TSS0230LU
Taiwan Semiconductor
Small Signal Product
Surface Mount Schottky Barrier Diode
FEATURES
- Designed for mounting on small surface
- Extremely thin/leadless package
- Low capacitance
- Low forward voltage drop
- Compliant to RoHS Directive 2011/65/EU and
in accordance to WEEE 2002/96/EC
- Halogen-free according to IEC 61249-2-21
0603-B
MECHANICAL DATA
- Case: 0603-B
- Terminal: Gold plated, solderable per
MIL-STD-750, method 2026
- Polarity: Indicated by cathode band
- Weight: 3 mg (approximately)
- Marking code: BA
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS (TA=25°C unless otherwise noted)
PARAMETER
Repetitive Peak Reverse Voltage
SYMBOL
VALUE
UNIT
VRRM
35
V
DC Reverse Voltage
VR
30
V
Average Forward Current
IO
200
mA
Peak Forward Surge Current 8.3 ms Single Half
Sine-Wave Superimposed on Rate Load
IFSM
1.0
A
Power Dissipation
Pd
150
mW
Forward Voltage @ IF=200mA
VF
0.5
V
IR
30
μA
Junction Temperature
TJ
-40 to +125
°C
Storage Temperature
TSTG
-40 to +125
°C
Reverse Leakage Current
VR=10V
Version: C1601
TSS0230LU
RATINGS AND CHARACTERISTICS CURVES
Fig. 2 Reverse Characteristics
Fig.1 Forward Characteristics
1000
1000
Reverse Current (A)
Forward current (mA)
100
100
10
125°C
75°C
25°C
-25°C
1
75°C
10
25°C
1
0.1
-25°C
0.01
0.001
0.1
0.2
0.3
0.4
0.5
0.6
0.7
0.2
0.4
0.6
0.8
1
1.2
1
Reverse voltage (V)
Forward Voltage(V)
2
Fig. 3 Capacitance Between Terminals
120
100
4
100
f = 1MHz
Average Forward Current (mA)
Capacitance Between Terminals (pF)
3
Fig. 4 Current Derating Rate
10
80
Fig. 3
60
40
Fig. 4
10
15
25
50
75
100
125
150
VCE(sat)
Ambient Temperature (°C)
Reverse Voltage (V)
1
440
430
Tm=25゚C
F=200 mA
n=30pcs
420
410
400
AVG 21 28mV
0 10 20 30 40 50 60 70 80 90 100
50
45
40
35
30
25
10
5
Fig 7 CT Dispersion Map
Fig 6 IR Dispersion
Tm=25゚C
VR=10V
n=30pcs
AVG1816uA
Capacitance between
Terminals(pF)
450
Fig 5 VF Dispersion Map
Reverse (nA)
Forward Voltage(mV)
2
30
29
28
27
26
25
24
23
22
21
Tm=25゚C
F=1MHz
VR=0V
n=10pcs
AVG22.8pF
Version: C1601
3
4
5
6
TSS0230LU
ORDERING INFORMATION
PART NO.
PACKING CODE
TSS0230LU
RG
PACKING CODE
SUFFIX
PACKAGE
PACKING
0603-B
4K / 7" Reel
G
Note : Whole series with green compound
EXAMPLE
EXAMPLE P/N
PART NO.
PACKING CODE
TSS0230LU RGG
TSS0230LU
RG
PACKING CODE
DESCRIPTION
SUFFIX
G
Green compound
PACKAGE OUTLINE DIMENSION
0603-B
DIM.
Unit (mm)
Unit (inch)
Min
Typ.
Max
Min
Typ.
Max
L
1.60
1.80
0.063
0.071
W
0.80
1.00
0.031
0.039
T
0.70
0.85
0.028
0.033
C
0.35
0.014
D
0.70
0.028
E
0.30
0.012
Version: C1601
TSS0230LU
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf,
assumes no responsibility or liability for any errors or inaccuracies.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC's terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
Version: C1601
很抱歉,暂时无法提供与“TSS0230U RGG”相匹配的价格&库存,您可以联系我们找货
