ES2DA R3G
ES2DA R3G
    TAIWANSEMICONDUCTOR(台湾半导体)
    DO-214AC
    DIODE GEN PURP 200V 2A DO214AC
ES2DA R3G 数据手册
ES2AA – ES2JA Taiwan Semiconductor 2A, 50V - 600V Super Fast Surface Mount Rectifier FEATURES ● ● ● ● ● ● ● KEY PARAMETERS Glass passivated chip junction Ideal for automated placement Low profile package Super fast recovery time for high efficiency Moisture sensitivity level: level 1, per J-STD-020 RoHS Compliant Halogen-free according to IEC 61249-2-21 PARAMETER VALUE UNIT IF 2 A VRRM 50 - 600 V IFSM 50 A TJ MAX 150 °C APPLICATIONS ● ● ● ● ● Package DO-214AC (SMA) Configuration Single die DC to DC converter Switching mode converters and inverters Lighting application Snubber Freewheeling application MECHANICAL DATA ● ● ● ● ● ● Case: DO-214AC (SMA) Molding compound meets UL 94V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Meet JESD 201 class 2 whisker test Polarity: Indicated by cathode band Weight: 0.060g (approximately) DO-214AC (SMA) ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) Repetitive peak reverse voltage VRRM ES 2AA ES 2AA 50 Reverse voltage, total rms value VR(RMS) 35 PARAMETER SYMBOL Marking code on the device ES 2BA ES 2BA 100 ES 2CA ES 2CA 150 ES 2DA ES 2DA 200 ES 2FA ES 2FA 300 ES 2GA ES 2GA 400 ES 2HA ES 2HA 500 70 105 140 210 280 350 ES UNIT 2JA ES 2JA 600 V 420 V Forward current Peak forward surge current, 8.3ms single half sine-wave superimposed on rated load Junction temperature IF 2 A IFSM 50 A TJ - 55 to +150 °C Storage temperature TSTG - 55 to +150 °C 1 Version: M2102 ES2AA – ES2JA Taiwan Semiconductor THERMAL PERFORMANCE PARAMETER SYMBOL TYP UNIT Junction-to-lead thermal resistance RӨJL 20 °C/W Junction-to-ambient thermal resistance RӨJA 75 °C/W ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER Forward voltage CONDITIONS ES2AA ES2BA ES2CA ES2DA ES2FA ES2GA ES2HA ES2JA (1) Reverse current @ rated VR TJ = 25°C (2) Junction capacitance IF = 2A, TJ = 25°C Reverse recovery time 1MHz, VR = 4.0V IF = 0.5A, IR = 1.0A, Irr = 0.25A TYP MAX UNIT - 0.95 V - 1.30 V - 1.70 V - 10 µA - 350 µA 25 - pF 20 - pF - 35 ns VF IR TJ = 125°C ES2AA ES2BA ES2CA ES2DA ES2FA ES2GA ES2HA ES2JA SYMBOL CJ trr Notes: 1. Pulse test with PW = 0.3ms 2. Pulse test with PW = 30ms ORDERING INFORMATION ORDERING CODE(1) PACKAGE PACKING ES2xA DO-214AC (SMA) 7,500 / Tape & Reel Notes: 1. “x” defines voltage from 50V(ES2AA) to 600V(ES2JA) 2 Version: M2102 ES2AA – ES2JA Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Forward Current Derating Curve Fig.2 Typical Junction Capacitance 60 50 CAPACITANCE (pF) 2 1 40 ES2AA - ES2DA 30 20 ES2FA - ES2JA 10 0 25 50 75 100 125 f=1.0MHz Vsig=50mVp-p 0 150 0.1 1 LEAD TEMPERATURE (°C) INSTANTANEOUS FORWARD CURRENT (A) 100 TJ=125°C 10 TJ=75°C 1 TJ=25°C 0.1 20 30 40 50 60 70 80 100 Fig.4 Typical Forward Characteristics 1000 90 100 100 10 10 1 UF1DLW ES2FA - ES2GA ES2AA - ES2DA TJ=125°C TJ=25°C 0.1 1 ES2HA - ES2JA 0.01 0.1 0.001 0.6 0.8 1.0 1.2 0.3 0.4 0.5 0.6 PERCENT OF RATED PEAK REVERSE VOLTAGE (%) Pulse width 300μs 1% duty cycle Pulse width 1.4 0.7 1.6 0.8 1.8 0.9 2.0 1 1.1 FORWARD VOLTAGE (V) Fig.5 Maximum Non-Repetitive Forward Surge Current 60 PEAK FORWARD SURGE CURRENT (A) INSTANTANEOUS REVERSE CURRENT (μA) Fig.3 Typical Reverse Characteristics 10 10 REVERSE VOLTAGE (V) (A) AVERAGE FORWARD CURRENT (A) 3 8.3ms single half sine wave 50 40 30 20 10 0 1 10 100 NUMBER OF CYCLES AT 60 Hz 3 Version: M2102 1.2 ES2AA – ES2JA Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.6 Reverse Recovery Time Characteristic and Test Circuit Diagram 4 Version: M2102 ES2AA – ES2JA Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS DO-214AC (SMA) SUGGESTED PAD LAYOUT MARKING DIAGRAM 5 P/N = Marking Code G = Green Compound YW = Date Code F = Factory Code Version: M2102 ES2AA – ES2JA Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 6 Version: M2102
ES2DA R3G
物料型号:ES2AA至ES2JA,由台湾半导体公司生产。
器件简介:这些是超快速表面贴装整流器,具有玻璃钝化芯片结、适合自动化放置、低轮廓封装、超快速恢复时间、符合RoHS标准、无卤素等特点。
引脚分配:文档中没有明确指出具体的引脚分配图,但通常对于DO-214AC (SMA)封装,阳极和阴极分别通过引脚和外壳/散热片连接。
参数特性:包括正向电流IF为2A,反向峰值重复电压VRRM从50V至600V,正向浪涌电流IFSM为50A,最大结温TJMAX为150℃,封装类型为DO-214AC (SMA),单芯片配置。
功能详解:这些整流器具有超快速恢复时间,适合高效率的应用场景。
应用信息:适用于DC-DC转换器、开关模式转换器和逆变器、照明应用、消火花电路和自由轮应用。
封装信息:封装类型为DO-214AC (SMA),封装材料满足UL 94V-0可燃性等级,引脚为镀锡的,可焊接,符合JSTD 201的2级晶须测试,极性通过阴极带标识。
ES2DA R3G 价格&库存
很抱歉,暂时无法提供与“ES2DA R3G”相匹配的价格&库存,您可以联系我们找货
ES2DA R3G
  • 1+5.366321+0.67289
  • 10+3.5924610+0.45047
  • 100+2.82552100+0.35430
  • 500+2.15122500+0.26975
库存:966
ES2DA R3G
    • 100+0.32951
    • 1000+0.31731
    • 3000+0.30510
    • 6000+0.28070
    • 10000+0.27337
    ES2DA R3G
    • 1800+1.729971800+0.21693
    • 3600+1.546513600+0.19392
    • 5400+1.467875400+0.18406
    • 9000+1.363029000+0.17091
    • 45000+1.3315645000+0.16697
    库存:966
