TSPB5H150S S1G
TSPB5H150S S1G
    TAIWANSEMICONDUCTOR(台湾半导体)
    TO-277
    DIODE SCHOTTKY 150V 5A SMPC4.0
TSPB5H150S S1G 数据手册
TSPB5H100S – TSPB5H150S Taiwan Semiconductor 5A, 100V - 150V Trench Schottky Surface Mount Rectifier FEATURES ● ● ● ● ● ● ● ● ● KEY PARAMETERS Patented Trench Schottky technology Excellent high temperature stability Low forward voltage Lower power loss/ high efficiency High forward surge capability Ideal for automated placement Moisture sensitivity level: level 1, per J-STD-020 RoHS Compliant Halogen-free according to IEC 61249-2-21 PARAMETER VALUE UNIT IF 5 A VRRM 100 - 150 V IFSM 100 A TJ MAX 150 °C Package SMPC4.0 Configuration Single die APPLICATIONS ● Switching mode power supply (SMPS) ● Adapters ● DC to DC converter MECHANICAL DATA ● ● ● ● ● ● Case: SMPC4.0 Molding compound meets UL 94V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Meet JESD 201 class 1A whisker test Polarity: Indicated by cathode band Weight: 0.090g (approximately) SMPC4.0 ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER SYMBOL Marking code on the device TSPB5H 100S TSPB5H 120S TSPB5H 150S B5H100 B5H120 B5H150 UNIT Repetitive peak reverse voltage VRRM 100 120 150 V Reverse voltage, total rms value VR(RMS) 70 84 105 V Forward current Peak forward surge current, 8.3ms single half sine-wave superimposed on rated load Critical rate of rise of off-state voltage IF 5 A IFSM 100 A dv/dt 10,000 V/μs Junction temperature TJ - 55 to +150 °C Storage temperature TSTG - 55 to +150 °C 1 Version: C2103 TSPB5H100S – TSPB5H150S Taiwan Semiconductor THERMAL PERFORMANCE PARAMETER SYMBOL TYP UNIT RӨJL 15 °C/W Junction-to-lead thermal resistance ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER CONDITIONS SYMBOL TSPB5H100S TSPB5H120S Forward voltage TSPB5H150S (1) VF TSPB5H100S TSPB5H120S Reverse current @ rated VR IF = 5A, TJ = 25°C (2) TSPB5H150S TSPB5H100S TSPB5H120S TSPB5H150S TSPB5H100S TSPB5H120S TSPB5H150S IF = 5A, TJ = 125°C TJ = 25°C IR TJ = 125°C TYP MAX UNIT 0.59 0.66 V 0.66 0.74 V 0.74 0.84 V 0.53 0.60 V 0.56 0.64 V 0.60 0.70 V - 150 μA - 100 μA - 18 mA - 12 mA Notes: 1. Pulse test with PW = 0.3ms 2. Pulse test with PW = 30ms ORDERING INFORMATION ORDERING CODE(1) PACKAGE PACKING TSPB5HxS SMPC4.0 6,000 / Tape & Reel Notes: 1. “x” defines voltage from 100V(TSPB5H100S) to 150V(TSPB5H150S) 2 Version: C2103 TSPB5H100S – TSPB5H150S Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Forward Current Derating Curve Fig.2 Typical Junction Capacitance 1000 5 CAPACITANCE (pF) 4 3 2 100 1 0 f=1.0MHz Vsig=50mVp-p 10 50 75 100 125 150 0.1 1 CASE TEMPERATURE (°C) INSTANTANEOUS FORWARD CURRENT (A) INSTANTANEOUS REVERSE CURRENT (mA) Fig.4 Typical Forward Characteristics 100 TSPB5H100S TJ=150°C 1 TJ=125°C 0.1 TJ=100°C 0.01 0.001 TJ=25°C 0.0001 10 20 30 40 50 60 70 80 90 100 10 10 TSPB5H100S 1 10.1 INSTANTANEOUS FORWARD CURRENT (A) INSTANTANEOUS REVERSE CURRENT (mA) TSPB5H120S TJ=150°C 1 TJ=125°C TJ=100°C 0.01 0.001 TJ=25°C 0.0001 20 30 40 50 60 70 80 TJ=125°C TJ=125°C TJ=100°C TJ=25°C TJ=25°C 0.1 0.001 0.1 0.2 0.3 0.4 0.3 0.4 0.5 0.6 Pulse width 300μs 1% duty cycle Pulse width 0.5 0.7 0.6 0.8 0.7 0.9 0.8 1 1.1 1.2 1.1 1.2 Fig.6 Typical Forward Characteristics 100 10 TJ=150°C FORWARD VOLTAGE (V) Fig.5 Typical Reverse Characteristics 0.1 UF1DLW 0.01 PERCENT OF RATED PEAK REVERSE VOLTAGE (%) 10 100 REVERSE VOLTAGE (V) Fig.3 Typical Reverse Characteristics 10 10 (A) 25 TSPB5H100S TSPB5H120S TSPB5H150S 90 100 PERCENT OF RATED PEAK REVERSE VOLTAGE (%) 10 10 TSPB5H120S 1 10.1 UF1DLW TJ=150°C TJ=125°C TJ=125°C TJ=100°C TJ=25°C (A) AVERAGE FORWARD CURRENT (A) 6 TJ=25°C 0.01 0.1 0.001 0.1 0.2 0.3 0.4 0.3 0.4 0.5 0.6 Pulse width 300μs 1% duty cycle Pulse width 0.5 0.7 0.6 0.8 0.7 0.9 0.8 1 FORWARD VOLTAGE (V) 3 Version: C2103 TSPB5H100S – TSPB5H150S Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.8 Typical Forward Characteristics TSPB5H150S 10 TJ=150°C 1 TJ=125°C 0.1 TJ=100°C 0.01 0.001 TJ=25°C 0.0001 10 20 30 40 50 60 70 80 90 100 PERCENT OF RATED PEAK REVERSE VOLTAGE (%) 10 10 TSPB5H150S 1 1 0.1 UF1DLW TJ=150°C TJ=125°C TJ=125°C TJ=25°C TJ=25°C 0.01 0.1 0.001 0.2 0.3 TJ=100°C (A) 100 INSTANTANEOUS FORWARD CURRENT (A) INSTANTANEOUS REVERSE CURRENT (mA) Fig.7 Typical Reverse Characteristics Pulse width 300μs 1% duty cycle Pulse width 0.3 0.4 0.4 0.5 0.5 0.6 0.6 0.7 0.8 0.7 0.9 0.8 1 1.1 FORWARD VOLTAGE (V) 4 Version: C2103 1.2 TSPB5H100S – TSPB5H150S Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS SMPC4.0 SUGGESTED PAD LAYOUT MARKING DIAGRAM P/N = Marking Code 5 YW = Date Code F = Factory Code Version: C2103 TSPB5H100S – TSPB5H150S Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 6 Version: C2103
TSPB5H150S S1G 价格&库存
很抱歉,暂时无法提供与“TSPB5H150S S1G”相匹配的价格&库存,您可以联系我们找货
