RS2A – RS2M
Taiwan Semiconductor
2A, 50V - 1000V Fast Recovery Surface Mount Rectifier
FEATURES
KEY PARAMETERS
Low power loss, high efficiency
Ideal for automated placement
Glass passivated chip junction
Fast switching for high efficiency
Moisture sensitivity level: level 1, per J-STD-020
RoHS Compliant
Halogen-free according to IEC 61249-2-21
APPLICATIONS
PARAMETER
VALUE
UNIT
IF
2
A
VRRM
50 - 1000
V
IFSM
50
A
TJ MAX
150
°C
Package
DO-214AA (SMB)
Configuration
Single die
Switching mode power supply (SMPS)
Adapters
Lighting application
Converter
MECHANICAL DATA
Case: DO-214AA (SMB)
Molding compound meets UL 94V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Meet JESD 201 class 2 whisker test
Polarity: Indicated by cathode band
Weight: 0.090g (approximately)
DO-214AA (SMB)
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
SYMBOL RS2A RS2B RS2D RS2G RS2J RS2K RS2M UNIT
Marking code on the device
RS2K RS2M
Repetitive peak reverse voltage
VRRM
50
100
200
400
600
800
1000
V
Reverse voltage, total rms value
VR(RMS)
35
70
140
280
420
560
700
V
Forward current
Surge peak forward current, 8.3ms
single half sine-wave superimposed
on rated load
Junction temperature
IF
2
A
IFSM
50
A
TJ
- 55 to +150
°C
Storage temperature
TSTG
- 55 to +150
°C
1
Version: K2102
RS2A – RS2M
THERMAL PERFORMANCE
PARAMETER
SYMBOL
TYP
UNIT
Junction-to-ambient thermal resistance
RӨJA
55
°C/W
Junction-to-lead thermal resistance
RӨJL
18
°C/W
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
Forward voltage
CONDITIONS
(1)
Reverse current @ rated VR
IF = 2A, TJ = 25°C
TJ = 25°C
(2)
TYP
MAX
UNIT
VF
1.3
V
5
µA
50
µA
50
pF
150
ns
250
ns
500
ns
IR
TJ = 125°C
Junction capacitance
SYMBOL
1MHz, VR = 4.0V
CJ
RS2A
RS2B
RS2D
Reverse recovery time
RS2G
RS2J
IF = 0.5A, IR = 1.0A
Irr = 0.25A
RS2K
RS2M
trr
Notes:
1. Pulse test with PW = 0.3ms
2. Pulse test with PW = 30ms
ORDERING INFORMATION
ORDERING CODE(1)
PACKAGE
PACKING
RS2x
DO-214AA (SMB)
3,000 / Tape & Reel
Notes:
1. "x" defines voltage from 50V(RS2A) to 1000V(RS2M)
2
Version: K2102
RS2A – RS2M
CHARACTERISTICS CURVES
Fig.1 Forward Current Derating Curve
Fig.2 Typical Junction Capacitance
100
2
CAPACITANCE (pF)
AVERAGE FORWARD CURRENT (A)
2.5
1.5
1
0.5
f=1.0MHz
Vsig=50mVp-p
50
75
100
125
10
150
1
10
LEAD TEMPERATURE (°C)
Fig.4 Typical Forward Characteristics
TJ=125°C
10
1
TJ=25°C
0.1
30
40
50
60
70
80
90
100
10 10
TJ=125°C
1
TJ=25°C
0.1
0.01
0.001
0.3
0.1
0.6
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
UF1DLW
1
(A)
100
INSTANTANEOUS FORWARD CURRENT (A)
INSTANTANEOUS REVERSE CURRENT (µA)
Fig.3 Typical Reverse Characteristics
REVERSE VOLTAGE (V)
0.4
0.8
0.5
0.6
1
Pulse width
Pulse Width=300μs
1% Duty Cycle
0.7
0.8
0.9
1
1.1
1.2
1.4
1.6
FORWARD VOLTAGE (V)
3
Version: K2102
1.2
RS2A – RS2M
Fig.5 Maximum Non-Repetitive Forward Surge Current
PEAK FORWARD SURGE CURRENT (A)
60
8.3ms single half sine wave
50
40
30
10
100
NUMBER OF CYCLES AT 60 Hz
Fig.6 Reverse Recovery Time Characteristic and Test Circuit Diagram
4
Version: K2102
RS2A – RS2M
PACKAGE OUTLINE DIMENSIONS
DO-214AA (SMB)
SUGGESTED PAD LAYOUT
MARKING DIAGRAM
5
P/N
= Marking Code
G
= Green Compound
YW
= Date Code
F
= Factory Code
Version: K2102
RS2A – RS2M
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf,
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability
for application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
6
Version: K2102
很抱歉,暂时无法提供与“RS2J R5G”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+0.743341+0.09660
- 国内价格 香港价格
- 1+0.545711+0.07092
- 国内价格 香港价格
- 146+0.55133146+0.07165
