYCLES AT 60 Hz Fig.6 Typical Transient Thermal Characteristics TRANSIENT THERMAL IMPEDANCE (°C/W) 100 10 1 0.1 0.01 0.1 1 10 100 T-PULSE DURATION(s) 5 Version: P2102 SK52B – SK515B Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS DO-214AA (SMB) SUGGESTED PAD LAYOUT MARKING DIAGRAM 6 P/N = Marking Code G = Green Compound YW = Date Code F = Factory Code Version: P2102 SK52B – SK515B Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 7 Version: P2102
SK510BHM4G 价格&库存
很抱歉,暂时无法提供与“SK510BHM4G”相匹配的价格&库存,您可以联系我们找货
