BAV19 A0G
BAV19 A0G
    TAIWANSEMICONDUCTOR(台湾半导体)
    DO-35(DO-204AH)
    DIODE GEN PURP 100V 200MA DO35
BAV19 A0G 数据手册
BAV19/BAV20/BAV21 Taiwan Semiconductor 200mA,120-250V Switching Diode FEATURES KEY PARAMETERS ● ● ● ● Low power loss, high efficiency Ideal for automated placement High surge current capability Compliant to RoHS directive 2011/65/EU and in accordance to WEEE 2002/96/EC ● Halogen-free according to IEC 61249-2-21 PARAMETER VALUE UNIT IF(AV) 100-200 mA VRRM 120-250 V IFSM at PW = 1μs 4 A VF at IF=100mA 1.00 V TJ MAX 175 °C APPLICATIONS ● ● ● ● Switching mode power supply (SMPS) Adapters Lighting application On-board DC/DC converter Package DO-35 Configuration Single Die MECHANICAL DATA ● Case: DO-35 ● Packing code with suffix "G" means green compound (halogen-free) ● Terminal: Matte tin plated leads, solderable per J-STD-002 ● Polarity: Indicated by cathode band ● Weight: 109 ± 4 mg (approximately) ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER Marking code on the device Reverse Breakdown Voltage Peak Forward Surge Current SYMBOL PART NUMBER UNIT BAV19 BAV20 BAV21 IR = 100 μA Pulse Width = 1 s , Square Wave Pulse Width = 1 μs , Square Wave V(BR) 120 200 250 V 1 IFSM A 4 Junction temperature range TJ -55 ~ 175 °C Storage temperature range TSTG -55 ~ 175 °C SYMBOL LIMIT UNIT RӨJA 300 °C/W THERMAL PERFORMANCE PARAMETER Junction-to-ambient thermal resistance 1 Version:E1610 BAV19/BAV20/BAV21 Taiwan Semiconductor ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER CONDITIONS Forward voltage per diode IF = 100mA, TJ = 25°C (1) (2) BAV19 VR = 100 V BAV20 VR = 150 V BAV21 VR = 200 V 1 MHz, VR=0V Junction capacitance TYP MAX UNIT -- 1.00 V -- 1.25 V IR -- 100 nA CJ -- 5 ρF VF IF = 200mA, TJ = 25°C Reverse current @ rated VR per diode SYMBOL Notes: 1. Pulse test with PW=0.3 ms 2. Pulse test with PW=30 ms ORDERING INFORMATION PART NO. PACKING PACKING CODE CODE SUFFIX BAVXX R0 (Note 1&2) A0 PACKAGE PACKING 10K / 14" Reel G DO-35 5K / Box (Ammo) Notes: 1. "xx" is Device Code from "19" to "21" 2. Whole series with green compound EXAMPLE EXAMPLE P/N PART NO. PACKING CODE BAV19 R0G BAV19 R0 PACKING CODE SUFFIX G 2 DESCRIPTION Green compound Version:E1610 BAV19/BAV20/BAV21 Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Reverse Voltage VS. Reverse Current Reverse Current VS. Reverse Voltage 325 50 Reverse Current (nA) Reverse Voltage (V) TA=25oC 300 TA=25oC 40 30 20 10 275 0 1 10 100 10 100 1000 Reverse Voltage (V) Reverse Current (uA) Reverse Current VS. Reverse Voltage Forward Voltage VS. Forward Current 100 475 90 Forward Voltage (mV) Reverse Current (nA) 425 TA=25oC 80 70 60 50 40 TA=25oC 375 325 275 30 20 100 225 1000 1 Reverse Voltage (V) 10 100 Forward Current (uA) 3 Version:E1610 BAV19/BAV20/BAV21 Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Forward Volatage VS. Forward Current Forward Volatage VS. Forward Current 1.4 1.3 Forward Voltage (V) Forward Voltage (mV) 700 TA=25oC 650 600 550 500 TA=25oC 1.2 1.1 1 0.9 0.8 0.7 450 0.1 1 10 10 100 1000 Forward Current (mA) Forward Current (mA) 4 Version:E1610 BAV19/BAV20/BAV21 Taiwan Semiconductor PACKAGE OUTLINE DIMENSION DO-35 DIM. Unit(mm) Unit(inch) Min Max Min Max A 0.34 0.60 0.013 0.024 B 2.90 5.08 0.114 0.200 C 25.40 38.10 1.000 1.500 D 1.30 2.28 0.051 0.090 MARKING DIAGRAM 5 Version:E1610 BAV19/BAV20/BAV21 Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 6 Version:E1610
BAV19 A0G 价格&库存
很抱歉,暂时无法提供与“BAV19 A0G”相匹配的价格&库存,您可以联系我们找货
