6A05GTA
6A05GTA
    SMCDIODESOLUTIONS(桑德斯)
    R-6
    DIODE GEN PURP 50V 6A R-6
6A05GTA 数据手册
6A05G-6A10G Technical Data Data Sheet N0550, Rev. B 6A05G THRU 6A10G GLASS PASSIVATED SILICON RECTIFIER Reverse Voltage - 50 to 1000 Volts Forward Current – 6.0 Amperes Features         R-6 Circuit Diagram The plastic package carries Underwriters Laboratory Flammability Classification 94V-0 Construction utilizes void-free molded plastic technique Low reverse leakage High forward surge current capability High temperature soldering guaranteed: 250℃ /10 seconds,0.375”(9.5mm) lead length, 5 lbs. (2.3kg) tension This is a Pb − Free Device All SMC parts are traceable to the wafer lot Additional testing can be offered upon request Mechanical Data       Case: R-6 molded plastic Terminals: Plated axial leads, solderable per MILSTD-202, Method 208 Polarity: Color band denotes cathode end Mounting Position: Any Weight: 2.1 grams Maximum Ratings and Electrical Characteristics @TA=25°C unless otherwise specified Single phase half-wave 60Hz, resistive or inductive load, for capacitive load current derate by 20%. Type Number Symbol 6A05G 6A1G 6A2G 6A4G 6A6G 6A8G 6A10G Units Maximum repetitive peak reverse voltage Maximum DC blocking voltage VRRM VDC Maximum RMS voltage VRMS Maximum average forward rectified current 0.375”(9.5mm) lead length at @TA = 60°C I(AV) 6.0 A Non-Repetitive Peak Forward Surge Current 8.3ms Single half sine-wave superimposed on rated load (JEDEC Method) IFSM 300 A Maximum instantaneous forward voltage at 6.0A VF 0.95 V Maximum DC reverse current At Rated DC Blocking Voltage IR 10.0 400 µA CJ 150 pF RθJA 10.0 °C/W TJ, TSTG -65 to +175 °C @TA = 25°C @TA = 100°C Typical Junction Capacitance (Note 1) Typical Thermal Resistance (Note 2) Operating junction and storage temperature range 50 35 5 100 3 70 1 200 7 140 2 400 1 280 4 600 2 420 Note: 1. Measured at 1MHz and applied reverse voltage of 4.0V D.C. 2. Thermal resistance from junction to ambient at 0.375”(9.5mm)lead length, P.C.B. mounted  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  6 800 4 560 8 1000 5 700 1 V 1 V 6A05G-6A10G Technical Data Data Sheet N0550, Rev. B Ratings and Characteristics Curves  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  6A05G-6A10G Technical Data Data Sheet N0550, Rev. B Mechanical Dimensions R-6 SYMBOL Ordering Information Device 6A05G-6A10G 6A05GTA-6A10GTA 6A05GTR-6A10GTR Package R-6(Pb-Free) R-6(Pb-Free) R-6(Pb-Free) Millimeters Inches Min. Max. Min. Max. A 25.4 - 1.000 - B 8.60 9.10 0.340 0.360 C 1.2 1.3 0.048 0.052 D 8.60 9.10 0.340 0.360 Marking Diagram Shipping 500pcs / tape 500pcs / tape 500pcs / reel For information on tape and reel specifications, including part orientation and tape sizes, please refer to our tape and reel packaging specification. 6A05G = Type Number Carrier Tape Specification R-6 SYMBOL Millimeters Min. Max. A 9.50 10.50 B 50.9 53.9 Z - 1.20 T 5.60 6.40 E - 0.80 IL1-L2I - 1.0  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  6A05G-6A10G Technical Data Data Sheet N0550, Rev. B DISCLAIMER: 1- The information given herein, including the specifications and dimensions, is subject to change without prior notice to improve product characteristics. Before ordering, purchasers are advised to contact the SMC Diode Solutions sales department for the latest version of the datasheet(s). 2- In cases where extremely high reliability is required (such as use in nuclear power control, aerospace and aviation, traffic equipment, medical equipment , and safety equipment) , safety should be ensured by using semiconductor devices that feature assured safety or by means of users’ fail-safe precautions or other arrangement . 3- In no event shall SMC Diode Solutions be liable for any damages that may result from an accident or any other cause during operation of the user’s units according to the datasheet(s). SMC Diode Solution assumes no responsibility for any intellectual property claims or any other problems that may result from applications of information, products or circuits described in the datasheets. 4- In no event shall SMC Diode Solutions be liable for any failure in a semiconductor device or any secondary damage resulting from use at a value exceeding the absolute maximum rating. 5- No license is granted by the datasheet(s) under any patents or other rights of any third party or SMC Diode Solutions. 6- The datasheet(s) may not be reproduced or duplicated, in any form, in whole or part, without the expressed written permission of SMC Diode Solutions. 7- The products (technologies) described in the datasheet(s) are not to be provided to any party whose purpose in their application will hinder maintenance of international peace and safety nor are they to be applied to that purpose by their direct purchasers or any third party. When exporting these products (technologies), the necessary procedures are to be taken in accordance with related laws and regulations.  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com 
6A05GTA 价格&库存
很抱歉,暂时无法提供与“6A05GTA”相匹配的价格&库存,您可以联系我们找货
