BZX884S-B7V5YL
BZX884S-B7V5YL
    NEXPERIA(安世)
    SOD-882
    BZX884S-B7V5/SOD882BD/XSON2
BZX884S-B7V5YL 数据手册
BZX884S series Voltage regulator diodes Rev. 4 — 9 February 2021 Product data sheet 1. General description General-purpose Zener diodes in an ultra small SOD882BD (DFN1006BD-2) leadless Surface Mounted Device (SMD) plastic package with side-wettable flanks. 2. Features and benefits • • • Leadless ultra small plastic package with side-wettable flanks suitable for surface-mounted design Two tolerance series: ± 2 % and approximately ± 5 % Wide working voltage range: nominal 2.4 V to 75 V (E24 range) 3. Applications • General regulation functions 4. Quick reference data Table 1. Quick reference data Tamb = 25 °C unless otherwise specified. Symbol Parameter Conditions VF forward voltage IF = 10 mA Ptot total power dissipation [1] [2] Min Typ Max Unit [1] - - 0.9 V [2] - - 365 mW Pulse test: tp ≤ 300 μs; δ ≤ 0.02 Device mounted on a FR4 PCB, single-sided 70 μm copper, tin-plated and standard footprint. 5. Pinning information Table 2. Pinning Pin Symbol Description 1 K cathode[1] 2 A anode Simplified outline 1 2 Graphic symbol 1 2 006aaa152 Transparent top view [1] The marking bar indicates the cathode. BZX884S series Nexperia Voltage regulator diodes 6. Ordering information Table 3. Ordering information Type number Package BZX884S series [1] [1] Name Description Version DFN1006BD-2 Leadless ultra small plastic package with sidewettable flanks (SWF); 2 terminals; 0.65 mm pitch; 1 mm x 0.6 mm x 0.47 mm body SOD882BD The series includes 37 breakdown voltages with nominal working voltages from 2.4 V to 75 V and ±2 % and approximately ±5% tolerances. 7. Marking Table 4. Marking Codes Type number Mark. Code Type number Mark. Code Type number Mark. Code Type number Mark. Code BZX884S-B2V4 2A BZX884S-B15 2U BZX884S-C2V4 4K BZX884S-C15 4C BZX884S-B2V7 2B BZX884S-B16 2V BZX884S-C2V7 4L BZX884S-C16 4D BZX884S-B3V0 2C BZX884S-B18 2W BZX884S-C3V0 4R BZX884S-C18 4E BZX884S-B3V3 2D BZX884S-B20 2X BZX884S-C3V3 4S BZX884S-C20 4F BZX884S-B3V6 2E BZX884S-B22 2Y BZX884S-C3V6 4T BZX884S-C22 4G BZX884S-B3V9 2F BZX884S-B24 2Z BZX884S-C3V9 4U BZX884S-C24 4H BZX884S-B4V3 2G BZX884S-B27 3A BZX884S-C4V3 4U BZX884S-C27 4J BZX884S-B4V7 2H BZX884S-B30 3B BZX884S-C4V7 4Y BZX884S-C30 4M BZX884S-B5V1 2J BZX884S-B33 3C BZX884S-C5V1 5B BZX884S-C33 4N BZX884S-B5V6 2K BZX884S-B36 3D BZX884S-C5V6 5C BZX884S-C36 4P BZX884S-B6V2 2L BZX884S-B39 3E BZX884S-C6V2 5F BZX884S-C39 4Q BZX884S-B6V8 N3 BZX884S-B43 3F BZX884S-C6V8 5G BZX884S-C43 4V BZX884S-B7V5 2M BZX884S-B47 3G BZX884S-C7V5 5J BZX884S-C47 4W BZX884S-B8V2 2N BZX884S-B51 3H BZX884S-C8V2 5K BZX884S-C51 4Z BZX884S-B9V1 2P BZX884S-B56 3J BZX884S-C9V1 5L BZX884S-C56 5A BZX884S-B10 2Q BZX884S-B62 3K BZX884S-C10 3Y BZX884S-C62 5D BZX884S-B11 2R BZX884S-B68 3L BZX884S-C11 3Z BZX884S-C68 5E BZX884S-B12 2S BZX884S-B75 3M BZX884S-C12 4A BZX884S-C75 5H BZX884S-B13 2T - - BZX884S-C13 4B - - BZX884S_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 9 February 2021 © Nexperia B.V. 2021. All rights reserved 2 / 14 BZX884S series Nexperia Voltage regulator diodes 8. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter IF forward current Ptot total power dissipation Tj Tamb Tstg [1] Conditions Min Max Unit - 200 mA - 365 mW junction temperature - 150 °C ambient temperature −55 +150 °C storage temperature −65 +150 °C Min Typ Max Unit - - 340 K/W Tamb = 25 °C [1] Device mounted on a FR4 PCB, single-sided 70 μm copper, tin-plated and standard footprint. 9. Thermal characteristics Table 6. Thermal characteristics Symbol Parameter Conditions Rth(j-a) in free air [1] thermal resistance from junction to ambient [1] Device mounted on a FR4 PCB, single-sided 70 μm copper, tin-plated and standard footprint. 10. Characteristics Table 7. Characteristics Tj = 25 °C unless otherwise specified. Symbol Parameter Conditions VF forward voltage IF = 10 mA [1] Min [1] - Typ Max Unit - 0.9 V Pulse test: tp ≤ 300 μs; δ ≤ 0.02. BZX884S_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 9 February 2021 © Nexperia B.V. 2021. All rights reserved 3 / 14 BZX884S series Nexperia Voltage regulator diodes Table 8. Characteristics per type; BZX884S-B2V4 to BZX884S-C24 Tj = 25 °C unless otherwise specified. BZX884S 2V4 2V7 3V0 3V3 3V6 3V9 4V3 4V7 5V1 5V6 6V2 6V8 7V5 8V2 9V1 10 11 12 13 Sel Working voltage VZ (V) Differential resistance rdif (Ω) IZ = 5 mA IZ = 1 mA IZ = 5 mA Min Max Typ Max Typ Max Max VR (V) Min Max Max B 2.35 2.45 275 600 70 100 50 1.0 -3.5 0.0 260 C 2.20 2.60 B 2.65 2.75 300 600 75 100 20 1.0 -3.5 0.0 260 C 2.50 2.90 B 2.94 3.06 325 600 80 95 10 1.0 -3.5 0.0 260 C 2.80 3.20 B 3.23 3.37 350 600 85 95 5 1.0 -3.5 0.0 260 C 3.10 3.50 B 3.53 3.67 375 600 85 90 5 1.0 -3.5 0.0 260 C 3.40 3.80 B 3.82 3.98 400 600 85 90 3 1.0 -3.5 0.0 260 C 3.70 4.10 B 4.21 4.39 410 600 80 90 3 1.0 -3.5 0.0 260 C 4.00 4.60 B 4.61 4.79 425 500 50 80 3 2.0 -3.5 0.2 170 C 4.40 5.00 B 5.00 5.20 400 480 40 60 2 2.0 -2.7 1.2 170 C 4.80 5.40 B 5.49 5.71 80 400 15 40 1 2.0 -2.0 2.5 170 C 5.20 6.00 B 6.08 6.32 40 150 6 10 3 4.0 0.4 3.7 120 C 5.80 6.60 B 6.66 6.94 30 80 6 15 2 4.0 1.2 4.5 120 C 6.40 7.20 B 7.35 7.65 30 80 6 15 1 5.0 2.5 5.3 150 C 7.00 7.90 B 8.04 8.36 40 80 6 15 0.7 5.0 3.2 6.2 150 C 7.70 8.70 B 8.92 9.28 40 100 6 15 0.5 6.0 3.8 7.0 150 C 8.50 9.60 B 9.80 10.20 50 150 8 20 0.2 7.0 4.5 8.0 90 C 9.40 10.60 B 10.80 11.20 50 150 10 20 0.1 8.0 5.4 9.0 85 C 10.40 11.60 B 11.80 12.20 50 150 10 25 0.1 8.0 6.0 10.0 85 C 11.40 12.70 B 12.70 13.30 50 170 10 30 0.1 8.0 7.0 11.0 80 C 12.40 14.10 BZX884S_SER Product data sheet Reverse current IR (μA) Diode capacitance Cd (pF) [1] IZ = 5 mA All information provided in this document is subject to legal disclaimers. Rev. 4 — 9 February 2021 Temperature coefficient SZ (mV/K) © Nexperia B.V. 2021. All rights reserved 4 / 14 BZX884S series Nexperia Voltage regulator diodes BZX884S 15 16 18 20 22 24 [1] Sel Working voltage VZ (V) Differential resistance rdif (Ω) Reverse current IR (μA) Temperature coefficient SZ (mV/K) Diode capacitance Cd (pF) [1] IZ = 5 mA IZ = 1 mA IZ = 5 mA Min Max Typ Max Typ Max Max VR (V) Min Max Max B 14.70 15.30 50 200 10 30 0.05 10.5 9.2 13.0 75 C 13.80 15.60 B 15.70 16.30 50 200 10 40 0.05 11.2 10.4 14.0 75 C 15.30 17.10 B 17.60 18.40 50 225 10 45 0.05 12.6 12.4 16.0 70 C 16.80 19.10 B 19.60 20.40 60 225 15 55 0.05 14.0 14.4 18.0 60 C 18.80 21.20 B 21.60 22.40 60 250 20 55 0.05 15.4 16.4 20.0 60 C 20.80 23.30 B 23.50 24.50 60 250 25 70 0.05 16.8 18.4 22.0 55 C 22.80 25.60 IZ = 5 mA f = 1 MHz; VR = 0 V BZX884S_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 9 February 2021 © Nexperia B.V. 2021. All rights reserved 5 / 14 BZX884S series Nexperia Voltage regulator diodes Table 9. Characteristics per type; BZX884S-B27 to BZX884S-C75 Tj = 25 °C unless otherwise specified. BZX884S 27 30 33 36 39 43 47 51 56 62 68 75 [1] Sel Working voltage VZ (V) Differential resistance rdif (Ω) Reverse current IR (μA) Temperature coefficient SZ (mV/K) Diode capacitance Cd (pF) [1] IZ = 2 mA IZ = 0.5 mA IZ = 2 mA Min Max Typ Max Typ Max Max VR (V) Min Max Max B 26.50 27.50 65 300 25 80 0.05 18.9 21.4 25.3 50 C 25.10 28.90 B 29.40 30.60 70 300 30 80 0.05 21.0 24.4 29.4 50 C 28.00 32.00 B 32.30 33.70 75 325 35 80 0.05 23.1 27.4 33.4 45 C 31.00 35.00 B 35.30 36.70 80 350 35 90 0.05 25.2 30.4 37.4 45 C 34.00 38.00 B 38.20 39.80 80 350 40 130 0.05 27.3 33.4 41.2 45 C 37.00 41.00 B 42.10 43.90 85 375 45 150 0.05 30.1 37.6 46.6 40 C 40.00 46.00 B 46.10 47.90 85 375 50 170 0.05 32.9 42 51.8 40 C 44.00 50.00 B 50.00 52.00 90 400 60 180 0.05 35.7 46.6 57.2 40 C 48.00 54.00 B 54.90 57.10 100 425 70 200 0.05 39.2 52.2 63.8 40 C 52.00 60.00 B 60.80 63.20 120 450 80 215 0.05 43.4 58.8 71.6 35 C 58.00 66.00 B 66.60 69.40 150 475 90 240 0.05 47.6 65.6 79.8 35 C 64.00 72.00 B 73.50 76.50 170 500 95 255 0.05 52.5 73.4 88.6 35 C 70.00 79.00 IZ = 2 mA f = 1 MHz; VR = 0 V BZX884S_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 9 February 2021 © Nexperia B.V. 2021. All rights reserved 6 / 14 BZX884S series Nexperia Voltage regulator diodes aaa-028550 103 IF (mA) 102 10 10 1 1 10-1 10-1 10-2 10-2 10-3 0.4 0.6 0.8 VF (V) 1.0 10-3 0.4 Tj = 25 °C Fig. 1. aaa-028552 103 IF (mA) 102 Fig. 2. 1 1 10-1 10-1 10-2 10-2 0.6 0.8 VF (V) 1.0 10-3 0.4 Tj = 25 °C 1.0 aaa-028553 0.6 0.8 VF (V) 1.0 Tj = 25 °C Forward current as a function of forward voltage; typical values (BZX884S-B/C7V5) Product data sheet VF (V) 103 IF (mA) 102 10 BZX884S_SER 0.8 Forward current as a function of forward voltage; typical values (BZX884S-B/C6V8) 10 Fig. 3. 0.6 Tj = 25 °C Forward current as a function of forward voltage; typical values (BZX884S-B/C2V4) 10-3 0.4 aaa-028551 103 IF (mA) 102 Fig. 4. Forward current as a function of forward voltage; typical values (BZX884S-B/C75) All information provided in this document is subject to legal disclaimers. Rev. 4 — 9 February 2021 © Nexperia B.V. 2021. All rights reserved 7 / 14 BZX884S series Nexperia Voltage regulator diodes mld444 0.5 SZ (mV/K) mld445 12 15 SZ (mV/K) 4V7 0 13 12 11 10 9V1 8V2 7V5 6V8 6V2 5V6 5V1 8 4V3 - 0.5 2V4 4 2V7 3V9 -1 3V6 - 1.5 0 3V3 3V0 -2 10- 1 1 10 IZ (mA) -4 10- 1 102 Tj = 25 °C to 150 °C Fig. 5. IR (A) Fig. 6. aaa-006665 2V4 10-2 2V7 10-3 3V0 3V3 10 IZ (mA) 102 Tj = 25 °C to 150 °C Temperature coefficient as a function of working current; typical values (BZX884S-B/C2V4 to B/C4V7) 10-1 1 3V6 3V9 4V3 4V7 5V1 IR (A) Temperature coefficient as a function of working current; typical values (BZX884S-B/C5V1 to B/C15) aaa-006666 10-1 7V5 10-2 10 12 15 18 22 8V2 10-3 10-4 9V1 11 13 16 20 24 10-4 10-5 5V6 10-6 6V2 10-5 6V8 10-6 10-7 10-7 10-8 10-9 0 2 4 6 VR (V) 8 10-8 Tj = 25 °C Fig. 7. Product data sheet 5 10 15 20 VR (V) 25 Tj = 25 °C Reverse current as a function of reverse voltage; typical values (BZX884S-B/C2V4 to BZX884S-B/C6V8) BZX884S_SER 0 Fig. 8. Reverse current as a function of reverse voltage; typical values (BZX884S-B/C7V5 to BZX884S-B/C24) All information provided in this document is subject to legal disclaimers. Rev. 4 — 9 February 2021 © Nexperia B.V. 2021. All rights reserved 8 / 14 BZX884S series Nexperia Voltage regulator diodes IR (A) aaa-006667 10-1 30 36 10-2 27 33 43 39 51 47 62 56 75 68 10-3 10-4 10-5 10-6 10-7 10-8 10-9 20 40 60 VR (V) 80 Tj = 25 °C Fig. 9. Reverse current as a function of reverse voltage; typical values (BZX884S-B/C27 to BZX884S-B/C75) BZX884S_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 9 February 2021 © Nexperia B.V. 2021. All rights reserved 9 / 14 BZX884S series Nexperia Voltage regulator diodes 11. Package outline DFN1006BD-2 Leadless ultra small plastic package with side-wettable flanks (SWF); 2 terminals; 0.65 mm pitch; 1 mm x 0.6 mm x 0.47 mm body SOD882BD L (2x) T 1 2 b (2x) bf (2x) v w e C A B C y1 C A A1 C SEATING PLANE y C E A u C D (3) (3) (2) u C B 0 0.5 Dimensions A(1) A1 0.50 0.47 0.44 0.04 Unit max nom min mm 1 mm scale bf(1) b D E e L T(1) 0.55 0.30 0.22 0.50 0.60 1.00 0.65 0.25 0.16 0.20 0.45 0.22 0.10 u v 0.05 0.10 w y y1 0.05 0.05 0.05 Note 1. Dimension including plating thickness. 2. The marking bar indicates the cathode. 3. Solderable lead end, protrusion max. 0.02 mm. Outline version sod882bd_po References IEC SOD882BD JEDEC JEITA European projection Issue date 20-06-22 20-06-23 MO-343AA Fig. 10. Package outline SOD882BD BZX884S_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 9 February 2021 © Nexperia B.V. 2021. All rights reserved 10 / 14 BZX884S series Nexperia Voltage regulator diodes 12. Soldering Footprint information for reflow soldering of DFN1006BD-2 package SOD882BD 1.4 0.2 0.8 (2×) 0.6 (2×) 0.7 (2×) 0.3 0.4 1.0 1.3 solder resist solder paste solder lands Dimensions in mm Issue date 20-05-01 20-12-15 sod882bd_fr Reflow soldering is the only recommended soldering method. Dimensions in mm. Fig. 11. Reflow soldering footprint SOD882BD BZX884S_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 9 February 2021 © Nexperia B.V. 2021. All rights reserved 11 / 14 BZX884S series Nexperia Voltage regulator diodes 13. Revision history Table 10. Revision history Document ID Release date Data sheet status Change notice Supersedes BZX884S_SER v.4 20210209 Product data sheet - • BZX884S_SER v.3 Changed to non-automotive. Please refer to the automotive product(s) with -Q. BZX884S_SER v.3 20210210 Modifications: • • BZX884S_SER v.2 20201215 Product data sheet - BZX884S_SER v.1 BZX884S_SER v.1 20200713 Product data sheet - - BZX884S_SER Product data sheet Product data sheet - BZX884S_SER v.2 Diode capacitance improved: BZX884S-B2V4 to BZX884S-C6V8 Data sheet changed to non-automotive All information provided in this document is subject to legal disclaimers. Rev. 4 — 9 February 2021 © Nexperia B.V. 2021. All rights reserved 12 / 14 BZX884S series Nexperia Voltage regulator diodes 14. Legal information injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Data sheet status Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Document status [1][2] Product status [3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the internet at https://www.nexperia.com. Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal BZX884S_SER Product data sheet Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. All information provided in this document is subject to legal disclaimers. Rev. 4 — 9 February 2021 © Nexperia B.V. 2021. All rights reserved 13 / 14 BZX884S series Nexperia Voltage regulator diodes Contents 1. General description...................................................... 1 2. Features and benefits.................................................. 1 3. Applications.................................................................. 1 4. Quick reference data....................................................1 5. Pinning information......................................................1 6. Ordering information....................................................2 7. Marking.......................................................................... 2 8. Limiting values............................................................. 3 9. Thermal characteristics............................................... 3 10. Characteristics............................................................ 3 11. Package outline........................................................ 10 12. Soldering................................................................... 11 13. Revision history........................................................12 14. Legal information......................................................13 © Nexperia B.V. 2021. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 9 February 2021 BZX884S_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 9 February 2021 © Nexperia B.V. 2021. All rights reserved 14 / 14
BZX884S-B7V5YL
物料型号:BZX884S系列
器件简介:这是一款通用的齐纳二极管,采用超小型无引脚SOD882BD (DFN1006BD-2)表面贴装器件(SMD)塑料封装,两侧可湿。
引脚分配:有两个引脚,分别为: - 1号引脚(K):阴极 - 2号引脚(A):阳极
参数特性: - 工作电压范围宽广,从2.4V至75V(E24系列)。 - 两种容差系列:±2%和大约±5%。 - 正向电压(VF)在10mA时的典型值未给出,但提供了最大值。 - 总功耗(Ptot)在特定条件下的最大值为365mW。
功能详解: - 用于一般调节功能。
应用信息: - 适用于一般调节功能。
封装信息: - 封装类型为DFN1006BD-2,是一种无引脚超小型塑料封装,具有两侧可湿的侧壁(SWF)。 - 引脚间距为0.65mm,封装尺寸为1mm x 0.6mm x 0.47mm。
BZX884S-B7V5YL 价格&库存
很抱歉,暂时无法提供与“BZX884S-B7V5YL”相匹配的价格&库存,您可以联系我们找货
BZX884S-B7V5YL
  • 30000+0.2822330000+0.03654
