RS2GA M2G
RS2GA M2G
    TAIWANSEMICONDUCTOR(台湾半导体)
    DO-214AC
    DIODE GEN PURP 400V 1.5A DO214AC
RS2GA M2G 数据手册
RS2AA – RS2MA Taiwan Semiconductor 1.5A, 50V - 1000V Fast Recovery Surface Mount Rectifier FEATURES ● ● ● ● ● ● KEY PARAMETERS Glass passivated chip junction Ideal for automated placement Fast switching for high efficiency Moisture sensitivity level: level 1, per J-STD-020 RoHS Compliant Halogen-free according to IEC 61249-2-21 APPLICATIONS ● ● ● ● ● DC to DC converter Switching mode converters and inverters Lighting application Snubber General purpose PARAMETER VALUE UNIT IF 1.5 A VRRM 50 - 1000 V IFSM 50 A TJ MAX 150 °C Package DO-214AC (SMA) Configuration Single die MECHANICAL DATA ● ● ● ● ● ● Case: DO-214AC (SMA) Molding compound meets UL 94V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Meet JESD 201 class 2 whisker test Polarity: Indicated by cathode band Weight: 0.060g (approximately) DO-214AC (SMA) ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) Repetitive peak reverse voltage VRRM RS 2AA RS 2AA 50 Reverse voltage, total rms value VR(RMS) 35 PARAMETER SYMBOL Marking code on the device RS 2BA RS 2BA 100 RS 2DA RS 2DA 200 RS 2GA RS 2GA 400 RS 2JA RS 2JA 600 RS 2KA RS 2KA 800 70 140 280 420 560 RS UNIT 2MA RS 2MA 1000 V 700 V Forward current Peak forward surge current, 8.3ms single half sine wave superimposed on rated load Junction temperature IF 1.5 A IFSM 50 A TJ - 55 to +150 °C Storage temperature TSTG - 55 to +150 °C 1 Version: H2102 RS2AA – RS2MA Taiwan Semiconductor THERMAL PERFORMANCE PARAMETER SYMBOL TYP UNIT Junction-to-lead thermal resistance RӨJL 18 °C/W Junction-to-ambient thermal resistance RӨJA 55 °C/W ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER Forward voltage CONDITIONS (1) Reverse current @ rated VR IF = 1.5A, TJ = 25°C TJ = 25°C (2) Reverse recovery time 1MHz, VR = 4.0V RS2AA RS2BA RS2DA RS2GA RS2JA RS2KA RS2MA TYP MAX UNIT VF - 1.3 V - 5 µA - 200 µA 50 - pF - 150 ns - 250 ns - 500 ns IR TJ = 125°C Junction capacitance SYMBOL IF = 0.5A, IR = 1.0A, Irr = 0.25A CJ trr Notes: 1. Pulse test with PW = 0.3ms 2. Pulse test with PW = 30ms ORDERING INFORMATION ORDERING CODE(1) PACKAGE PACKING RS2xA DO-214AC (SMA) 7,500 / Tape & Reel Notes: 1. “x” defines voltage from 50V(RS2AA) to 1000V(RS2MA) 2 Version: H2102 RS2AA – RS2MA Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Forward Current Derating Curve Fig.2 Typical Junction Capacitance 100 1.5 CAPACITANCE (pF) 1.0 0.5 f=1.0MHz Vsig=50mVp-p 10 0.0 25 50 75 100 125 1 150 10 LEAD TEMPERATURE (°C) REVERSE VOLTAGE (V) Fig.4 Typical Forward Characteristics INSTANTANEOUS FORWARD CURRENT (A) 100 TJ=125°C 1 TJ=25°C 0.1 10 20 30 40 50 60 70 80 90 100 10 10 UF1DLW 1 TJ=125°C TJ=25°C 10.1 0.01 0.1 0.001 0.6 0.3 PERCENT OF RATED PEAK REVERSE VOLTAGE (%) Pulse width 300μs 1% duty cycle Pulse width 0.8 0.4 0.5 1.0 0.6 1.2 0.7 0.8 1.4 0.9 1.6 1 1.1 FORWARD VOLTAGE (V) Fig.5 Maximum Non-Repetitive Forward Surge Current 60 PEAK FORWARD SURGE CURRENT (A) INSTANTANEOUS REVERSE CURRENT (μA) Fig.3 Typical Reverse Characteristics 10 100 (A) AVERAGE FORWARD CURRENT (A) 2.0 8.3ms single half sine wave 50 40 30 20 10 0 1 10 100 NUMBER OF CYCLES AT 60 Hz 3 Version: H2102 1.2 RS2AA – RS2MA Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.6 Reverse Recovery Time Characteristic And Test Circuit Diagram 4 Version: H2102 RS2AA – RS2MA Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS DO-214AC (SMA) SUGGESTED PAD LAYOUT MARKING DIAGRAM 5 P/N = Marking Code G = Green Compound YW = Date Code F = Factory Code Version: H2102 RS2AA – RS2MA Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 6 Version: H2102
RS2GA M2G 价格&库存
很抱歉,暂时无法提供与“RS2GA M2G”相匹配的价格&库存,您可以联系我们找货
