MUR110S R5G
MUR110S R5G
    TAIWANSEMICONDUCTOR(台湾半导体)
    DO214AA
    DIODE GEN PURP 100V 1A DO214AA
MUR110S R5G 数据手册
MUR105S – MUR160S Taiwan Semiconductor 1A, 50V - 600V Ultra Fast Surface Mount Rectifier FEATURES ● ● ● ● ● ● ● KEY PARAMETERS Glass passivated chip junction Ideal for automated placement Ultra Fast recovery time for high efficiency Low forward voltage, low power loss Moisture sensitivity level: level 1, per J-STD-020 RoHS Compliant Halogen-free according to IEC 61249-2-21 PARAMETER VALUE UNIT IF 1 A VRRM 50 - 600 V IFSM 40, 35 A TJ MAX 175 °C APPLICATIONS ● ● ● ● Package DO-214AA (SMB) Configuration Single die Switching mode power supply (SMPS) Adapters Lighting application Converter MECHANICAL DATA ● ● ● ● ● ● Case: DO-214AA (SMB) Molding compound meets UL 94V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Meet JESD 201 class 2 whisker test Polarity: Indicated by cathode band Weight: 0.090g (approximately) DO-214AA (SMB) ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER MUR SYMBOL MUR MUR MUR MUR MUR 105S 110S 115S 120S 140S 160S Marking code on the device MUR MUR MUR MUR MUR MUR 105S 110S 115S 120S 140S 160S UNIT Repetitive peak reverse voltage VRRM 50 100 150 200 400 600 V Reverse voltage, total rms value VR(RMS) 35 70 105 140 280 420 V Forward current Surge peak forward current, 8.3ms single half sine-wave superimposed on rated load Junction temperature IF 1 IFSM TJ - 55 to +175 °C Storage temperature TSTG - 55 to +175 °C 40 1 A 35 A Version: L2102 MUR105S – MUR160S Taiwan Semiconductor THERMAL PERFORMANCE PARAMETER SYMBOL TYP UNIT RӨJL 17 °C/W Junction-to-lead thermal resistance ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER CONDITIONS TYP MAX UNIT - 0.875 V - 1.250 V - 0.710 V MUR140S MUR160S - 1.050 V MUR105S MUR110S MUR115S MUR120S - 2 µA - 5 µA - 50 µA - 150 µA - 25 ns - 50 ns MUR105S MUR110S MUR115S MUR120S SYMBOL IF = 1A, TJ = 25°C MUR140S MUR160S Forward voltage (1) VF MUR105S MUR110S MUR115S MUR120S IF = 1A, TJ = 150°C TJ = 25°C MUR140S MUR160S Reverse current @ rated VR (2) IR MUR105S MUR110S MUR115S MUR120S TJ = 150°C MUR140S MUR160S Reverse recovery time MUR105S MUR110S MUR115S MUR120S IF = 0.5A, IR = 1.0A Irr = 0.25A MUR140S MUR160S trr Notes: Pulse test with PW = 0.3ms Pulse test with PW = 30ms 2 Version: L2102 MUR105S – MUR160S Taiwan Semiconductor ORDERING INFORMATION ORDERING CODE(1) PACKAGE PACKING MUR1xS DO-214AA (SMB) 3,000 / Tape & Reel Notes: "x" defines voltage from 50V(MUR105S) to 600V(MUR160S) 3 Version: L2102 MUR105S – MUR160S Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Forward Current Derating Curve Fig.2 Typical Junction Capacitance 70 60 CAPACITANCE (pF) 1 50 40 30 MUR105S-120S 20 10 MUR140S-160S 0 0 25 50 75 100 125 150 175 0 4 8 LEAD TEMPERATURE (°C) INSTANTANEOUS FORWARD CURRENT (A) MUR105S-120S MUR140S-160S 0.01 TJ=25°C 10 20 30 40 50 60 70 80 24 90 100 10 10 1 UF1DLW TJ=150°C TJ=125°C 1 0.1 TJ=25°C TJ=25°C 0.01 MUR105S-120S MUR140S-160S 0.1 0.001 0.4 0.6 0.8 1.0 0.3 0.4 0.5 0.6 PERCENT OF RATED PEAK REVERSE VOLTAGE (%) Pulse width 1.2 0.7 1.4 0.8 1.6 0.9 1.8 1 1.1 FORWARD VOLTAGE (V) Fig.5 Maximum Non-Repetitive Forward Surge Current 50 PEAK FORWARD SURGE CURRENT (A) INSTANTANEOUS REVERSE CURRENT (μA) TJ=150°C 0.001 20 Fig.4 Typical Forward Characteristics 10 0.1 16 REVERSE VOLTAGE (V) Fig.3 Typical Reverse Characteristics 1 12 (A) AVERAGE FORWARD CURRENT (A) 2 8.3ms single half sine wave 40 30 20 10 0 1 10 100 NUMBER OF CYCLES AT 60 Hz 4 Version: L2102 1.2 MUR105S – MUR160S Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS DO-214AA (SMB) SUGGESTED PAD LAYOUT MARKING DIAGRAM 5 P/N = Marking Code G = Green Compound YW = Date Code F = Factory Code Version: L2102 MUR105S – MUR160S Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 6 Version: L2102
MUR110S R5G 价格&库存
很抱歉,暂时无法提供与“MUR110S R5G”相匹配的价格&库存,您可以联系我们找货
