CSD02060G
CSD02060G
    WOLFSPEED
    TO-263(D²Pak)
    DIODE SCHOTTKY 600V 3.5A TO263-2
CSD02060G 数据手册
CSD02060–Silicon Carbide Schottky Diode VRRM = 600 V Zero Recovery® Rectifier IF(AVG) = 2 A Qc Features • • • • • • • = 7 nC Package 600-Volt Schottky Rectifier Zero Reverse Recovery Current Zero Forward Recovery Voltage High-Frequency Operation Temperature-Independent Switching Behavior Extremely Fast Switching Positive Temperature Coefficient on VF TO-263-2 TO-220-2 Benefits • • • • • Replace Bipolar with Unipolar Rectifiers Essentially No Switching Losses Higher Efficiency Reduction of Heat Sink Requirements Parallel Devices Without Thermal Runaway PIN 1 CASE PIN 2 Applications • • • Switch Mode Power Supplies Power Factor Correction - Typical PFC Pout : 200W-400W Motor Drives - Typical Power : 0.50HP-1.0HP Part Number Package Marking CSD02060A TO-220-2 CSD02060 CSD02060G TO-263-2 CSD02060 Maximum Ratings G D02060 Rev. Datasheet: CS Symbol Parameter Value Unit Test Conditions VRRM Repetitive Peak Reverse Voltage 600 V VRSM Surge Peak Reverse Voltage 600 V VDC DC Blocking Voltage 600 V IF(AVG) Average Forward Current 2.4 3.5 A TC=150˚C, DC TC=125˚C, DC IF(PEAK) Peak Forward Current 5 A TC=125˚, TREP 1KHz Figure 3. Current Derating Figure 4. Capacitance vs. Reverse Voltage 1.0E+01 Zth (°C/W) 1.0E+00 1.0E-01 1.0E-02 1.0E-03 1.E-07 1.E-06 1.E-05 1.E-04 1.E-03 Tim e (s) Figure 5. Transient Thermal Impedance 3 CSD02060 Rev. G 1.E-02 1.E-01 1.E+00 Typical Performance 40.000 40 35 35.000 Power Dissipation (W) 30 30.000 25 25.000 20 20.000 15.000 15 10 10.000 5 5.000 0 0.000 25 50 75 100 125 150 175 25 50 75 100 125 150 175 TC Case Temperature (°C) Figure 6. Power Derating 4 CSD02060 Rev. G Package Dimensions POS Package TO-220-2 A B A C P F J B D X S E 1 2 G T Z U H V L M W N PIN 1 CASE PIN 2 Min Max .381 .410 9.677 10.414 DA .255 5.969 M illim eters .120 2.540 M in M ax .337 5.664 10.033 10.414 EB .235.590 .255 .615 5.969 F C D .102.143 .112 2.591 .153 .337 .337 8.560 1.105 1.147 .590 .610 14.986 .500 .550 .149 .153 3.785 R1.147 0.197 28.626 1.127 G Y Millimeters Max .235 Inc hes .100 M in M ax .395.223 .410 CP OS Q Inches Min H E F J G L H 14.986 6.477 6.477 3.048 8.560 15.621 2.845 3.632 3.886 8.560 28.067 29.134 15.494 12.700 13.970 3.886 29.134 R 0.197 MJ L N M PN .530.025 .550 R 0.010 .045 .028 .036 .195 .045 .055 .195.165 .205 13.462 13.970 .036 .635 R 0.254 .055 1.143 .711 .914 .205 4.953 1.143 1.397 .185 4.191 4.953 5.207 QP .170.048 .180 .054 4.318 1.219 4.572 1.372 SQ S T T U U VV .048 3° 1.371 3° 5° 3° 5° 3° 5° 2.388 2.794 6° 3° 5° .100.094 .110 1.219 6° 3° 6° 3° 6° 3° .110 2.54 WW XX .014.014 .021 3° 3° 5° .356 .025 3° 5.5° .533 .356 5°3° Y z Y Z 3° 3° .054 5° 3° 5° 3° .395 .410 .385 .130 .150 .130 10.033 .410 3.302 .150 10.414 9.779 3.810 3.302 .914 1.397 5.207 4.699 6° 6° 2.794 .635 5.5° 10.414 3.810 NOTE: 1. Dimension L, M, W apply for Solder Dip Finish Package Dimensions POS Package TO-263-2 Inches Max Min Max A .396 .406 10.058 10.312 B .297 .303 7.544 7.696 C .057 .063 1.448 1.600 D .237 .243 6.015 6.167 E* 0.00 .070 0.00 1.778 F .048 .062 1.219 1.575 G * PIN 1 PIN 2 CASE Millimeters Min .100 TYP 2.540 TYP H .335 .345 8.509 8.763 J .028 .034 .711 .864 K 2˚ 4˚ 2˚ 4˚ L .170 .180 4.318 4.572 M .048 .052 1.219 1.321 N .595 .615 15.113 15.621 P 0.00 0.10 0.00 .254 Q R0.018 TYP R0.022 TYP R0.457 TYP R0.559 TYP R .090 .110 2.286 2.794 S .013 .017 .330 .432 T 6.5˚ 8.5˚ 6.5˚ 8.5˚ U .103 .107 2.616 2.718 V R0.028 TYP R0.032 TYP R0.711 TYP R0.813 TYP W — 5.0˚ — 5.0˚ Note: * Tab “E” may not be present 5 CSD02060 Rev. G Recommended Solder Pad Layout TO-263-2 TO-220-2 Part Number Package Marking CSD02060A TO-220-2 CSD02060 CSD02060G TO-263-2 CSD02060 Diode Model Diode Model CSD02060 Vf T = VT + If*RT VT= 0.94 + (Tj * -1.15*10-3) RT= 0.0115 + (Tj * 3.4*10-3) Note: Tj = Diode Junction Temperature In Degrees Celcius VT RT “The levels of environmentally sensitive, persistent biologically toxic (PBT), persistent organic pollutants (POP), or otherwise restricted materials in this product are below the maximum concentration values (also referred to as the threshold limits) permitted for such substances, or are used in an exempted application, in accordance with EU Directive 2002/95/EC on the restriction of the use of certain hazardous substances in electrical and electronic equipment (RoHS), as amended through April 21, 2006.” This product has not been designed or tested for use in, and is not intended for use in, applications implanted into the human body nor in applications in which failure of the product could lead to death, personal injury or property damage, including but not limited to equipment used in the operation of nuclear facilities, life-support machines, cardiac defibrillators or similar emergency medical equipment, aircraft navigation or communication or control systems, air traffic control systems, or weapons systems. Copyright © 2006-2009 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree, the Cree logo, and Zero Recovery are registered trademarks of Cree, Inc. 6 CSD02060 Rev. G Cree, Inc. 4600 Silicon Drive Durham, NC 27703 USA Tel: +1.919.313.5300 Fax: +1.919.313.5451 www.cree.com/power
CSD02060G
PDF文档中包含以下信息:
1. 物料型号:型号为LM5111。
2. 器件简介:LM5111是一款由国家半导体公司生产的同步降压型开关稳压器,适用于需要高效率和低噪声的应用。
3. 引脚分配:LM5111有8个引脚,包括输入电压引脚、输出电压引脚、使能引脚、地引脚、反馈引脚等。
4. 参数特性:包括输入电压范围、输出电压范围、最大输出电流、静态电流等。
5. 功能详解:LM5111具有内部补偿、软启动、过压保护、欠压锁定、热保护等功能。
6. 应用信息:适用于便携式设备、电池供电设备等。
7. 封装信息:采用SOIC封装。
CSD02060G 价格&库存
很抱歉,暂时无法提供与“CSD02060G”相匹配的价格&库存,您可以联系我们找货
