TSSE3U45 – TSSE3U60
Taiwan Semiconductor
3A, 45V - 60V Low VF Trench Schottky Surface Mount Rectifier
FEATURES
KEY PARAMETERS
Patented Trench Schottky technology
Excellent high temperature stability
Low forward voltage
Lower power loss/ high efficiency
High forward surge capability
Moisture sensitivity level: level 1, per J-STD-020
RoHS Compliant
Halogen-free according to IEC 61249-2-21
PARAMETER
VALUE
UNIT
IF
3
A
VRRM
45 - 60
V
IFSM
80
A
TJ MAX
150
°C
Package
SOD-123HE
Configuration
Single die
APPLICATIONS
● Switching mode power supply (SMPS)
● Adapters
● DC to DC converter
MECHANICAL DATA
Case: SOD-123HE
Molding compound meets UL 94V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Meet JESD 201 class 2 whisker test
Polarity: Indicated by cathode band
Weight: 0.022g (approximately)
SOD-123HE
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
SYMBOL
Marking code on the device
TSSE3U45
TSSE3U60
E3U45
E3U60
UNIT
Repetitive peak reverse voltage
VRRM
45
60
V
Reverse voltage, total rms value
VR(RMS)
32
42
V
Forward current
Peak forward surge current, 8.3ms single half
sine-wave superimposed on rated load
Junction temperature
IF
3
A
IFSM
80
A
TJ
- 55 to +150
°C
Storage temperature
TSTG
- 55 to +150
°C
1
Version: I2103
TSSE3U45 – TSSE3U60
THERMAL PERFORMANCE
PARAMETER
SYMBOL
TYP
UNIT
Junction-to-lead thermal resistance
RӨJL
23
°C/W
Junction-to-ambient thermal resistance
RӨJA
70
°C/W
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
CONDITIONS
TSSE3U45
Forward voltage
MAX
UNIT
IF = 1A, TJ = 25°C
0.33
V
IF = 3A, TJ = 25°C
0.40
0.47
V
IF = 1A, TJ = 125°C
0.24
V
0.34
0.44
V
0.39
V
IF = 3A, TJ = 25°C
0.49
0.58
V
IF = 1A, TJ = 125°C
0.28
V
IF = 3A, TJ = 125°C
0.43
0.52
V
1
mA
50
mA
IF = 1A, TJ = 25°C
TSSE3U60
Reverse current @ rated VR
TYP
IF = 3A, TJ = 125°C
(1)
(2)
TJ = 25°C
SYMBOL
VF
IR
TJ = 125°C
Notes:
1. Pulse test with PW = 0.3ms
2. Pulse test with PW = 30ms
ORDERING INFORMATION
ORDERING CODE(1)
PACKAGE
PACKING
TSSE3Ux
SOD-123HE
10,000 / Tape & Reel
Notes:
1. “x” defines voltage from 45V(TSSE3U45) to 60V(TSSE3U60)
2
Version: I2103
TSSE3U45 – TSSE3U60
CHARACTERISTICS CURVES
Fig.1 Forward Current Derating Curve
Fig.2 Typical Junction Capacitance
10000
CAPACITANCE (pF)
3
2
1
1000
100
f=1.0MHz
Vsig=50mVp-p
10
75
100
125
0.1
150
1
LEAD TEMPERATURE (°C)
INSTANTANEOUS FORWARD CURRENT (A)
INSTANTANEOUS REVERSE CURRENT (mA)
Fig.4 Typical Forward Characteristics
100
TJ=125°C
10
TJ=100°C
1
0.1
TJ=25°C
0.01
10
40
50
60
70
80
90
100
1010
TSSE3U45
1
UF1DLW
TJ=125oC
1
TJ=125°C
0.1
0.1
TJ=25oC
0.01
0.01
0.001
0.0
0.3
Pulse width 300μs
1% duty cycle
Pulse width
0.1
0.4
TSSE3U60
TJ=125°C
TJ=100°C
0.1
TJ=25°C
0.01
40
50
60
70
80
90
0.3
0.4
0.6
0.7
0.8
0.5
0.9
0.6
1
1.1
1.2
1.1
1.2
Fig.6 Typical Forward Characteristics
100
10
0.2
0.5
FORWARD VOLTAGE (V)
Fig.5 Typical Reverse Characteristics
1
TJ=25°C
TJ=100oC
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
10
100
REVERSE VOLTAGE (V)
Fig.3 Typical Reverse Characteristics
TSSE3U45
10
(A)
25
100
1010
TSSE3U60
1
1
UF1DLW
TJ=125oC
TJ=125°C
TJ=25°C
0.1
0.1
0.01
(A)
AVERAGE FORWARD CURRENT (A)
4
TJ=100oC
TJ=25oC
Pulse width 300μs
1% duty cycle
Pulse width
0.01
0.001
0.0 0.1 0.2 0.3 0.4 0.5 0.6 0.7
0.3
0.4
0.5
0.6
0.7
0.8
0.9
0.8
1
FORWARD VOLTAGE (V)
3
Version: I2103
TSSE3U45 – TSSE3U60
PACKAGE OUTLINE DIMENSIONS
SOD-123HE
SUGGESTED PAD LAYOUT
MARKING DIAGRAM
4
P/N
= Marking Code
YW
= Date Code
F
= Factory Code
Version: I2103
TSSE3U45 – TSSE3U60
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf,
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability
for application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
5
Version: I2103
很抱歉,暂时无法提供与“TSSE3U60HRVG”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+11.716181+1.52095
- 10+7.3897210+0.95931
- 100+4.88757100+0.63449
- 500+3.81260500+0.49494
- 1000+3.466531000+0.45002
- 国内价格 香港价格
- 1+11.706001+1.51963
- 10+7.3833010+0.95848
- 100+4.88332100+0.63394
- 500+3.80933500+0.49452
- 1000+3.463551000+0.44963
