MUR360SBHR5G
MUR360SBHR5G
    TAIWANSEMICONDUCTOR(台湾半导体)
    DO214AA
    DIODE GEN PURP 600V 3A DO214AA
MUR360SBHR5G 数据手册
MUR305SB – MUR320SB Taiwan Semiconductor 3A, 50 - 200V Ultra Fast Surface Mount Power Rectifier FEATURES ● ● ● ● ● ● KEY PARAMETERS Glass passivated chip junction Ideal for automated placement Ultra Fast recovery time for high efficiency Moisture sensitivity level: level 1, per J-STD-020 RoHS Compliant Halogen-free according to IEC 61249-2-21 APPLICATIONS ● ● ● ● Switching mode power supply (SMPS) Adapters Monitor TV PARAMETER VALUE UNIT IF 3 A VRRM 50 - 200 V IFSM 75 A TJ MAX 175 °C Package DO-214AA (SMB) Configuration Single die MECHANICAL DATA ● ● ● ● ● ● Case: DO-214AA (SMB) Molding compound meets UL 94V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Meet JESD 201 class 2 whisker test Polarity: Indicated by cathode band Weight: 0.110g (approximately) DO-214AA (SMB) ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER SYMBOL Marking code on the device MUR305 MUR310 MUR315 MUR320 SB SB SB SB UNIT MUR305SB MUR310SB MUR315SB MUR320SB Repetitive peak reverse voltage VRRM 50 100 150 200 V Reverse voltage, total rms value VR(RMS) 35 70 105 140 V Forward current Surge peak forward current, 8.3ms single half sine-wave superimposed on rated load Junction temperature IF 3 A IFSM 75 A TJ - 55 to +175 °C Storage temperature TSTG - 55 to +175 °C 1 Version: C2102 MUR305SB – MUR320SB Taiwan Semiconductor THERMAL PERFORMANCE PARAMETER SYMBOL TYP UNIT Junction-to-lead thermal resistance RӨJL 42 °C/W Junction-to-ambient thermal resistance RӨJA 76 °C/W Junction-to-case thermal resistance RӨJC 45 °C/W Thermal Performance Note: Units mounted on PCB (10mm x 10mm Cu pad test board) ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER CONDITIONS SYMBOL TYP MAX UNIT 0.79 0.85 V 0.86 0.90 V 0.61 0.68 V 0.69 0.73 V - 5 µA - 150 µA CJ 45 - pF trr - 25 ns IF = 1.5A, TJ = 25°C Forward voltage IF = 3.0A, TJ = 25°C (1) IF = 1.5A, TJ = 150°C VF IF = 3.0A, TJ = 150°C Reverse current @ rated VR (2) Junction capacitance Reverse recovery time TJ = 25°C IR TJ = 150°C 1MHz, VR = 4.0V IF = 0.5A, IR = 1.0A, Irr = 0.25A Notes: 1. Pulse test with PW = 0.3ms 2. Pulse test with PW = 30ms ORDERING INFORMATION ORDERING CODE(1) PACKAGE PACKING MUR3xSB DO-214AA (SMB) 3,000 / Tape & Reel Notes: 1. "x" defines voltage from 50V(MUR305SB) to 200V(MUR320SB) 2 Version: C2102 MUR305SB – MUR320SB Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Forward Current Derating Curve Fig.2 Typical Junction Capacitance 1000 AVERAGE FORWARD CURRENT (A) 4 CAPACITANCE (pF) A 3 2 1 0 25 50 75 100 125 150 100 f=1.0MHz Vsig=50mVp-p 10 175 1 LEAD TEMPERATURE (°C) 10 100 REVERSE VOLTAGE (V) Fig.4 Typical Forward Characteristics 10 INSTANTANEOUS FORWARD CURRENT (A) INSTANTANEOUS REVERSE CURRENT (μA) Fig.3 Typical Reverse Characteristics TJ=150°C 1 0.1 TJ=25°C 0.01 10 20 30 40 50 60 70 80 90 100 100 10 TJ=150°C 1 TJ=25°C Pulse width 300μs 1% duty cycle 0.1 0.4 PERCENT OF RATED PEAK REVERSE VOLTAGE (%) 3 0.5 0.6 0.7 0.8 0.9 1 FORWARD VOLTAGE (V) 1.1 Version: C2102 1.2 MUR305SB – MUR320SB Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS DO-214AA (SMB) SUGGESTED PAD LAYOUT MARKING DIAGRAM 4 P/N = Marking Code G = Green Compound YW = Date Code F = Factory Code Version: C2102 MUR305SB – MUR320SB Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 5 Version: C2102
MUR360SBHR5G 价格&库存
很抱歉,暂时无法提供与“MUR360SBHR5G”相匹配的价格&库存,您可以联系我们找货
