S15GC – S15MC
Taiwan Semiconductor
15A, 400V - 1000V Surface Mount Rectifier
FEATURES
KEY PARAMETERS
Glass passivated chip junction
Low forward voltage drop
Ideal for automated placement
High surge current capability
Moisture sensitivity level: level 1, per J-STD-020
RoHS Compliant
Halogen-free according to IEC 61249-2-21
APPLICATIONS
PARAMETER
VALUE
UNIT
IF
15
A
VRRM
400 - 1000
V
IFSM
350
A
TJ MAX
150
°C
Package
DO-214AB (SMC)
Configuration
Single die
● Freewheeling application
● Switching mode converters and inverters, computer and
telecommunication
MECHANICAL DATA
Case: DO-214AB (SMC)
Molding compound meets UL 94V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Meet JESD 201 class 2 whisker test
Polarity: Indicated by cathode band
Weight: 0.270g (approximately)
DO-214AB (SMC)
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
SYMBOL
Marking code on the device
S15GC S15JC S15KC S15MC UNIT
S15GC
S15JC
S15KC
S15MC
Repetitive peak reverse voltage
VRRM
400
600
800
1000
V
Reverse voltage, total rms value
VR(RMS)
280
420
560
700
V
Forward current
Peak forward surge current, 8.3ms single half
sine-wave superimposed on rated load
Junction temperature
IF
15
A
IFSM
350
A
TJ
- 55 to +150
°C
Storage temperature
TSTG
- 55 to +150
°C
1
Version: C2102
S15GC – S15MC
THERMAL PERFORMANCE
PARAMETER
SYMBOL
TYP
UNIT
Junction-to-lead thermal resistance
RӨJL
8
°C/W
Junction-to-ambient thermal resistance
RӨJA
44
°C/W
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
Forward voltage
CONDITIONS
(1)
Reverse current @ rated VR
IF = 15A, TJ = 25°C
(2)
Junction capacitance
TJ = 25°C
SYMBOL
TYP
MAX
UNIT
VF
1.1
V
1
µA
250
µA
93
pF
IR
TJ = 125°C
1MHz, VR = 4.0V
CJ
Notes:
1. Pulse test with PW = 0.3ms
2. Pulse test with PW = 30ms
ORDERING INFORMATION
ORDERING CODE(1)
PACKAGE
PACKING
S15xC
DO-214AB (SMC)
3,000 / Tape & Reel
Notes:
1. “x” defines voltage from 400V(S15GC) to 1000V(S15MC)
2
Version: C2102
S15GC – S15MC
CHARACTERISTICS CURVES
Fig.1 Forward Current Derating Curve
Fig.2 Maximum Non-Repetitive Forward Surge
Current
400
PEAK FORWARD SURGE CURRENT (A)
15
10
5
50
75
100
125
350
8.3ms single half sine wave
300
250
200
150
100
50
1
AMBIENT TEMPERATURE (°C)
INSTANTANEOUS FORWARD CURRENT (A)
INSTANTANEOUS REVERSE CURRENT (μA)
Fig.4 Typical Forward Characteristics
100
TJ=125°C
1
0.1
TJ=25°C
0.01
10
40
50
60
70
80
100
NUMBER OF CYCLES AT 60 Hz
Fig.3 Typical Reverse Characteristics
10
10
90
100
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
100 10
10
1
UF1DLW
TJT=125°C
J=125°C
TJ=25°C
0.1
1
(A)
AVERAGE FORWARD CURRENT (A)
TJ=25°C
0.01
0.1
0.001
0.4
0.3
Pulse width 300μs
1% duty cycle
Pulse width
0.6
0.4
0.5
0.8
0.6
0.7
1.0
0.8
0.9
1.2
1
1.1
FORWARD VOLTAGE (V)
3
Version: C2102
1.2
S15GC – S15MC
PACKAGE OUTLINE DIMENSIONS
DO-214AB (SMC)
SUGGESTED PAD LAYOUT
MARKING DIAGRAM
4
P/N
= Marking Code
G
= Green Compound
YW
= Date Code
F
= Factory Code
Version: C2102
S15GC – S15MC
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf,
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability
for application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
5
Version: C2102
很抱歉,暂时无法提供与“S15JCHM6G”相匹配的价格&库存,您可以联系我们找货
