RS2D R5G
RS2D R5G
    TAIWANSEMICONDUCTOR(台湾半导体)
    DO214AA
    DIODE GEN PURP 200V 2A DO214AA
RS2D R5G 数据手册
RS2A – RS2M Taiwan Semiconductor 2A, 50V - 1000V Fast Recovery Surface Mount Rectifier FEATURES ● ● ● ● ● ● ● KEY PARAMETERS Low power loss, high efficiency Ideal for automated placement Glass passivated chip junction Fast switching for high efficiency Moisture sensitivity level: level 1, per J-STD-020 RoHS Compliant Halogen-free according to IEC 61249-2-21 APPLICATIONS ● ● ● ● PARAMETER VALUE UNIT IF 2 A VRRM 50 - 1000 V IFSM 50 A TJ MAX 150 °C Package DO-214AA (SMB) Configuration Single die Switching mode power supply (SMPS) Adapters Lighting application Converter MECHANICAL DATA ● ● ● ● ● ● Case: DO-214AA (SMB) Molding compound meets UL 94V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Meet JESD 201 class 2 whisker test Polarity: Indicated by cathode band Weight: 0.090g (approximately) DO-214AA (SMB) ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER SYMBOL RS2A RS2B RS2D RS2G RS2J RS2K RS2M UNIT Marking code on the device RS2A RS2B RS2D RS2G RS2J RS2K RS2M Repetitive peak reverse voltage VRRM 50 100 200 400 600 800 1000 V Reverse voltage, total rms value VR(RMS) 35 70 140 280 420 560 700 V Forward current Surge peak forward current, 8.3ms single half sine-wave superimposed on rated load Junction temperature IF 2 A IFSM 50 A TJ - 55 to +150 °C Storage temperature TSTG - 55 to +150 °C 1 Version: K2102 RS2A – RS2M Taiwan Semiconductor THERMAL PERFORMANCE PARAMETER SYMBOL TYP UNIT Junction-to-ambient thermal resistance RӨJA 55 °C/W Junction-to-lead thermal resistance RӨJL 18 °C/W ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER Forward voltage CONDITIONS (1) Reverse current @ rated VR IF = 2A, TJ = 25°C TJ = 25°C (2) TYP MAX UNIT VF - 1.3 V - 5 µA - 50 µA 50 - pF - 150 ns - 250 ns - 500 ns IR TJ = 125°C Junction capacitance SYMBOL 1MHz, VR = 4.0V CJ RS2A RS2B RS2D Reverse recovery time RS2G RS2J IF = 0.5A, IR = 1.0A Irr = 0.25A RS2K RS2M trr Notes: 1. Pulse test with PW = 0.3ms 2. Pulse test with PW = 30ms ORDERING INFORMATION ORDERING CODE(1) PACKAGE PACKING RS2x DO-214AA (SMB) 3,000 / Tape & Reel Notes: 1. "x" defines voltage from 50V(RS2A) to 1000V(RS2M) 2 Version: K2102 RS2A – RS2M Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Forward Current Derating Curve Fig.2 Typical Junction Capacitance 100 2 CAPACITANCE (pF) AVERAGE FORWARD CURRENT (A) 2.5 1.5 1 0.5 f=1.0MHz Vsig=50mVp-p 0 0 25 50 75 100 125 10 150 1 10 LEAD TEMPERATURE (°C) Fig.4 Typical Forward Characteristics TJ=125°C 10 1 TJ=25°C 0.1 30 40 50 60 70 80 90 100 10 10 TJ=125°C 1 TJ=25°C 0.1 0.01 0.001 0.3 0.1 0.6 PERCENT OF RATED PEAK REVERSE VOLTAGE (%) UF1DLW 1 (A) 100 INSTANTANEOUS FORWARD CURRENT (A) INSTANTANEOUS REVERSE CURRENT (µA) Fig.3 Typical Reverse Characteristics 20 100 REVERSE VOLTAGE (V) 0.4 0.8 0.5 0.6 1 Pulse width Pulse Width=300μs 1% Duty Cycle 0.7 0.8 0.9 1 1.1 1.2 1.4 1.6 FORWARD VOLTAGE (V) 3 Version: K2102 1.2 RS2A – RS2M Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.5 Maximum Non-Repetitive Forward Surge Current PEAK FORWARD SURGE CURRENT (A) 60 8.3ms single half sine wave 50 40 30 20 10 0 1 10 100 NUMBER OF CYCLES AT 60 Hz Fig.6 Reverse Recovery Time Characteristic and Test Circuit Diagram 4 Version: K2102 RS2A – RS2M Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS DO-214AA (SMB) SUGGESTED PAD LAYOUT MARKING DIAGRAM 5 P/N = Marking Code G = Green Compound YW = Date Code F = Factory Code Version: K2102 RS2A – RS2M Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 6 Version: K2102
RS2D R5G 价格&库存
很抱歉,暂时无法提供与“RS2D R5G”相匹配的价格&库存,您可以联系我们找货
