FR107GTA
FR107GTA
    SMCDIODESOLUTIONS(桑德斯)
    DO-204AL
    DIODE GPP 1KV 1A DO41
FR107GTA 数据手册
FR101G-FR107G Technical Data Data Sheet N0442, Rev. A FR101G THRU FR107G FAST RECOVERY GLASS PASSIVATED RECTIFIERS Reverse Voltage - 50 to 1000 Volts Forward Current - 1.0 Amperes Features The plastic package carries Underwriters Laboratory Flammability Classification 94V-0 Fast switching for high efficiency Low reverse leakage High forward surge current capability High temperature soldering guaranteed: 260 C/10 seconds,0.375”(9.5mm) lead length, 5 lbs. (2.3kg) tension Glass passivated chip junction This is a Pb − Free Device All SMC parts are traceable to the wafer lot Additional testing can be offered upon request          DO-41 Circuit Diagram Mechanical Data Case: JEDEC DO-41 molded plastic body Terminals: Plated axial leads, solderable per MIL-STD-202, Method 208 Polarity: Color band denotes cathode end Mounting Position: Any Weight: 0.34 grams       Maximum Ratings and Electrical Characteristics @TA=25°C unless otherwise specified Characteristic Symbol FR FR FR 101G 102G 103G FR 104G FR 105G 5 100 3 70 2 400 1 280 4 600 2 420 VRRM VDC Maximum RMS voltage VRMS Maximum average forward rectified current 0.375”(9.5mm) lead length at @TA =55°C I(AV) 1.0 A Peak forward surge current 8.3ms single half sinewave superimposed on rated load (JEDEC Method) IFSM 30 A Maximum instantaneous forward voltage at 1.0A VF 1.3 V Maximum DC reverse current At Rated DC Blocking Voltage IRM 5.0 100 µA @TA = 25°C @TA = 100°C 35 250 8 1000 5 700 1 V trr Typical Junction Capacitance (Note 2) CJ 15 pF Typical Thermal Resistance Junction to Ambient (Note 3) RθJA 40 °C/W TJ, TSTG -65 to +150 °C Note: 1. Reverse recovery condition IF=0.5A, IR=1.0A, Irr=0.25A 2. Measured at 1MHz and applied reverse voltage of 4.0V D.C. 3. Thermal resistance from junction to ambient at 0.375”(9.5mm)lead length, P.C.B. mounted  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  500 1 V Maximum reverse recovery time (Note 1) Operating junction and storage temperature range 150 6 800 4 560 Units Maximum repetitive peak reverse voltage Maximum DC blocking voltage 50 1 200 7 140 FR FR 106G 107G ns FR101G-FR107G Technical Data Data Sheet N0442, Rev. A Ratings and Characteristics Curves  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  FR101G-FR107G Technical Data Data Sheet N0442, Rev. A Mechanical Dimensions DO-41 SYMBOL Ordering Information Device FR101G-FR107G Package DO-41 (Pb-Free) Millimeters Inches Min. Max. Min. Max. A 25.4 - 1.000 - B 4.06 5.21 0.160 0.205 C 0.71 0.864 0.028 0.034 D 2.00 2.72 0.079 0.107 Marking Diagram Shipping Where XXXXX is YYWWL FR101G SSG YY WW L 5000pcs / tape For information on tape and reel specifications, including part orientation and tape sizes, please refer to our tape and reel packaging specification. = Part Name = SSG = Year = Week = Lot Number Cautions:Molding resin Epoxy resin UL:94V-0 Carrier Tape Specification DO-41 SYMBOL Millimeters Min. Max. A 4.50 5.50 B 50.9 53.9 Z - 1.20 T 5.60 6.40 E - 0.80 IL1-L2I - 1.0  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  FR101G-FR107G Technical Data Data Sheet N0442, Rev. A DISCLAIMER: 1- The information given herein, including the specifications and dimensions, is subject to change without prior notice to improve product characteristics. Before ordering, purchasers are advised to contact the SMC - Sangdest Microelectronics (Nanjing) Co., Ltd sales department for the latest version of the datasheet(s). 2- In cases where extremely high reliability is required (such as use in nuclear power control, aerospace and aviation, traffic equipment, medical equipment , and safety equipment) , safety should be ensured by using semiconductor devices that feature assured safety or by means of users’ fail-safe precautions or other arrangement . 3- In no event shall SMC - Sangdest Microelectronics (Nanjing) Co., Ltd be liable for any damages that may result from an accident or any other cause during operation of the user’s units according to the datasheet(s). SMC - Sangdest Microelectronics (Nanjing) Co., Ltd assumes no responsibility for any intellectual property claims or any other problems that may result from applications of information, products or circuits described in the datasheets. 4- In no event shall SMC - Sangdest Microelectronics (Nanjing) Co., Ltd be liable for any failure in a semiconductor device or any secondary damage resulting from use at a value exceeding the absolute maximum rating. 5- No license is granted by the datasheet(s) under any patents or other rights of any third party or SMC - Sangdest Microelectronics (Nanjing) Co., Ltd. 6- The datasheet(s) may not be reproduced or duplicated, in any form, in whole or part, without the expressed written permission of SMC - Sangdest Microelectronics (Nanjing) Co., Ltd. 7- The products (technologies) described in the datasheet(s) are not to be provided to any party whose purpose in their application will hinder maintenance of international peace and safety nor are they to be applied to that purpose by their direct purchasers or any third party. When exporting these products (technologies), the necessary procedures are to be taken in accordance with related laws and regulations..  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com 
FR107GTA 价格&库存
很抱歉,暂时无法提供与“FR107GTA”相匹配的价格&库存,您可以联系我们找货
FR107GTA
