MBR735 – MBR7150
Taiwan Semiconductor
7.5A, 35V - 150V Schottky Barrier Rectifier
FEATURES
KEY PARAMETERS
AEC-Q101 qualified available
Low power loss, high efficiency
Guard ring for overvoltage protection
High surge current capability
RoHS Compliant
Halogen-free according to IEC 61249-2-21
APPLICATIONS
● Switching mode power supply (SMPS)
● Adapters
● DC to DC converters
PARAMETER
VALUE
UNIT
IF
7.5
A
VRRM
35 - 150
V
IFSM
150
A
TJ MAX
150
°C
Package
TO-220AC
Configuration
Single die
MECHANICAL DATA
Case: TO-220AC
Molding compound meets UL 94V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Mounting torque: 0.56 N⋅m maximum
Meet JESD 201 class 2 whisker test
Polarity: As marked
Weight: 1.85g (approximately)
TO-220AC
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
Repetitive peak reverse voltage
VRRM
MBR
735
MBR
735
35
Reverse voltage, total rms value
VR(RMS)
24
Forward current
Surge peak forward current
8.3ms single half sine wave
superimposed on rated load
Peak repetitive forward current
(Rated VR, Square Wave, 20KHz)
Peak repetitive reverse surge
(1)
current
Voltage rate of change (Rated VR)
IF
7.5
A
IFSM
150
A
IFRM
15
A
PARAMETER
SYMBOL
Marking code on the device
IRRM
MBR
745
MBR
745
45
MBR
750
MBR
750
50
MBR
760
MBR
760
60
MBR
790
MBR
790
90
MBR
7100
MBR
7100
100
31
35
42
63
70
1
0.5
MBR
UNIT
7150
MBR
7150
150
V
105
V
A
dV/dt
10,000
V/µs
Junction temperature
TJ
-55 to +150
°C
Storage temperature
TSTG
-55 to +175
°C
Notes:
1. tp = 2.0μs, 1.0KHz
1
Version: K2103
MBR735 – MBR7150
THERMAL PERFORMANCE
PARAMETER
SYMBOL
TYP
UNIT
Junction-to-ambient resistance
RӨJA
15
°C/W
Junction-to-case resistance
RӨJC
5
°C/W
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
Forward voltage
CONDITIONS
(1)
Reverse current @ rated VR
(2)
MBR735
MBR745
MBR750
MBR760
MBR790
MBR7100
MBR7150
MBR735
MBR745
MBR750
MBR760
MBR790
MBR7100
MBR7150
MBR735
MBR745
MBR750
MBR760
MBR790
MBR7100
MBR7150
MBR735
MBR745
MBR750
MBR760
MBR790
MBR7100
MBR7150
MBR735
MBR745
MBR750
MBR760
MBR790
MBR7100
MBR7150
MBR735
MBR745
MBR750
MBR760
MBR790
MBR7100
MBR7150
SYMBOL
IF = 7.5A, TJ = 25°C
IF = 15A, TJ = 25°C
VF
IF = 7.5A, TJ = 125°C
IF = 15A, TJ = 125°C
TJ = 25°C
TYP
MAX
UNIT
V
0.75
V
0.92
V
0.95
V
0.84
V
V
V
V
0.57
V
0.65
V
0.82
V
0.92
V
0.72
V
V
V
V
100
µA
15
mA
10
mA
5
mA
IR
TJ = 125°C
Notes:
1. Pulse test with PW = 0.3ms
2. Pulse test with PW = 30ms
2
Version: K2103
MBR735 – MBR7150
ORDERING INFORMATION
ORDERING CODE(1)(2)
PACKAGE
PACKING
MBR7x
TO-220AC
50 / Tube
MBR7xH
TO-220AC
50 / Tube
Notes:
1. “x” defines voltage from 35V(MBR735) to 150V(MBR7150)
2. “H” means AEC-Q101 qualified
3
Version: K2103
MBR735 – MBR7150
CHARACTERISTICS CURVES
Fig.1 Forward Current Derating Curve
Fig.2 Typical Junction Capacitance
1000
MBR750-MBR7150
7
MBR735-MBR745
6
5
CAPACITANCE (pF)
MBR735-MBR745
4
3
MBR750-MBR760
100
MBR790-MBR7150
2
1
f=1.0MHz
Vsig=50mVp-p
10
25
50
75
100
125
150
0.1
CASE TEMPERATURE (°C)
INSTANTANEOUS FORWARD CURRENT (A)
TJ=75°C
0.1
TJ=25°C
0.001
10
40
50
60
70
80
90
100
100
10
MBR735-MBR745
MBR750-MBR760
UF1DLW
1 MBR790-MBR7150
10
TJ=125°C
TJ=125°C
TJ=25°C
0.1
1
0.01
TJ=25°C
Pulse widthPulse
300μs
1% duty cycle width
0.001
0.1
0.4 0.3 0.5
0.60.6 0.7 0.80.8
0 0.3
0.1 0.2
0.4 0.5
0.9 0.9
1 1.1 11.2
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
1.1
FORWARD VOLTAGE (V)
Fig.5 Maximum Non-Repetitive Forward Surge Current
180
PEAK FORWARD SURGE CURRENT (A)
INSTANTANEOUS REVERSE CURRENT (mA)
TJ=125°C
1
0.01
100
Fig.4 Typical Forward Characteristics
100
10
10
REVERSE VOLTAGE (V)
Fig.3 Typical Reverse Characteristics
MBR735-MBR745
MBR750-MBR7150
1
(A)
AVERAGE FORWARD CURRENT (A)
8
150
120
90
60
30
10
100
NUMBER OF CYCLES AT 60 Hz
4
Version: K2103
1.2
MBR735 – MBR7150
Fig.6 Typical Transient Thermal Impedance
TRANSIENT THERMAL IMPEDANCE (°C/W)
10
1
0.1
0.01
0.1
1
10
100
PULSE DURATION (s)
5
Version: K2103
MBR735 – MBR7150
PACKAGE OUTLINE DIMENSIONS
TO-220AC
MARKING DIAGRAM
6
P/N
= Marking Code
G
= Green Compound
YWW
= Date Code
F
= Factory Code
Version: K2103
MBR735 – MBR7150
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability
for application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
7
Version: K2103
很抱歉,暂时无法提供与“MBR7150HC0G”相匹配的价格&库存,您可以联系我们找货
