BAV19WS/BAV20WS/BAV21WS
Taiwan Semiconductor
200mA, 120-250V High Voltage SMD Switching Diode
FEATURES
KEY PARAMETERS
Low power loss, high efficiency
Ideal for automated placement
High surge current capability
Moisture sensitivity level: level 1, per J-STD-020
Compliant to RoHS directive 2011/65/EU and
in accordance to WEEE 2002/96/EC
● Halogen-free according to IEC 61249-2-21
APPLICATIONS
Switching mode power supply (SMPS)
Adapters
Lighting application
On-board DC/DC converter
PARAMETER
VALUE
UNIT
IF(AV)
200
mA
VRRM
120-250
V
IFSM
2.5
A
VF at IF=200mA
1.25
V
TJ MAX.
150
°C
Package
SOD-323F
Configuration
Single die
MECHANICAL DATA
Case: SOD-323F
Molding compound meets UL 94 V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Meet JESD 201 class 1A whisker test
Polarity: Indicated by cathode band
Weight: 4.5 ± 0.5 mg (approximately)
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
SYMBOL BAV19WS BAV20WS
S5
Marking code on the device
Power dissipation
PD
200
mW
Average forward current
IF
200
mA
120
S6
BAV21WS UNIT
200
S7
Repetitive peak reverse voltage
Pulse Width = 1 s ,
Square Wave
Peak forward surge
current
Pulse Width = 1 μs ,
Square Wave
Junction temperature range
VRRM
250
V
TJ
-65 to +150
°C
Storage temperature range
TSTG
-65 to +150
°C
0.5
IFSM
A
2.5
1
Version: I1804
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
CONDITIONS
Forward voltage per diode
IF = 100mA, TJ = 25°C
(1)
IF = 200mA, TJ = 25°C
SYMBOL
MIN
MAX
1.00
1.25
120
200
250
IR
100
nA
CJ
5
pF
trr
50
ns
VF
BAV19WS
Reverse voltage
BAV20WS
IR=100µA, TJ = 25°C
VR
BAV21WS
Reverse current
(2)
BAV19WS
VR=100V TJ = 25°C
BAV20WS
VR=150V TJ = 25°C
BAV21WS
VR=200V TJ = 25°C
1 MHz, VR=0V
Junction capacitance
IF=IR=30mA, RL=100Ω,
Reverse recovery time
IRR=3mA
UNIT
V
V
Notes:
1. Pulse test with PW=0.3 ms
2. Pulse test with PW=30 ms
ORDERING INFORMATION
PART NO.
PACKAGE
PACKING
BAV19WS RRG
SOD-323F
3K / 7" Reel
BAV19WS RR
SOD-323F
3K / 7" Reel
BAV19WS R9G
SOD-323F
10K / 13" Reel
BAV19WS R9
SOD-323F
10K / 13" Reel
BAV20WS RRG
SOD-323F
3K / 7" Reel
BAV20WS RR
SOD-323F
3K / 7" Reel
BAV20WS R9G
SOD-323F
10K / 13" Reel
BAV20WS R9
SOD-323F
10K / 13" Reel
BAV21WS RRG
SOD-323F
3K / 7" Reel
BAV21WS RR
SOD-323F
3K / 7" Reel
BAV21WS R9G
SOD-323F
10K / 13" Reel
BAV21WS R9
SOD-323F
10K / 13" Reel
2
Version: I1804
CHARACTERISTICS CURVES
Fig.1 Typical Forward Characteristics
Fig.2 Typical Reverse Characteristics
100
IR, Instantaneous Reverse Current (μA)
IF,Instantaneous Forward Current (A)
1
TA=150oC
TA=125oC
TA=75oC
TA=25oC
TA=0oC
TA=-40oC
0.1
0.01
0.001
TA=125oC
10
TA=75oC
1
TA=25oC
0.1
TA=0oC
0.01
0.001
0.0001
0.4
0.6
0.8
1
1.2
1.4
100
150
200
250
VR, Instantaneous Reverse Voltage (V)
VF, Instantaneous Forward Voltage (V)
Fig.3 Typical Capacitance VS. Reverse Voltage
Fig.3 Power Derating Curve
250
3.0
PD, Power Dissipation (mW)
4.0
CT, Total Capacitance (pF)
TA=150oC
TA=-40oC
f=1.0MHz
2.0
1.0
0.0
200
150
100
50
40
VR, Reverse Voltage (V)
50
100
150
200
o
TA, ambient Temperature ( C)
3
Version: I1804
PACKAGE OUTLINE DIMENSION
SOD-323F
DIM.
Unit (mm)
Unit (inch)
Min
Max
Min
Max
A
1.15
1.35
0.045
0.053
B
2.30
2.80
0.091
0.110
C
0.25
0.40
0.010
0.016
D
1.60
1.80
0.063
0.071
E
0.80
1.10
0.031
0.043
F
0.05
0.25
0.002
0.010
SUGGEST PAD LAYOUT
DIM.
4
Unit (mm)
Unit (inch)
Typ.
Typ.
A
0.63
0.025
B
0.83
0.033
C
1.60
0.063
D
2.86
0.113
Version: I1804
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf,
assumes no responsibility or liability for any errors or inaccuracies.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
5
Version: I1804
很抱歉,暂时无法提供与“BAV20WS RRG”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 3000+0.406053000+0.05253
- 6000+0.362986000+0.04696
- 9000+0.340999000+0.04412
- 15000+0.3162715000+0.04092
- 21000+0.3016221000+0.03902
- 30000+0.2873730000+0.03718
- 国内价格 香港价格
- 1+2.026011+0.26210
- 10+1.2348010+0.15974
- 100+0.76370100+0.09880
- 500+0.55801500+0.07219
- 1000+0.491271000+0.06356
- 国内价格
- 1+0.29895
- 200+0.11934
- 500+0.11535
- 1000+0.11340
