BAT54SW RVG
BAT54SW RVG
    TAIWANSEMICONDUCTOR(台湾半导体)
    SOT-323-3
    DIODE SCHOTTKY 30V 200MA SOT323
BAT54SW RVG 数据手册
BAT54W/AW/CW/SW Taiwan Semiconductor 200mA, 30V Schottky Barrier Diode FEATURES ● ● ● ● ● ● ● ● ● ● KEY PARAMETERS Fast switching speed Low forward voltage Surface mount device type Ultra high-speed switching Voltage clamping Protection circuits High temperature soldering guaranteed: 260°C/10s Moisture sensitivity level: level 1, per J-STD-020 RoHS Compliant Halogen-free according to IEC 61249-2-21 PARAMETER VALUE UNIT IF 200 mA VRRM 30 V IFSM 600 mA TJ MAX 125 °C Package SOT-323 APPLICATIONS ● Voltage clamping ● Ultra high-speed switching ● Reverse polarity protection SOT-323 MECHANICAL DATA ● Case: SOT-323 ● Weight: 5.00mg (approximately) ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER SYMBOL VALUE UNIT VRRM 30 V Forward current IF 200 mA Power dissipation PD 200 mW Peak Forward Surge Current (tp = 10ms) IFSM 600 mA Repetitive Peak Forward Current IFRM 300 mA Junction temperature TJ 125 °C Storage temperature TSTG -55 to +150 °C Repetitive peak reverse voltage 1 Version: D2102 BAT54W/AW/CW/SW Taiwan Semiconductor THERMAL PERFORMANCE PARAMETER SYMBOL TYP UNIT RӨJA 625 °C/W Junction-to-ambient thermal resistance ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER CONDITIONS Forward Voltage SYMBOL TYP MAX UNIT IF = 0.1mA - 240 mV IF = 1.0mA - 320 mV - 400 mV IF = 30mA - 500 mV IF = 100mA - 1000 mV IF = 10mA VF Reverse current VR = 25V IR - 2 uA Junction capacitance VR = 1V, f = 1.0MHz IF = 10 mA through IR = 10mA to IR = 1mA, RL = 100 Ω CJ - 10 pF trr - 5 ns Reverse Recovery Time ORDERING AND MARKING INFORMATION ORDERING CODE(1) MARKING PACKAGE PACKING BAT54W RFG L4 SOT-323 3K / 7" Reel BAT54AW RFG L42 SOT-323 3K / 7" Reel BAT54CW RFG L43 SOT-323 3K / 7" Reel BAT54SW RFG L44 SOT-323 3K / 7" Reel BAT54W-B0 RFG L4 SOT-323 3K / 7" Reel BAT54AW-B0 RFG L42 SOT-323 3K / 7" Reel BAT54CW-B0 RFG L43 SOT-323 3K / 7" Reel BAT54SW-B0 RFG L44 SOT-323 3K / 7" Reel Notes: 1. “G” means green compound (halogen free) 2 Version: D2102 BAT54W/AW/CW/SW Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.2 Typical Reverse Characteristics 100 1 0.1 0.01 REVERSE CURRENT (µA) INSTANTANEOUS FORWARD CURRENT (A) Fig.1 Typical Forward Characteristics 125oC 75oC 25oC 0oC -40oC 0.001 0.0001 10 125°C 1 75oC 25oC 0.1 0oC 0.01 0.001 0 0.2 0.4 0.6 0.8 1 0 5 INSTANTANEOUS FORWARD VOLTAGE (V) JUNCTION CAPACITANCE (pF) POWER DISSIPATION (mW) 200 150 100 50 0 50 75 100 20 25 30 Fig.4 Typical Junction Capacitance 250 25 15 REVERSE VOLTAGE (V) Fig.3 Power Dissipation Curve 0 10 125 12 11 10 9 8 7 6 5 4 3 2 1 0 0 AMBIENT TEMPERATURE (°C) 5 10 15 20 25 30 REVERSE VOLTAGE (V) 3 Version: D2102 BAT54W/AW/CW/SW Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS SOT-323 SUGGESTED PAD LAYOUT PIN CONFIGURATION 4 Version: D2102 BAT54W/AW/CW/SW Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 5 Version: D2102
BAT54SW RVG 价格&库存
很抱歉,暂时无法提供与“BAT54SW RVG”相匹配的价格&库存,您可以联系我们找货
