FR156GTA
FR156GTA
    SMCDIODESOLUTIONS(桑德斯)
    DO-204AC
    DIODE GPP 800V 1.5A DO15
FR156GTA 数据手册
FR151G-FR157G Technical Data Data Sheet N0443, Rev. A FR151G THRU FR157G FAST RECOVERY RECTIFIERS Features         DO-15 Circuit Diagram Diffused Junction Low Forward Voltage Drop High Current Capability High Reliability High Surge Current Capability This is a Pb − Free Device All SMC parts are traceable to the wafer lot Additional testing can be offered upon request Mechanical Data       Case: JEDEC DO-15 molded plastic body Terminals: Plated axial leads, solderable per MIL-STD-750, Method 2026 Polarity: Color band denotes cathode end Mounting Position: Any Weight: 0.014 ounce, 0.40 grams Maximum Ratings and Electrical Characteristics @TA=25°C unless otherwise specified Single phase half-wave 60Hz, resistive or inductive load, for capacitive load current derate by 20%. Symbol FR 151G FR 152G FR 153G FR 154G FR 155G FR 156G FR 157G Units Maximum repetitive peak reverse voltage VRRM 50 100 200 400 600 800 1000 V Maximum RMS voltage VRMS 35 70 140 280 420 560 700 V Maximum DC blocking voltage VDC 50 100 200 400 600 800 1000 V Maximum average forward rectified current 0.375”(9.5mm) lead length at TA=55℃ I(AV) 1.5 A Peak forward surge current 8.3ms single half sinewave superimposed on rated load (JEDEC Method) IFSM 50 A Maximum instantaneous forward voltage at 1.5A VF 1.3 V Maximum DC reverse current TA=25 ℃ at rated DC blocking voltage TA=100 ℃ IR 5.0 100.0 µA Maximum Reverse Recovery Time (Note 1) Trr Typical Junction Capacitance (Note 2) CJ 25 pF Typical Thermal Resistance (Note 3) RθJA 50.0 °C/W Junction Temperature Storage Temperature Range TJ TSTG -65 to +150 -65 to +150 °C °C Characteristic 150 250 *Glass passivated forms are available upon request Note: 1. Reverse recovery condition IF=0.5A, IR=1.0A, Irr=0.25A 2. Measured at 1MHz and applied reverse voltage of 4.0V D.C. 3. Thermal resistance from junction to ambient at 0.375”(9.5mm)lead length, P.C.B. mounted  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  500 ns FR151G-FR157G Technical Data Data Sheet N0443, Rev. A Ratings and Characteristics Curves  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  FR151G-FR157G Technical Data Data Sheet N0443, Rev. A Mechanical Dimensions DO-15 SYMBOL Ordering Information Device FR151G-FR157G Package DO-15 (Pb-Free) Millimeters Inches Min. Max. Min. Max. A 25.4 - 1.000 - B 5.5 7.62 0.217 0.300 C 0.7 0.9 0.028 0.034 D 2.6 3.6 0.104 0.140 Marking Diagram Shipping Where XXXXX is YYWWL FR151G SSG YY WW L 3000pcs /tape For information on tape and reel specifications, including part orientation and tape sizes, please refer to our tape and reel packaging specification. = Part Name = SSG = Year = Week = Lot Number Cautions:Molding resin Epoxy resin UL:94V-0 Carrier Tape Specification DO-15 SYMBOL Millimeters Min. Max. A 4.50 5.50 B 50.9 53.9 Z - 1.20 T 5.60 6.40 E - 0.80 IL1-L2I - 1.0  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  FR151G-FR157G Technical Data Data Sheet N0443, Rev. A DISCLAIMER: 1- The information given herein, including the specifications and dimensions, is subject to change without prior notice to improve product characteristics. Before ordering, purchasers are advised to contact the SMC - Sangdest Microelectronics (Nanjing) Co., Ltd sales department for the latest version of the datasheet(s). 2- In cases where extremely high reliability is required (such as use in nuclear power control, aerospace and aviation, traffic equipment, medical equipment , and safety equipment) , safety should be ensured by using semiconductor devices that feature assured safety or by means of users’ fail-safe precautions or other arrangement . 3- In no event shall SMC - Sangdest Microelectronics (Nanjing) Co., Ltd be liable for any damages that may result from an accident or any other cause during operation of the user’s units according to the datasheet(s). SMC - Sangdest Microelectronics (Nanjing) Co., Ltd assumes no responsibility for any intellectual property claims or any other problems that may result from applications of information, products or circuits described in the datasheets. 4- In no event shall SMC - Sangdest Microelectronics (Nanjing) Co., Ltd be liable for any failure in a semiconductor device or any secondary damage resulting from use at a value exceeding the absolute maximum rating. 5- No license is granted by the datasheet(s) under any patents or other rights of any third party or SMC - Sangdest Microelectronics (Nanjing) Co., Ltd. 6- The datasheet(s) may not be reproduced or duplicated, in any form, in whole or part, without the expressed written permission of SMC - Sangdest Microelectronics (Nanjing) Co., Ltd. 7- The products (technologies) described in the datasheet(s) are not to be provided to any party whose purpose in their application will hinder maintenance of international peace and safety nor are they to be applied to that purpose by their direct purchasers or any third party. When exporting these products (technologies), the necessary procedures are to be taken in accordance with related laws and regulations..  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com 
FR156GTA 价格&库存
很抱歉,暂时无法提供与“FR156GTA”相匹配的价格&库存,您可以联系我们找货
