TSOD1F1HM RVG
TSOD1F1HM RVG
    TAIWANSEMICONDUCTOR(台湾半导体)
    SOD-123F
    DIODE GEN PURP 100V 1A SOD123FL
TSOD1F1HM RVG 数据手册
TSOD1F1HM - TSOD1F10HM Taiwan Semiconductor Small Signal Product 1A, 100V - 1000V Surface Mount Rectifiers FEATURES - Glass passivated devices - Ideal for surface mounted applications - Low leakage current - Metallurgical bonded construction - Compliant to RoHS Directive 2011/65/EU and in accordance to WEEE 2002/96/EC SOD-123FL - Halogen-free according to IEC 61249-2-21 - Packing code with suffix "G" means green compound (halogen-free) MECHANICAL DATA me nd ed - Case: JEDEC SOD-123FL, molded plastic over passivated chip - Terminals: Solder Plated, solderable per MIL-STD-750, Method 2026 - Weight: 21 ± 0.5mg MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS (TA=25°C unless otherwise noted) PARAMETER SYMBOL Device marking code TSOD1F TSOD1F TSOD1F TSOD1F TSOD1F TSOD1F 1HM Maximum RMS voltage Maximum DC blocking voltage 4HM 6HM 8HM 10HM UNIT FD FG FJ FK FM VRRM 100 200 400 600 800 1000 V VRMS 70 140 280 420 560 700 V VDC 100 200 400 600 800 1000 V eco m FB Maximum recurrent peak reverse voltage 2HM I(AV) 1 A Peak forward surge current 8.3ms single half sine wave superimposed on rated load IFSM 25 A Maximum instantaneous forward voltage at 1A (Note 2) VF 1.3 V TA=25°C TA=125°C No Maximum DC reverse current at rated DC blocking voltage tR Maximum average forward rectified current (Note 1) 5 IR μA 50 Maximum reverse recovery time (Note 3) trr Typical junction capacitance (Note 4) CJ 4 pF RθJA 180 K/W TJ , TSTG -55 to +150 °C Typical thermal resistance (Note 5) Junction and Storage Temperature Range 150 250 500 ns Note 1: Averaged over any 20ms period. Note 2: Pulse test: 300μs pulse width, 1% duty cycle. Note 3: Measured with IF=0.5A, IR=1A, Irr=0.25A Note 4: Measured at 1.0MHz and applied average voltage of 4.0V DC. Note 5: Thermal resistance junction to ambient, 6.0 mm2 copper pads to each terminal. Version: B1606 TSOD1F1HM - TSOD1F10HM Taiwan Semiconductor Small Signal Product RATINGS AND CHARACTERISTICS CURVES (TA=25°C unless otherwise noted) Fig. 1 FORWARD DERATING CURVE Fig. 2 TYPICAL FORWARD CHARACTERISTICS 100 FORWARD CURRENT (A) 1 0.8 0.6 0.4 0.2 0 1 0.1 Fig.2 Pulse Width=300μs 1% Duty Cycle 0.01 0 30 60 90 120 150 AMBIENT TEMPERATURE (°C) 0.6 0.7 0.8 0.9 1.0 1.1 1.2 1.3 1.4 1.5 1.6 FORWARD VOLTAGE (V) Fig. 3 TYPICAL REVERSE CHARACTERISTICS Fig. 3 eco m Fig. 4 TYPICAL JUNCTION CAPACITANCE 100 10 9 8 tR 10 TJ=125°C 1 No INSTANTANEOUS REVERSE CURRENT (μA) 10 me nd ed RESISTIVE OR INDUCTIVE LOAD 0.1 0 20 40 60 80 100 120 PERCENT OF RATED PEAK REVERSE VOLTAGE (%) 7 6 5 4 3 2 1 TJ=25°C 0.01 CAPACITANCE (pF) AVERAGE FORWARD CURRENT (A) 1.2 0 140 0 5 10 15 20 25 30 35 40 REVERSE VOLTAGE (V) Version: B1606 TSOD1F1HM - TSOD1F10HM Taiwan Semiconductor Small Signal Product ORDERING INFORMATION PART NO. PACKING CODE TSOD1FxHM (Note 1, 2) R4 PACKING CODE SUFFIX G PACKAGE PACKING SOD-123FL 10,000 / 13" reel Note 1: "x" defines voltage from 100V (TSOD1F1HM) to 1000V (TSOD1F10HM) Note 2: Whole series with green compound EXAMPLE PREFERRED P/N PART NO. PACKING CODE TSOD1F1HM R4G TSOD1F1HM R4 PACKING CODE DESCRIPTION SUFFIX G Green compound PACKAGE OUTLINE DIMENSIONS me nd ed SOD-123FL DIM. Unit (mm) Min Max Unit (inch) Min Max 3.45 3.95 0.136 0.156 B 2.60 3.10 0.102 0.122 C 1.70 2.10 0.067 0.083 D 0.80 1.15 0.031 0.045 E 0.30 0.90 0.012 0.035 eco m A 0.10 0.30 0.004 0.012 0.88 1.35 0.035 0.053 No tR F G SUGGEST PAD LAYOUT DIM. Unit (mm) Unit (inch) Typ. Typ. C 4.00 0.157 G 3.00 0.118 X 1.20 0.047 X1 4.90 0.193 Y 1.20 0.047 Version: B1606 TSOD1F1HM - TSOD1F10HM Taiwan Semiconductor No tR eco m me nd ed Small Signal Product Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC's terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. Version: B1606
TSOD1F1HM RVG 价格&库存
很抱歉,暂时无法提供与“TSOD1F1HM RVG”相匹配的价格&库存,您可以联系我们找货
