S1AB – S1MB
Taiwan Semiconductor
1A, 50V - 1000V Standard Surface Mount Rectifier
FEATURES
KEY PARAMETERS
Glass passivated chip junction
Ideal for automated placement
Low forward voltage drop
High surge current capability
Moisture sensitivity level: level 1, per J-STD-020
RoHS Compliant
Halogen-free according to IEC 61249-2-21
PARAMETER
VALUE
UNIT
IF
1
A
VRRM
50 - 1000
V
IFSM
30
A
TJ MAX
150
°C
APPLICATIONS
Package
DO-214AA (SMB)
Configuration
Single die
Switching mode power supply (SMPS)
Adapters
Lighting application
Converter
MECHANICAL DATA
Case: DO-214AA (SMB)
Molding compound meets UL 94V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Meet JESD 201 class 2 whisker test
Polarity: Indicated by cathode band
Weight: 0.090g (approximately)
DO-214AA (SMB)
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
SYMBOL S1AB S1BB S1DB S1GB S1JB S1KB S1MB UNIT
Marking code on the device
Repetitive peak reverse voltage
VRRM
50
100
200
400
600
800
1000
V
Reverse voltage, total rms value
VR(RMS)
35
70
140
280
420
560
700
V
Forward current
Surge peak forward current, 8.3ms
single half sine-wave superimposed
on rated load
Junction temperature
IF
1
A
IFSM
30
A
TJ
- 55 to +150
°C
Storage temperature
TSTG
- 55 to +150
°C
1
Version: I2102
S1AB – S1MB
THERMAL PERFORMANCE
PARAMETER
SYMBOL
TYP
UNIT
RӨJL
30
°C/W
Junction-to-lead thermal resistance
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
Forward voltage
CONDITIONS
(1)
Reverse current @ rated VR
IF = 1A,TJ = 25°C
(2)
Junction capacitance
TJ = 25°C
TJ = 125°C
1MHz, VR = 4.0V
SYMBOL
TYP
MAX
UNIT
VF
1.1
V
5
µA
50
µA
12
pF
IR
CJ
Notes:
1. Pulse test with PW = 0.3ms
2. Pulse test with PW = 30ms
ORDERING INFORMATION
ORDERING CODE(1)
PACKAGE
PACKING
S1xB
DO-214AA (SMB)
3,000 / Tape & Reel
Notes:
1. "x" defines voltage from 50V(S1AB) to 1000V(S1MB)
2
Version: I2102
S1AB – S1MB
CHARACTERISTICS CURVES
Fig.1 Forward Current Derating Curve
Fig.2 Typical Junction Capacitance
100
1
CAPACITANCE (pF)
AVERAGE FORWARD CURRENT (A)
1.2
0.8
0.6
0.4
10
0.2
f=1.0MHz
Vsig=50mVp-p
1
50
75
100
125
0.01
150
0.1
1
10
REVERSE VOLTAGE (V)
LEAD TEMPERATURE (°C)
Fig.4 Typical Forward Characteristics
TJ=125°C
1
0.1
TJ=75°C
0.01
TJ=25°C
0.001
40
50
60
70
80
90
100
100
10
UF1DLW
1
10
TJ=125°C
1
0.01
0.001
0.1
0.3
0.6
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
TJ=25°C
0.1
(A)
10
INSTANTANEOUS FORWARD CURRENT (A)
INSTANTANEOUS REVERSE CURRENT (μA)
Fig.3 Typical Reverse Characteristics
100
0.4
0.8
0.5
0.6
1
0.7
1.2
Pulse width
Pulse width=300μs
1% duty cycle
0.8
0.9
1
1.1
1.4
1.6
1.8
FORWARD VOLTAGE (V)
3
Version: I2102
1.2
S1AB – S1MB
Fig.5 Maximum Non-Repetitive Forward Surge Current
PEAK FORWARD SURGE CURRENT (A)
40
8.3ms single half sine wave
30
10
100
NUMBER OF CYCLES AT 60 Hz
4
Version: I2102
S1AB – S1MB
PACKAGE OUTLINE DIMENSIONS
DO-214AA (SMB)
SUGGESTED PAD LAYOUT
MARKING DIAGRAM
5
P/N
= Marking Code
G
= Green Compound
YW
= Date Code
F
= Factory Code
Version: I2102
S1AB – S1MB
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf,
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability
for application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
6
Version: I2102
很抱歉,暂时无法提供与“S1GBHR5G”相匹配的价格&库存,您可以联系我们找货
