B0530WS
Taiwan Semiconductor
200mW, 0.47V Schottky Barrier Diode
FEATURES
KEY PARAMETERS
PARAMETER
VALUE
UNIT
IF(AV)
500
mA
VRRM
30
V
IFSM
5
A
VF at IF=500mA
0.47
V
APPLICATIONS
TJ Max.
125
°C
Package
SOD-323F
Configuration
Single dice
Designed for mounting on small surface
Low Capacitance
Low forward voltage drop
Compliant to RoHS directive 2011/65/EU and
in accordance to WEEE 2002/96/EC
● Halogen-free according to IEC 61249-2-21
Adapters
For switching power supply
Low stored charge
Inverter
MECHANICAL DATA
Case: SOD-323F
Molding compound meets UL 94 V-0 flammability rating
Moisture sensitivity level: level 1, per J-STD-020
Packing code with suffix "G" means green compound
(halogen-free)
Terminal: Matte tin plated leads, solderable per J-STD-002
Meet JESD 201 class 1A whisker test
Polarity: Indicated by cathode band
Weight: 4.85 mg (approximately)
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
Marking code on the device
SYMBOL
B0530WS
UNIT
B3
Repetitive peak reverse voltage
VRRM
IF(AV)
IFSM
30
200
5
V
mA
A
Junction temperature range
TJ
-65 to +125
°C
Storage temperature range
TSTG
-65 to +125
°C
SYMBOL
LIMIT
UNIT
RӨJA
426
°C/W
Forward current
Non-repetitive peak forward surge current @ t = 8.3ms
THERMAL PERFORMANCE
PARAMETER
Junction-to-ambient thermal resistance
1
Version:J1709
B0530WS
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
CONDITIONS
Forward voltage per diode
TYP
VF
IR
100
500
160
IF = 100mA, TJ = 25°C
(1)
IF = 500mA, TJ = 25°C
VR=15V TJ = 25°C
Reverse current @ rated VR per
diode
SYMBOL
VR=20V TJ = 25°C
(2)
VR=30V TJ = 25°C
1 MHz, VR=0V
Junction capacitance
CJ
MAX
UNIT
0.36
0.47
V
80
μA
pF
Notes:
1. Pulse test with PW=0.3 ms
2. Pulse test with PW=30 ms
ORDERING INFORMATION
PART NO.
PACKING
PACKING CODE
CODE
SUFFIX
B0530WS
RR
(Note 1)
R9
PACKAGE
PACKING
3K / 7" Reel
G
SOD-323F
10K / 13" Reel
Notes:
1. Whole series with green compound
EXAMPLE
EXAMPLE P/N
PART NO.
PACKING CODE
B0530WS RRG
B0530WS
RR
PACKING CODE
SUFFIX
G
2
DESCRIPTION
Green compound
Version:J1709
B0530WS
CHARACTERISTICS CURVES
Fig. 1 Typical Forward Characteristics
Fig. 2 Forward Current Derating Curve
1
Io: Mean Forward Current (A)
Instantaneous Forward Current (A)
10
1
0.1
0.75
0.5
0.25
0.01
0.2
0.4
0.6
0.8
1.0
1.2
1.4
1.6
75
100
125
150
Terminal Temperature (°C)
Instantaneous Forward Voltage (V)
Fig. 3 Admissible Power Dissipation Curve
Fig. 4 Typical Junction Capacitance
70
250
60
Junction Capacitance (pF)
200
Power Dissipation (mW)
50
150
100
50
50
40
30
50
75
100
125
150
10
15
o
Ambient Temperature ( C)
Reverse Voltage (V)
3
Version:J1709
B0530WS
Fig. 5 Typical Reverse Characteristics
Reverse Current (mA)
100
10
1
0.1
0.01
Reverse Voltage (V)
4
Version:J1709
B0530WS
PACKAGE OUTLINE DIMENSION
SOD-323F
DIM.
5
Unit(mm)
Unit(inch)
Min
Max
Min
Max
A
1.15
1.35
0.045
0.053
B
2.30
2.80
0.091
0.110
C
0.25
0.40
0.010
0.016
D
1.60
1.80
0.063
0.071
E
0.80
1.10
0.031
0.043
F
0.05
0.25
0.002
0.010
Version:J1709
B0530WS
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf,
assumes no responsibility or liability for any errors or inaccuracies.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
6
Version:J1709
很抱歉,暂时无法提供与“B0530WS RRG”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+2.829581+0.36576
- 10+1.7393910+0.22484
- 100+1.08699100+0.14051
- 500+0.80160500+0.10362
- 1000+0.709221000+0.09168
- 国内价格 香港价格
- 3000+0.591563000+0.07647
- 6000+0.532166000+0.06879
- 9000+0.501869000+0.06487
- 15000+0.4678015000+0.06047
- 21000+0.4476121000+0.05786
- 30000+0.4279930000+0.05533
- 国内价格 香港价格
- 1+1.707321+0.22069
- 10+1.1399610+0.14736
- 100+0.70199100+0.09074
- 500+0.50704500+0.06554
- 1000+0.443221000+0.05730
- 3000+0.363673000+0.04701
- 6000+0.322586000+0.04170
- 9000+0.312099000+0.04035
- 国内价格 香港价格
- 3000+0.673843000+0.08710
- 6000+0.471056000+0.06089
- 9000+0.458289000+0.05924
- 15000+0.4335315000+0.05604
- 21000+0.4143721000+0.05356
- 30000+0.3632730000+0.04696
- 国内价格
- 1+1.58768
- 10+1.06029
- 100+0.65268
- 500+0.47169
- 1000+0.41228
- 3000+0.33802
- 6000+0.29993
- 9000+0.29059
