C6D08065A
C6D08065A
    WOLFSPEED
    TO-220-2
    凭借碳化硅 (SiC) 肖特基势垒二极管的性能优势,电力电子系统有望达到比基于硅的解决方案更高的效率标准,同时还能实现更高的频率和功率密度。SiC 二极管可以轻松并联,以满足各种应用需求,而无需担心热...
C6D08065A 数据手册
C6D08065A VRRM Silicon Carbide Schottky Diode Z-Rec Rectifier ® 650 V IF (TC=155˚C) = 8A Qc = 29 nC Package Features • • • • • • • = New 6th Generation Technology Low Forward Voltage Drop (VF) Zero Reverse Recovery Current Zero Forward Recovery Voltage Low Leakage Current (Ir) Temperature-Independent Switching Behavior Positive Temperature Coefficient on VF TO-220-2 Benefits • • • • PIN 1 Higher System Level Efficiency Increase System Power Density Reduction of Heat Sink Requirements Parallel Devices Without Thermal Runaway Applications • • • • • CASE PIN 2 Switch Mode Power Supplies (SMPS) Server/Telecom Power Supplies Industrial Power Supplies Solar UPS Part Number Package Marking C6D08065A TO-220-2 C6D08065 Maximum Ratings (TC = 25 ˚C unless otherwise specified) Symbol Parameter Unit Test Conditions Note VRRM Repetitive Peak Reverse Voltage 650 V VDC DC Blocking Voltage 650 V Continuous Forward Current 30 16 8 A TC=25˚C TC=125˚C TC=155˚C IFRM Repetitive Peak Forward Surge Current 37 22 A TC=25˚C, tP = 10 ms, Half Sine Wave TC=110˚C, tP=10 ms, Half Sine Wave IFSM Non-Repetitive Peak Forward Surge Current 69 63 A TC=25˚C, tp = 10 ms, Half Sine Wave TC=110˚C, tp = 10 ms, Half Sine Wave Fig. 8 IF,Max Non-Repetitive Peak Forward Surge Current 860 790 A TC=25˚C, tP = 10 µs, Pulse TC=110˚C, tP = 10 µs, Pulse Fig. 8 Ptot Power Dissipation 92.6 40.1 W TC=25˚C TC=110˚C Fig. 4 Operating Junction and Storage Temperature -55 to +175 ˚C 1 8.8 Nm lbf-in IF TJ , Tstg TO-220 Mounting Torque 1 Value C6D08065A, Rev. -, 04-2019 M3 Screw 6-32 Screw Fig. 3 Electrical Characteristics Symbol Parameter Typ. Max. Unit VF Forward Voltage 1.27 1.37 1.50 1.60 V IR Reverse Current 2 15 40 160 QC Total Capacitive Charge C EC Test Conditions Note IF = 8 A TJ=25°C IF = 8 A TJ=175°C Fig. 1 μA VR = 650 V TJ=25°C VR = 650 V TJ=175°C Fig. 2 29 nC VR = 400 V, IF = 8A TJ = 25°C Fig. 5 Total Capacitance 518 57 45 pF VR = 0 V, TJ = 25°C, f = 1 MHz VR = 200 V, TJ = 25˚C, f = 1 MHz VR = 400 V, TJ = 25˚C, f = 1 MHz Fig. 6 Capacitance Stored Energy 4.4 μJ VR = 400 V Fig. 7 Note: This is a majority carrier diode, so there is no reverse recovery charge. Thermal Characteristics Symbol RθJC Parameter Typ. Unit Note Thermal Resistance from Junction to Case 1.62 °C/W Fig. 9 Typical Performance 100 20 18 14 mA) IRRI(Rm(A) 12 10 FF F FowardICurrent, I (A) I(A) (A) IF (A) 16 Reverse Leakage I Current, (mA) IRR (uA) TJ = -55°C TJ = 25°C TJ = 75°C TJ = 125°C TJ = 175°C 8 6 4 2 0 0.5 1.0 1.5 FowardVVVoltage, V(V) (V)VF (V) FF F(V) 2.0 Figure 1. Forward Characteristics 2 C6D08065A, Rev. -, 04-2019 2.5 80 60 TJ = 175 °C TJ = 125 °C 40 TJ = 75 °C TJ = 25 °C 20 0 TJ = -55 °C 0 100 200 300 400 500 VVRVVoltage, (V) (V) Reverse (V) VR (V) RR 600 Figure 2. Reverse Characteristics 700 800 Typical Performance 100 14 90 100 10% Duty 20% Duty 30% Duty 50% Duty 70% Duty DC 90 80 90 80 12 80 70 30 10 70 60 60 508 50 406 40 30 304 20 20 20 10 10 10 0 0 70 (W) PP (W) P (W) (W) P Tot TOT Tot TOT Tot Tot (A) (A) IIF(peak) IF(peak) (A) IF (A) F(peak) F(peak) 60 50 40 2 25 50 75 100 T ˚C T ˚C TTCCCC(°C) ˚C 125 150 175 25 Figure 3. Current Derating Capacitance Capacitance (pF)(pF) CC(pF) 25 6 20 154 Conditions: TJ = 25 °C Ftest = 1 MHz Vtest = 25 mV 200 60 0 00 200 300 400 500 500 (V) VRR (V) (V) ReverseVVRVoltage, RR C6D08065A, Rev. -, 04-2019 175 175 100 300 80 40 100 20 600 600 700 700 Figure 5. Total Capacitance Charge vs. Reverse Voltage 3 150 150 400 120 10 2 5 100 T ˚C T ˚C TCCCC (°C) 125 125 160 500 140 308 0 100 100 180 600 Conditions: TJ = 25 °C 40 10 35 75 75 Figure 4. Power Derating C C C CapacitiveQ QC (nC) (nC) QCharge, (nC) C (pF) 12 45 50 00 11 10 10 (V) VRR (V) Reverse Voltage, R(V) VV RR 100 100 Figure 6. Capacitance vs. Reverse Voltage 1000 1000 Typical Performance 1,000 12 12 IIFSM (A) Capacitance Stored Energy, (A) EC (mJ) 10 8 FSM EC(mJ) 6 C Capacitance Stored E Energy, (mJ) EC (mJ) 10 4 2 0 TJ_initial = 25 °C TJ_initial = 110 °C 0 100 200 300 400 500 ReverseVVoltage, (V) VR (V) R 600 700 Junction To Impedance, ZZthJC (ooC/W) Thermal Resistance (˚C/W) Junction To Case Case Impedance, Thermal Thermal Resistance Resistance (˚C/W) (˚C/W) thJC ( C/W) Figure 7. Capacitance Stored Energy 1 10 1 100E-3 100E-3 1 10E-3 10E-3 100E-3 8 6100 4 2 0 10 010E-6 100 400 1E-3500 ReverseTime, tpVoltage, (s) tp (s)VR (V) 0.3 0.3 0.5 0.1 0.3 0.1 0.05 0.05 0.1 0.02 0.02 0.01 0.05 0.01 SinglePulse SinglePulse 0.02 0.01 SinglePulse 10E-6 10E-610E-6 100E-6 100E-6 1E-3 1E-3 100E-310E-3 1 10E-3 Time, tp (s) T(Sec) (Sec) (Sec) T TT (Sec) Figure 9. Transient Thermal Impedance C6D08065A, Rev. -, 04-2019 600 Figure 8. Non-repetitive peak forward surge current versus pulse duration (sinusoidal waveform) 0.5 0.5 1E-3 1E-3 10E-3 1E-6 1E-6 1E-6 4 200100E-6300 100E-3 10 100 1 10E-3 700 Package Dimensions Package TO-220-2 POS PIN 1 PIN 2 CASE Inches Millimeters Min Max Min Max A .381 .410 9.677 10.414 6.477 B .235 .255 5.969 C .100 .120 2.540 3.048 D .223 .337 5.664 8.560 D1 .457-.490 11.60-12.45 typ D2 .277-.303 typ 7.04-7.70 typ D3 .244-.252 typ 6.22-6.4 typ E .590 .615 14.986 15.621 E1 .302 .326 7.68 8.28 E2 .227 251 5.77 6.37 F .143 .153 3.632 3.886 G 1.105 1.147 28.067 29.134 H .500 .550 12.700 13.970 L .025 .036 .635 .914 M .045 .055 1.143 1.550 N .195 .205 4.953 5.207 P .165 .185 4.191 4.699 Q .048 .054 1.219 1.372 S 3° 6° 3° 6° 6° T 3° 6° 3° U 3° 6° 3° 6° V .094 .110 2.388 2.794 W .014 .025 .356 .635 X 3° 5.5° 3° 5.5° Y .385 .410 9.779 10.414 z .130 .150 3.302 3.810 NOTE: 1. Dimension L, M, W apply for Solder Dip Finish Recommended Solder Pad Layout TO-220-2 Part Number Package Marking C6D08065A TO-220-2 C6D08065 Note: Recommended soldering profiles can be found in the applications note here: http://www.wolfspeed.com/power_app_notes/soldering 5 C6D08065A, Rev. -, 04-2019 Notes • RoHS Compliance The levels of RoHS restricted materials in this product are below the maximum concentration values (also referred to as the threshold limits) permitted for such substances, or are used in an exempted application, in accordance with EU Directive 2011/65/EC (RoHS2), as implemented January 2, 2013. RoHS Declarations for this product can be obtained from your Wolfpseed representative or from the Product Ecology section of our website at http://www.wolfspeed.com/Power/Tools-and-Support/Product-Ecology. • REACh Compliance REACh substances of high concern (SVHCs) information is available for this product. Since the European Chemical Agency (ECHA) has published notice of their intent to frequently revise the SVHC listing for the foreseeable future,please contact a Cree representative to insure you get the most up-to-date REACh SVHC Declaration. REACh banned substance information (REACh Article 67) is also available upon request. • This product has not been designed or tested for use in, and is not intended for use in, applications implanted into the human body nor in applications in which failure of the product could lead to death, personal injury or property damage, including but not limited to equipment used in the operation of nuclear facilities, life-support machines, cardiac defibrillators or similar emergency medical equipment, aircraft navigation or communication or control systems, or air traffic control systems. Related Links • • • Cree SiC Schottky diode portfolio: http://www.wolfspeed.com/Power/Products#SiCSchottkyDiodes Schottky diode Spice models: http://www.wolfspeed.com/power/tools-and-support/DIODE-model-request2 SiC MOSFET and diode reference designs: http://go.pardot.com/l/101562/2015-07-31/349i Copyright © 2019 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree, the Cree logo, and Zero Recovery are registered trademarks of Cree, Inc. 6 C6D08065A, Rev. -, 04-2019 Cree, Inc. 4600 Silicon Drive Durham, NC 27703 USA Tel: +1.919.313.5300 Fax: +1.919.313.5451 www.cree.com/power
C6D08065A 价格&库存
很抱歉,暂时无法提供与“C6D08065A”相匹配的价格&库存,您可以联系我们找货
C6D08065A
  • 1+36.95213
  • 10+22.07545
  • 50+18.99711
  • 100+17.70348
  • 250+16.49371
  • 500+15.84689
库存:37
