TSPB20U80S S1G
TSPB20U80S S1G
    TAIWANSEMICONDUCTOR(台半)
    TO277
    DIODE SCHOTTKY 80V 20A SMPC4.0
TSPB20U80S S1G 数据手册
TSPB20U80S Taiwan Semiconductor 20A, 80V Low VF Trench Schottky Surface Mount Rectifier FEATURES ● ● ● ● ● ● ● ● ● KEY PARAMETERS Patented Trench Schottky technology Excellent high temperature stability Low forward voltage Lower power loss/ high efficiency High forward surge capability Ideal for automated placement Moisture sensitivity level: level 1, per J-STD-020 RoHS Compliant Halogen-free according to IEC 61249-2-21 PARAMETER VALUE UNIT IF 20 A VRRM 80 V IFSM 200 A TJ MAX 150 °C Package SMPC4.0 Configuration Single die APPLICATIONS ● Switching mode power supply (SMPS) ● Adapters ● DC to DC converter MECHANICAL DATA ● ● ● ● ● ● Case: SMPC4.0 Molding compound meets UL 94V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Meet JESD 201 class 2 whisker test Polarity: Indicated by cathode band Weight: 0.095g (approximately) SMPC4.0 ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER SYMBOL Marking code on the device TSPB20U80S UNIT B20U80 Repetitive peak reverse voltage VRRM 80 V Reverse voltage, total rms value VR(RMS) 56 V Forward current Peak forward surge current, 8.3ms single half sine-wave superimposed on rated load Junction temperature IF 20 A IFSM 200 A TJ - 55 to +150 °C Storage temperature TSTG - 55 to +150 °C 1 Version: B2103 TSPB20U80S Taiwan Semiconductor THERMAL PERFORMANCE PARAMETER SYMBOL TYP UNIT Junction-to-lead thermal resistance RӨJL 10 °C/W Junction-to-case thermal resistance RӨJC 10 °C/W ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER CONDITIONS SYMBOL IF = 10A, TJ = 25°C Forward voltage IF = 20A, TJ = 25°C (1) IF = 10A, TJ = 125°C VF IF = 20A, TJ = 125°C Reverse current @ rated VR (2) TJ = 25°C IR TJ = 125°C TYP MAX UNIT 0.48 0.56 V 0.56 0.64 V 0.43 0.51 V 0.54 0.62 V - 300 µA - 75 mA Notes: 1. Pulse test with PW = 0.3ms 2. Pulse test with PW = 30ms ORDERING INFORMATION ORDERING CODE PACKAGE PACKING TSPB20U80S SMPC4.0 6,000 / Tape & Reel 2 Version: B2103 TSPB20U80S Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Forward Current Derating Curve Fig.2 Typical Junction Capacitance 10000 20 CAPACITANCE (pF) 15 10 1000 5 0 f=1.0MHz Vsig=50mVp-p 100 25 50 75 100 125 150 0.1 1 LEAD TEMPERATURE (°C) INSTANTANEOUS FORWARD CURRENT (A) INSTANTANEOUS REVERSE CURRENT (mA) Fig.4 Typical Forward Characteristics 100 TJ=150°C 10 TJ=125°C TJ=100°C 0.1 0.01 TJ=25°C 0.001 10 20 30 40 50 60 70 80 100 REVERSE VOLTAGE (V) Fig.3 Typical Reverse Characteristics 1 10 90 100 PERCENT OF RATED PEAK REVERSE VOLTAGE (%) 100 10 1 10 UF1DLW TJT=150°C =125°C J 0.1 TJ=25°C (A) AVERAGE FORWARD CURRENT (A) 25 TJ=125°C TJ=100°C 1 0.01 TJ=25°C 0.1 0.001 0.0 0.3 0.10.4 0.20.5 0.3 0.6 Pulse width 300μs Pulse width 1% duty cycle 0.4 0.7 0.5 0.8 0.6 0.9 0.7 1 1.1 FORWARD VOLTAGE (V) 3 Version: B2103 1.2 TSPB20U80S Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS SMPC4.0 SUGGESTED PAD LAYOUT MARKING DIAGRAM P/N = Marking Code 4 YW = Date Code F = Factory Code Version: B2103 TSPB20U80S Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 5 Version: B2103
TSPB20U80S S1G 价格&库存
很抱歉,暂时无法提供与“TSPB20U80S S1G”相匹配的价格&库存,您可以联系我们找货
