TSN520M60
Taiwan Semiconductor
20A, 60V Trench Schottky Surface Mount Rectifier
FEATURES
KEY PARAMETERS
Patented Trench Schottky technology
Excellent high temperature stability
Low forward voltage
Lower power loss/ high efficiency
High forward surge capability
Ideal for automated placement
Moisture sensitivity level: level 1, per J-STD-020
RoHS Compliant
Halogen-free according to IEC 61249-2-21
PARAMETER
VALUE
UNIT
IF
A
VRRM
60
V
IFSM
200
A
TJ MAX
150
°C
Package
PDFN56
Configuration
Single die
APPLICATIONS
● Switching mode power supply (SMPS)
● Adapters
● DC to DC converter
MECHANICAL DATA
Case: PDFN56
Molding compound meets UL 94V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Meet JESD 201 class 2 whisker test
Polarity: As marked
Weight: 0.096g (approximately)
PDFN56
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
SYMBOL
Marking code on the device
TSN520M60
UNIT
520M60
Repetitive peak reverse voltage
VRRM
60
V
Reverse voltage, total rms value
VR(RMS)
42
V
Forward current
Peak forward surge current, 8.3ms single half
sine-wave superimposed on rated load
Junction temperature
IF
A
IFSM
200
A
TJ
- 55 to +150
°C
Storage temperature
TSTG
- 55 to +150
°C
1
Version: H2103
TSN520M60
THERMAL PERFORMANCE
PARAMETER
Junction-to-lead thermal resistance
SYMBOL
TYP
UNIT
RӨJL
7
°C/W
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
CONDITIONS
SYMBOL
IF = 10A, TJ = 25°C
Forward voltage
IF = 20A, TJ = 25°C
(1)
IF = 10A, TJ = 125°C
VF
IF = 20A, TJ = 125°C
Reverse current @ rated VR
(2)
TJ = 25°C
IR
TJ = 125°C
TYP
MAX
UNIT
0.43
V
0.48
0.58
V
0.33
V
0.42
0.52
V
500
µA
100
mA
Notes:
1. Pulse test with PW = 0.3ms
2. Pulse test with PW = 30ms
ORDERING INFORMATION
ORDERING CODE
PACKAGE
PACKING
TSN520M60
PDFN56
6,000 / Tape & Reel
2
Version: H2103
TSN520M60
CHARACTERISTICS CURVES
Fig.1 Forward Current Derating Curve
Fig.2 Typical Junction Capacitance
10000
1000
CAPACITANCE (pF)
100
10
1
f=1.0MHz
Vsig=50mVp-p
0.1
25
50
75
100
125
150
0.1
1
LEAD TEMPERATURE (°C)
INSTANTANEOUS FORWARD CURRENT (A)
INSTANTANEOUS REVERSE CURRENT (mA)
Fig.4 Typical Forward Characteristics
1000
TJ=150°C
10
TJ=125°C
1
TJ=100°C
0.1
0.01
TJ=25°C
0.001
10
40
50
60
70
80
100
REVERSE VOLTAGE (V)
Fig.3 Typical Reverse Characteristics
100
10
90
100
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
10010
T =150°C
10 1
J
UF1DLW
TJ=125°C
TJ=125°C
TJ=25°C
10.1
(A)
AVERAGE FORWARD CURRENT (A)
30
TJ=25°C
0.1
0.01
0.01
0.001
0.0
0.3
TJ=100°C
Pulse width 300μs
1% duty cycle
Pulse width
0.1
0.4
0.2
0.5
0.3
0.4
0.6
0.7
0.8
0.5
0.9
0.6
1
1.1
FORWARD VOLTAGE (V)
3
Version: H2103
1.2
TSN520M60
PACKAGE OUTLINE DIMENSIONS
PDFN56
SUGGESTED PAD LAYOUT
MARKING DIAGRAM
4
P/N
= Marking Code
YW
= Date Code
F
= Factory Code
Version: H2103
TSN520M60
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf,
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability
for application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
5
Version: H2103
很抱歉,暂时无法提供与“TSN520M60 S4G”相匹配的价格&库存,您可以联系我们找货
