BZX85C5V1 R0G
BZX85C5V1 R0G
    TAIWANSEMICONDUCTOR(台湾半导体)
    DO-204AL
    DIODE ZENER 5.1V 1.3W DO204AL
BZX85C5V1 R0G 数据手册
BZX85C3V3 - BZX85C56 Taiwan Semiconductor Small Signal Product 5% Tolerance Zener Diode FEATURES - Wide zener voltage range selection: 3.3V to 56V - VZ Tolerance selection of ±5% - Designed for through-hole device type mounting - Hermetically sealed glasss - Pb free and RoHS compliant - High reliability glass passivation insuring parameter stability and protection against junction contamination DO-41 Hermetically Sealed Glass MECHANICAL DATA - Case: DO-41 - High temperature soldering guaranteed: 260oC/10s - Polarity: Cathode indicated by polarity band - Weight : 310mg (approximately) MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS (TA=25℃ unless otherwise noted) PARAMETER Power Dissipation Forward Voltage IF = 10 mA Thermal Resistance (Junction to Ambient) Junction and Storage Temperature Range (Note 1) SYMBO PD VALUE UNIT 1.3 W VF 1.2 RθJA 130 TJ, TSTG - 65 to +200 V o C/W o C Note 1: Valid provided that electrodes are kept at ambient temerature . Zener I vs. V Characteristics VBR : Voltage at IZK IZK : Test current for voltage VBR ZZK : Dynamic impedance at IZK IZT VZ : Test current for voltage VZ : Voltage at current IZT ZZT : Dynamic impedance at IZT IZM : Maximum steady state current : Voltage at IZM VZM Version: G1606 BZX85C3V3 - BZX85C56 Taiwan Semiconductor Small Signal Product ELECTRICAL CHARACTERISTICS ( TA= 25oC unless otherwise noted ) VZ @ IZT (Volt) ZZT @ IZT (Ω) Max IZK (mA) ZZK @ IZK (Ω) Max IR @ VR(μA) Max VR (V) Min Nom Max IZT (mA) BZX85C3V3 BZX85C3V3 3.1 3.3 3.5 80 20 1 400 40 1 BZX85C3V6 BZX85C3V6 3.4 3.6 3.8 60 20 1 500 20 1 BZX85C3V9 BZX85C3V9 3.7 3.9 4.1 60 15 1 500 20 1 BZX85C4V3 BZX85C4V3 4.0 4.3 4.6 50 13 1 500 3 1 BZX85C4V7 BZX85C4V7 4.4 4.7 5.0 45 13 1 500 3 1 BZX85C5V1 BZX85C5V1 4.8 5.1 5.4 45 10 1 500 1 1.5 BZX85C5V6 BZX85C5V6 5.2 5.6 6.0 45 7 1 400 1 2 BZX85C6V2 BZX85C6V2 5.8 6.2 6.6 35 4 1 300 1 3 BZX85C6V8 BZX85C6V8 6.4 6.8 7.2 35 3.5 1 300 1 4 BZX85C7V5 BZX85C7V5 7.0 7.5 7.9 35 3 0.5 200 1 4.5 BZX85C8V2 BZX85C8V2 7.7 8.2 8.7 25 5 0.5 200 1 6.2 BZX85C9V1 BZX85C9V1 Part Number Marking Code 8.5 9.1 9.6 25 5 0.5 200 1 6.9 BZX85C10 BZX85C10 9.4 10 10.6 25 7 0.5 200 0.5 7.5 BZX85C11 BZX85C11 10.4 11 11.6 20 8 0.5 300 0.5 8.2 BZX85C12 BZX85C12 11.4 12 12.7 20 9 0.5 350 0.5 9.1 BZX85C13 BZX85C13 12.4 13 14.1 20 10 0.5 400 0.5 10 BZX85C15 BZX85C15 13.8 15 15.6 15 15 0.5 500 0.5 11 BZX85C16 BZX85C16 15.3 16 17.1 15 15 0.5 500 0.5 12 BZX85C18 BZX85C18 16.8 18 19.1 15 20 0.5 500 0.5 13 BZX85C20 BZX85C20 18.8 20 21.2 10 24 0.5 600 0.5 15 BZX85C22 BZX85C22 20.8 22 23.3 10 25 0.5 600 0.5 16 BZX85C24 BZX85C24 22.8 24 25.6 10 25 0.5 600 0.5 18 BZX85C27 BZX85C27 25.1 27 28.9 8 30 0.25 750 0.5 20 BZX85C30 BZX85C30 28.0 30 32.0 8 30 0.25 1000 0.5 22 BZX85C33 BZX85C33 31.0 33 35.0 8 35 0.25 1000 0.5 24 BZX85C36 BZX85C36 34.0 36 38.0 8 40 0.25 1000 0.5 25 BZX85C39 BZX85C39 37.0 39 41.0 6 45 0.25 1000 0.5 27 BZX85C43 BZX85C43 40.0 43 46.0 6 50 0.25 1000 0.5 30 BZX85C47 BZX85C47 44.0 47 50.0 4 90 0.25 1500 0.5 33 BZX85C51 BZX85C51 48.0 51 54.0 4 115 0.25 1500 0.5 36 BZX85C56 BZX85C56 52.0 56 60.0 4 120 0.25 2000 0.5 39 Notes: 1. The Zener Voltage (VZ) is tested under pulse condition of 10ms. 2. The device numbers listed have a standard tolerance on the nomial zener voltage of ±5%. 3. For detailed information on price, availability and delivery of nominal zener voltages between the voltages shown and tighter voltage tolerances, contact your nearest Taiwan Semiconductor representative. 4. The Zener impedance is derived from the 60-cycle ac voltage, which results when an ac current having an RMS value equal to 10% of the dc zener current(IZT or IZK) is superimposed to IZT or IZK. Version: G1606 BZX85C3V3 - BZX85C56 Taiwan Semiconductor Small Signal Product ORDERING INFORMATION PART NO. PACKING CODE BZX85Cxxx (Note1,2) R0 GREEN COMPOUND CODE PACKAGE G A0 PACKING 5K / 14" Reel DO-41 3K / Box (Ammo) Note 1: "xxx" defines voltage from 3.3V (BZX85C3V3) to 56V (BZX85C56) Note 2: Whole series with green compound. EXAMPLE PREFERRED PART NO. PART NO. BZX85C3V3 R0G BZX85C3V3 PACKING PACKING CODE CODE SUFFIX R0 G DESCRIPTION Green compound PACKAGE OUTLINE DIMENSION DIM. Unit (mm) Unit (inch) Min Max Min Max A 0.50 0.90 0.020 0.035 B 3.50 5.20 0.138 0.205 C 22.00 -- 0.866 -- D 1.80 2.80 0.071 0.110 MARKING DIAGRAM XXX XXX XXX BZX 85C XXX Version: G1606 BZX85C3V3 - BZX85C56 Taiwan Semiconductor Small Signal Product Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors inaccuracies. Information contained herein is intended to provide a product description only. No license, express or implied,to any intellectual property rights is granted by this document. Except as provided in TSC's terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or seling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. Version: G1606
BZX85C5V1 R0G
物料型号:BZX85C3V3 - BZX85C56,由台湾半导体生产。
器件简介:这些是5%容差的小信号齐纳二极管,具有3.3V至56V的宽齐纳电压范围选择,专为通孔设备类型安装设计,采用密封玻璃封装,无铅且符合RoHS标准。
引脚分配:文档中未明确指出引脚分配,但通常齐纳二极管有一个阳极和一个阴极,阴极通常由极性带指示。
参数特性: - 功率耗散:文档未提供具体数值。 - 正向电压:在10mA电流下的测试值未给出。 - 热阻(结到环境):130°C/W。 - 结温和存储温度范围:-65°C至+200°C。
功能详解:文档提供了齐纳二极管的电气特性表,包括在25°C下的最小、标称和最大齐纳电压,以及在不同测试电流下的动态阻抗和最大稳态电流。
应用信息:文档未明确提供应用信息,但齐纳二极管通常用于稳定电压、过压保护和信号钳位。
封装信息:采用DO-41封装,重量约为310毫克,高温焊接保证260°C/10秒。
订购信息:提供了不同电压等级的订购代码和包装代码,以及绿色化合物代码。
封装外形尺寸:提供了详细的封装尺寸图和标记图。
BZX85C5V1 R0G 价格&库存
很抱歉,暂时无法提供与“BZX85C5V1 R0G”相匹配的价格&库存,您可以联系我们找货
BZX85C5V1 R0G
    • 96+0.8586796+0.11130
    • 477+0.57245477+0.07420
    • 5715+0.429345715+0.05565
    库存:8000
    BZX85C5V1 R0G
    • 1+3.773101+0.48840
    • 10+2.5633010+0.33180
    • 100+1.62900100+0.21090
    • 500+1.02530500+0.13270
    • 1000+0.894801000+0.11580
    • 2500+0.789402500+0.10220
    • 5000+0.570205000+0.07380
    • 10000+0.4911010000+0.06360
    • 25000+0.4384025000+0.05680
    库存:4978
    BZX85C5V1 R0G
