BZD27C11PWH – BZD27C220PWH
Taiwan Semiconductor
1W, 11V - 220V Zener Diode
FEATURES
KEY PARAMETERS
AEC-Q101 qualified
Silicon zener diodes
Low profile surface-mount package
Zener and surge current specification
Low leakage current
Excellent stability
Moisture sensitivity level: level 1, per J-STD-020
RoHS Compliant
Halogen-free according to IEC 61249-2-21
PARAMETER
VALUE
UNIT
VZ
11 - 220
V
Test current IZT
5 - 50
mA
Ptot
1.0
W
TJ MAX
175
°C
Package
SOD-123W
Configuration
Single die
APPLICATIONS
● Voltage regulating
● Reference voltage
● Protection circuit
MECHANICAL DATA
Case: SOD-123W
Molding compound meets UL 94V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Meet JESD 201 class 2 whisker test
Polarity: Indicated by cathode band
Weight: 0.016g (approximately)
SOD-123W
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
SYMBOL
VALUE
UNIT
VF
1.0
V
2.3
W
1.0
W
PZSM
300
W
PRSM
150
W
PRSM
100
W
Junction temperature
TJ
- 55 to +175
°C
Storage temperature
TSTG
- 55 to +175
°C
Forward voltage @ IF = 0.2A
TL = 80°C
Power dissipation
TA = 25°C
(1)
Non-repetitive peak pulse power dissipation
100μs square pulse
(2)
10/1000μs waveform (BZD27C11PWH to BZD27C100PWH)
10/1000μs waveform (BZD27C110PWH to BZD27C220PWH)
Ptot
Notes:
1. Mounted on Cu-Pad size 5mm x 5mm
2. TJ = 25°C prior to surge
1
Version: A2103
THERMAL PERFORMANCE
PARAMETER
SYMBOL
TYP
UNIT
Junction-to-lead thermal resistance
RӨJL
22
°C/W
Junction-to-ambient thermal resistance
RӨJA
85
°C/W
Junction-to-case thermal resistance
RӨJC
24
°C/W
ORDERING INFORMATION
ORDERING CODE(1)
PACKAGE
PACKING
BZD27CxPWH
SOD-123W
10,000 / Tape & Reel
Notes:
1. “x” defines voltage from 11V (BZD27C11PWH) to 220V (BZD27C220PWH)
2
Version: A2103
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
Zener voltage
Part
number
Marking
code
VZ @ IZT
Test
current
(1)
V
Min
Nom
Max
Regulator impedance
Test
current
IZT
ZZT @ IZT
ZZK @ IZK
IZK
mA
Ω
Ω
mA
Max
Max
BZD27C11PWH
N2
10.5
11
11.6
50
7
700
0.25
BZD27C12PWH
N3
11.4
12
12.6
50
7
700
0.25
BZD27C13PWH
N4
12.4
13
13.7
50
10
700
0.25
BZD27C15PWH
N5
14.3
15
15.8
50
10
700
0.25
BZD27C16PWH
N6
15.2
16
16.8
25
15
700
0.25
BZD27C18PWH
N7
17.1
18
18.9
25
15
750
0.25
BZD27C20PWH
P0
19
25
15
750
0.25
BZD27C22PWH
P1
20.9
22
23.1
25
15
750
0.25
BZD27C24PWH
P3
22.8
24
25.2
25
15
750
0.25
BZD27C27PWH
P4
25.7
27
28.4
25
15
1000
0.25
BZD27C30PWH
P5
28.5
30
31.5
25
15
1000
0.25
BZD27C33PWH
P6
31.4
33
34.7
25
15
1000
0.25
BZD27C36PWH
P7
34.2
36
37.8
10
40
1000
0.25
BZD27C39PWH
P8
37.1
39
41
10
40
1000
0.25
BZD27C43PWH
Q0
40.9
43
45.2
10
45
1500
0.25
BZD27C47PWH
Q1
44.7
47
49.4
10
45
1500
0.25
BZD27C51PWH
Q2
48.5
51
53.6
10
60
1500
0.25
BZD27C56PWH
Q5
53.2
56
58.8
10
60
2000
0.25
BZD27C62PWH
Q7
58.9
62
65.1
10
80
2000
0.25
BZD27C68PWH
R1
64.6
68
71.4
10
80
2000
0.25
BZD27C75PWH
R2
71.3
75
78.8
10
100
2000
0.25
BZD27C82PWH
R3
77.9
82
86.1
10
200
3000
0.25
BZD27C91PWH
R4
86.5
91
95.6
5
200
3000
0.25
BZD27C100PWH
R5
95
100
105
5
200
3000
0.25
BZD27C110PWH
R6
104.5
110
115.5
5
250
4000
0.25
BZD27C120PWH
R7
114
120
126
5
300
4500
0.25
BZD27C130PWH
R8
123.5
130
136.5
5
300
5000
0.25
BZD27C150PWH
R9
142.5
150
157.5
5
300
6000
0.25
BZD27C160PWH
R10
152
160
168
5
350
6500
0.25
BZD27C180PWH
R11
171
180
189
5
450
7000
0.25
BZD27C200PWH
R12
190
200
210
5
750
8000
0.25
BZD27C220PWH
R13
209
220
231
5
900
8500
0.25
Notes:
1. Pulse test with PW = 30ms
3
Version: A2103
Zener voltage
Part number
Marking
code
VZ @ IZT
(1)
V
Temperature
Test
Clamping Voltage Leakage current coefficient of
current
Zener voltage
IZT
Vc
mA
V
(2)
@IRSM
A
Max
(1)
IR @ V R
µA
V
Max
αVZ @ IZT
mV/°C
Min
Nom
Max
Min
Max
BZD27C11PWH
N2
10.5
11
11.6
50
15.7
9.6
4.0
8.2
0.05
0.10
BZD27C12PWH
N3
11.4
12
12.6
50
17.0
8.8
3.0
9.1
0.05
0.10
BZD27C13PWH
N4
12.4
13
13.7
50
18.9
7.9
2.0
10
0.05
0.10
BZD27C15PWH
N5
14.3
15
15.8
50
20.9
7.2
1.0
11
0.05
0.10
BZD27C16PWH
N6
15.2
16
16.8
25
22.9
6.6
1.0
12
0.06
0.11
BZD27C18PWH
N7
17.1
18
18.9
25
25.6
5.9
1.0
13
0.06
0.11
BZD27C20PWH
P0
19
25
28.4
5.3
1.0
15
0.06
0.11
BZD27C22PWH
P1
20.9
22
23.1
25
31.0
4.8
1.0
16
0.06
0.11
BZD27C24PWH
P3
22.8
24
25.2
25
33.8
4.4
1.0
18
0.06
0.11
BZD27C27PWH
P4
25.7
27
28.4
25
38.1
3.9
1.0
0.11
BZD27C30PWH
P5
28.5
30
31.5
25
42.2
3.6
1.0
22
0.06
0.11
BZD27C33PWH
P6
31.4
33
34.7
25
46.2
3.2
1.0
24
0.07
0.12
BZD27C36PWH
P7
34.2
36
37.8
10
50.1
3.0
1.0
27
0.07
0.12
BZD27C39PWH
P8
37.1
39
41
10
54.1
2.8
1.0
30
0.07
0.12
BZD27C43PWH
Q0
40.9
43
45.2
10
60.7
2.5
1.0
33
0.08
0.13
BZD27C47PWH
Q1
44.7
47
49.4
10
65.5
2.3
1.0
36
0.08
0.13
BZD27C51PWH
Q2
48.5
51
53.6
10
70.8
2.1
1.0
39
0.08
0.13
BZD27C56PWH
Q5
53.2
56
58.8
10
78.6
1.9
1.0
43
0.09
0.13
BZD27C62PWH
Q7
58.9
62
65.1
10
86.5
1.7
1.0
47
0.09
0.13
BZD27C68PWH
R1
64.6
68
71.4
10
94.4
1.6
1.0
51
0.09
0.13
BZD27C75PWH
R2
71.3
75
78.8
10
103.5
1.5
1.0
56
0.09
0.13
BZD27C82PWH
R3
77.9
82
86.1
10
114
1.3
1.0
62
0.09
0.13
BZD27C91PWH
R4
86.5
91
95.6
5
126
1.2
1.0
68
0.09
0.13
BZD27C100PWH
R5
95
100
105
5
139
1.1
1.0
75
0.09
0.13
BZD27C110PWH
R6
104.5
110
115.5
5
150
1.0
1.0
82
0.09
0.13
BZD27C120PWH
R7
114
120
126
5
152
0.65
1.0
91
0.09
0.13
BZD27C130PWH
R8
123.5
130
136.5
5
185
0.81
1.0
100
0.09
0.13
BZD27C150PWH
R9
142.5
150
157.5
5
205
0.73
1.0
110
0.09
0.13
BZD27C160PWH
R10
152
160
168
5
224
0.67
1.0
120
0.09
0.13
BZD27C180PWH
R11
171
180
189
5
229
0.43
1.0
130
0.09
0.13
BZD27C200PWH
R12
190
200
210
5
254
0.39
1.0
150
0.09
0.13
BZD27C220PWH
R13
209
220
231
5
279
0.35
1.0
160
0.09
0.13
Notes :
2. 10/1000µs waveform
4
Version: A2103
CHARACTERISTICS CURVES
Fig.1 Steady State Power Derating Curve
Fig.2 Typical Junction Capacitance
1000
BZD27C12PWH
BZD27C18PWH
CAPACITANCE (pF)
Ptot - Maximum Power Dissipation (W)
1.5
1.0
0.5
0.0
50
75
100
125
150
100
BZD27C36PWH
10
1
175
BZD27C220PWH
f=1.0MHz
0.1
o
AMBIENT TEMPERATURE ( C)
1
10
100
REVERSE VOLTAGE (V)
Fig.3 Typical Forward Characteristics
Fig.4 Typical Zener Impedance
1
10000
BZD27C220PWH
Zz - DYNAMIC IMPEDANCE (Ω)
INSTANTANEOUS FORWARD CURRENT (A)
BZD27C75PWH
BZD27C12PWH
0.1
BZD27C36PWH
BZD27C220PWH
0.01
1000
BZD27C75PWH
100
BZD27C36PWH
BZD27C18PWH
10
BZD27C12PWH
1
0.001
0.6
0.7
0.8
0.9
0.1
FORWARD VOLTAGE (V)
1
10
100
Iz - ZENER TEST CURRENT (mA)
5
Version: A2103
PACKAGE OUTLINE DIMENSIONS
SOD-123W
SUGGESTED PAD LAYOUT
MARKING DIAGRAM
6
P/N
= Marking Code
YW
= Date Code
F
= Factory Code
Version: A2103
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability
for application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
7
Version: A2103
很抱歉,暂时无法提供与“BZD27C12PWH”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 25+2.15046
- 50+2.09839
- 100+2.04841
- 250+1.99946
- 1000+1.95052
- 国内价格 香港价格
- 1+4.678611+0.60515
- 10+2.8968910+0.37470
- 100+1.83556100+0.23742
- 500+1.37641500+0.17803
- 1000+1.228111000+0.15885
- 2000+1.103162000+0.14269
- 5000+0.967775000+0.12518
- 国内价格 香港价格
- 10000+0.8839910000+0.11434
- 20000+0.8135420000+0.10523
- 30000+0.7776530000+0.10059
- 50000+0.7373150000+0.09537
- 70000+0.7134370000+0.09228
- 100000+0.69023100000+0.08928
- 国内价格
- 50+2.09839
- 100+2.04841
- 250+1.99946
- 1000+1.95052
- 国内价格
- 1+0.72512
- 200+0.28070
- 500+0.27076
- 1000+0.26590
- 国内价格
- 3000+0.82061
- 12000+0.80395
- 21000+0.78833
- 51000+0.77167
