SFC5V650-SFC1250
Technical Data
Data Sheet N2075, Rev. -
SFC5V650 Thru SFC1250 Flip Chip Zener Diode
Features
Zener Voltage: 5.6V 6.2V 6.8V 10V 12V
Case: WLCSP
Space saving, low profile
Very small dimensions:1.0mm*0.6mm*0.28mm
20mA forward current
500mW Power dissipation
Case: WLCSP
Applications
Circuit Diagram
Voltage Regulation
Voltage Reference
Protection and Clamping
Maximum Ratings:
Characteristics
Symbol
Condition
Max.
Units
Nominal Power Dissipation
PD
Derate above 25℃
500
mW
Forward Voltage
VF
@IF=10mA, Pulse, TJ=25℃
0.9
V
Operating Temperature Range
TJ
-55 to +150
C
Storage Temperature Range
Tstg
-55 to +150
C
China - Germany - Korea - Singapore - United States
http://www.smc-diodes.com - sales@ smc-diodes.com
SFC5V650-SFC1250
Technical Data
Electrical Characteristics @ TJ=25 C:
Zener voltage
Device
SFC5V650
SFC6V250
SFC6V850
SFC1050
SFC1250
Zener Impedence
Leakage Current
Max.
Max.
ZZT @ IZT
ZZK @ IZK
mA
Ω
Ω
mA
uA
Volts
7
5
17
30
1600
1000
750
600
600
0.25
0.25
0.25
0.25
0.25
5
5
3
3
1
3
4
5
8
9.1
Nom. VZ ①
@ IZT
Volts
5.6
6.2
6.8
10
12
@ IZK
Max. IR @ VR
Note: ①Vz Tolerance is ±5%
Ordering Information:
Device
SFC5V650-SFC1250
Package
Plating
Shipping
WLCSP
Cu+Sn
6000pcs/reel
For information on tape and reel specifications, including part orientation and tape sizes, please refer to our tape and reel packaging
specification.
SFC5V650-SFC1250
Technical Data
Mechanical Dimensions (in millimeters:WLCSP)
mechanical size(mm)
Item
Material
A
Si
A1
Cu
0.008
A2
Sn
0.003
A3
PI
min
typ
max
0.240
0.260
0.280
0.003
b
0.004
0.005
0.500
L2
0.200
0.250
0.300
L3
0.200
0.250
0.300
e
0.650
D
0.590
0.63
E
0.990
1.03
SFC5V650-SFC1250
Technical Data
Carrier Tape and Reel Specification(in millimeters)
Marking Diagram
XX
WW
YY
WW
YY
XX
= cathode
= week code
= year code
= device code
Where
56
=SFC5V650
62
=SFC6V250
68
=SFC6V850
10
=SFC1050
12
=SFC1250
SFC5V650-SFC1250
Technical Data
Data Sheet N2075, Rev. DISCLAIMER:
1- The information given herein, including the specifications and dimensions, is subject to change without prior notice to improve product
characteristics. Before ordering, purchasers are advised to contact the SMC Diode Solutions sales department for the latest version of
the datasheet(s).
2- In cases where extremely high reliability is required (such as use in nuclear power control, aerospace and aviation, traffic equipment,
medical equipment , and safety equipment) , safety should be ensured by using semiconductor devices that feature assured safety or by
means of users’ fail-safe precautions or other arrangement .
3- In no event shall SMC Diode Solutions be liable for any damages that may result from an accident or any other cause during
operation of the user’s units according to the datasheet(s). SMC Diode Solution assumes no responsibility for any intellectual property
claims or any other problems that may result from applications of information, products or circuits described in the datasheets.
4- In no event shall SMC Diode Solutions be liable for any failure in a semiconductor device or any secondary damage resulting from use
at a value exceeding the absolute maximum rating.
5- No license is granted by the datasheet(s) under any patents or other rights of any third party or SMC Diode Solutions.
6- The datasheet(s) may not be reproduced or duplicated, in any form, in whole or part, without the expressed written permission of SMC
Diode Solutions.
7- The products (technologies) described in the datasheet(s) are not to be provided to any party whose purpose in their application will
hinder maintenance of international peace and safety nor are they to be applied to that purpose by their direct purchasers or any third
party. When exporting these products (technologies), the necessary procedures are to be taken in accordance with related laws and
regulations..
很抱歉,暂时无法提供与“SFC5V650”相匹配的价格&库存,您可以联系我们找货
