GC02MPS12-220
GC02MPS12-220
    GENESICSEMICONDUCTOR
    TO-220-2
    GC02MPS12-220
GC02MPS12-220 数据手册
GC02MPS12-220 1200V 2A SiC Schottky MPS™ Diode TM Silicon Carbide Schottky Diode VRRM = IF (TC = 164°C) = QC = Features • • • • • • • • Package Low VF for High Temperature Operation Enhanced Surge and Avalanche Robustness Superior Figure of Merit QC/IF Low Thermal Resistance Low Reverse Leakage Current Temperature Independent Fast Switching Positive Temperature Coefficient of VF High dV/dt Ruggedness Case RoHS TO-220-2 Advantages • • • • • • • • 1200 V 2A 11 nC K REACH A Applications Improved System Efficiency High System Reliability Optimal Price Performance Reduced Cooling Requirements Increased System Power Density Zero Reverse Recovery Current Easy to Parallel without Thermal Runaway Enables Extremely Fast Switching • • • • • • • • High Voltage Sensing Solar Inverters Electric Vehicles High Frequency Converters Battery Chargers AC/DC Power Supplies Anti-Parallel / Free-Wheeling Diode LED and HID Lighting Absolute Maximum Ratings (At TC = 25°C Unless Otherwise Stated) Parameter Repetitive Peak Reverse Voltage Continuous Forward Current Symbol VRRM IF Non-Repetitive Peak Forward Surge Current, Half Sine Wave IF,SM Repetitive Peak Forward Surge Current, Half Sine Wave IF,RM Non-Repetitive Peak Forward Surge Current i2t Value Non-Repetitive Avalanche Energy Diode Ruggedness Power Dissipation Operating and Storage Temperature Rev 21/Jul IF,MAX ∫i2dt EAS dV/dt PTOT T j , T stg Conditions TC = 100°C, D = 1 TC = 135°C, D = 1 TC = 164°C, D = 1 TC = 25°C, tP = 10 ms TC = 150°C, tP = 10 ms TC = 25°C, tP = 10 ms TC = 150°C, tP = 10 ms TC = 25°C, tP = 10 µs TC = 25°C, tP = 10 ms L = 18.0 mH, IAS = 2 A VR = 0 ~ 960 V TC = 25°C Values 1200 6 4 2 20 16 12 8 100 2.0 36 200 54 -55 to 175 Latest Version at: www.genesicsemi.com/sic-schottky-mps/GC02MPS12-220/GC02MPS12-220.pdf Unit V Note A Fig. 4 A A A A2s mJ V/ns W °C Fig. 3 Page 1 of 7 GC02MPS12-220 1200V 2A SiC Schottky MPS™ Diode TM Electrical Characteristics Parameter Symbol Diode Forward Voltage VF Reverse Current IR Total Capacitive Charge QC Switching Time tS Total Capacitance C Conditions Min. IF = 2 A, Tj = 25°C IF = 2 A, Tj = 175°C VR = 1200 V, Tj = 25°C VR = 1200 V, Tj = 175°C VR = 400 V VR = 800 V IF ≤ IF,MAX dIF/dt = 200 A/µs VR = 400 V VR = 800 V VR = 1 V, f = 1MHz VR = 800 V, f = 1MHz Values Typ. 1.5 1.9 1 3 7 11 Max. 1.8 5 Unit Note V Fig. 1 µA Fig. 2 nC Fig. 7 < 10 ns 122 7 pF Fig. 6 Unit Note °C/W g Nm Fig. 9 Thermal/Package Characteristics Parameter Symbol Thermal Resistance, Junction - Case Weight Mounting Torque Rev 21/Jul RthJC WT TM Conditions Screws to Heatsink Min. Values Typ. 2.79 2.0 Max. 1.0 Latest Version at: www.genesicsemi.com/sic-schottky-mps/GC02MPS12-220/GC02MPS12-220.pdf Page 2 of 7 GC02MPS12-220 1200V 2A SiC Schottky MPS™ Diode Figure 1: Typical Forward Characteristics I F = f(VF,Tj); tP = 250 µs Figure 3: Power Derating Curves PTOT = f(TC ); Tj = 175°C Rev 21/Jul TM Figure 2: Typical Reverse Characteristics I R = f(VR,Tj) Figure 4: Current Derating Curves (Typical VF) I F = f(TC ); D = tP/T; Tj ≤ 175°C; fSW > 10kHz Latest Version at: www.genesicsemi.com/sic-schottky-mps/GC02MPS12-220/GC02MPS12-220.pdf Page 3 of 7 GC02MPS12-220 1200V 2A SiC Schottky MPS™ Diode Figure 5: Current Derating Curves (Maximum VF) I F = f(TC ); D = tP/T; Tj ≤ 175°C; fSW > 10kHz Figure 7: Typical Capacitive Charge vs Reverse Voltage Characteristics QC = f(VR); f = 1MHz Rev 21/Jul TM Figure 6: Typical Junction Capacitance vs Reverse Voltage Characteristics C = f(VR); f = 1MHz Figure 8: Typical Capacitive Energy vs Reverse Voltage Characteristics EC = f(VR); f = 1MHz Latest Version at: www.genesicsemi.com/sic-schottky-mps/GC02MPS12-220/GC02MPS12-220.pdf Page 4 of 7 GC02MPS12-220 1200V 2A SiC Schottky MPS™ Diode TM Figure 9: Transient Thermal Impedance Zth,jc = f(tP,D); D = tP/T Figure 10: Forward Curve Model Forward Curve Model Equation: I F = (VF - VBI)/RDIFF (A) Built-In Voltage (VBI): VBI(Tj) = m × Tj + n (V) m = -0.00123 (V/°C) n = 0.995 (V) Differential Resistance (RDIFF): 1/RDIFF RDIFF(Tj) = a × Tj2 + b × Tj + c (Ω) a = 5.96e-06 (Ω/°C2) b = 0.000846 (Ω/°C) c = 0.251 (Ω) VBI Forward Power Loss Equation: PLOSS = VBI(Tj) × I AVG + RDIFF(Tj) × I RMS2 I F = f(VF,Tj) Rev 21/Jul Latest Version at: www.genesicsemi.com/sic-schottky-mps/GC02MPS12-220/GC02MPS12-220.pdf Page 5 of 7 GC02MPS12-220 1200V 2A SiC Schottky MPS™ Diode TM Package Dimensions TO-220-2 Package Outline 0.102 (2.60) 0.118 (3.00) 0.392 (9.96) 0.408 (10.36) Ø 0.148 (3.750) 0.155 (3.930) 0.167(4.24) 0.183(4.64) 0.045(1.15) 0.055(1.40) 0.254 (6.45) 0.579 0.630 (14.70) (16.00) 0.501 (12.73) 0.347 0.355 (8.82) (9.02) 0.306 (7.77) 0.047(1.20) 0.067(1.70) 0.157(4.00) MAX. 0.530(13.47) 0.550(13.97) 0.091 (2.30) 0.106 (2.70) 0.027(0.70) 0.035(0.90) 0.016(0.40) 0.237(0.60) 0.100 BSC. (2.540) BSC. Recommended Solder Pad Layout Package View Case (K) 0.12 (3.1) 0.20 (5.1) 0.05 (1.3) K A NOTE 1. CONTROLLED DIMENSION IS INCH. DIMENSION IN BRACKET IS MILLIMETER. 2. DIMENSIONS DO NOT INCLUDE END FLASH, MOLD FLASH, MATERIAL PROTRUSIONS. Rev 21/Jul Latest Version at: www.genesicsemi.com/sic-schottky-mps/GC02MPS12-220/GC02MPS12-220.pdf Page 6 of 7 GC02MPS12-220 1200V 2A SiC Schottky MPS™ Diode TM Compliance RoHS Compliance The levels of RoHS restricted materials in this product are below the maximum concentration values (also referred to as the threshold limits) permitted for such substances, or are used in an exempted application, in accordance with EU Directive 2011/65/EC (RoHS 2), as adopted by EU member states on January 2, 2013 and amended on March 31, 2015 by EU Directive 2015/863. RoHS Declarations for this product can be obtained from your GeneSiC representative. REACH Compliance REACH substances of high concern (SVHCs) information is available for this product. Since the European Chemical Agency (ECHA) has published notice of their intent to frequently revise the SVHC listing for the foreseeable future, please contact a GeneSiC representative to insure you get the most up-to-date REACH SVHC Declaration. REACH banned substance information (REACH Article 67) is also available upon request. Disclaimer GeneSiC Semiconductor, Inc. reserves right to make changes to the product specifications and data in this document without notice. GeneSiC disclaims all and any warranty and liability arising out of use or application of any product. No license, express or implied to any intellectual property rights is granted by this document. Unless otherwise expressly indicated, GeneSiC products are not designed, tested or authorized for use in life-saving, medical, aircraft navigation, communication, air traffic control and weapons systems, nor in applications where their failure may result in death, personal injury and/or property damage. Related Links • SPICE Models: https://www.genesicsemi.com/sic-schottky-mps/GC02MPS12-220/GC02MPS12-220_SPICE.zip • PLECS Models: https://www.genesicsemi.com/sic-schottky-mps/GC02MPS12-220/GC02MPS12-220_PLECS.zip • CAD Models: https://www.genesicsemi.com/sic-schottky-mps/GC02MPS12-220/GC02MPS12-220_3D.zip • Evaluation Boards: https://www.genesicsemi.com/technical-support • Reliability: https://www.genesicsemi.com/reliability • Compliance: https://www.genesicsemi.com/compliance • Quality Manual: https://www.genesicsemi.com/quality Revision History • Rev 21/Jul: Updated with most recent test data • Supersedes: Rev 19/Apr, Rev 20/Apr, Rev 20/Aug www.genesicsemi.com/sic-schottky-mps/ Rev 21/Jul Copyright© 2021 GeneSiC Semiconductor Inc. All Rights Reserved. Published by GeneSiC Semiconductor, Inc. 43670 Trade Center Place Suite 155, Dulles, VA 20166; USA Page 7 of 7
GC02MPS12-220
物料型号为GC02MPS12-220,是一款1200V 2A SiC Schottky MPS™二极管。
器件简介: - 这是一款硅碳化物(SiC)肖特基(MPS™)二极管,具有低正向电压降、高浪涌和雪崩鲁棒性、优越的Q/Ic比率、低热阻、低反向漏电流、正温度系数的VF、高dv/dt鲁棒性。
引脚分配: - 该二极管采用TO-220-2封装,具体引脚分配在文档中未明确说明,但通常TO-220封装的二极管有两根引脚在两侧,中间的引脚为阳极。
参数特性: - 重复峰值反向电压(VRRM):1200V - 连续正向电流(IF):在100°C时为2A,135°C时为4A,164°C时为2A - 非重复峰值正向浪涌电流(IFSM):在25°C时为20A,150°C时为16A - 重复峰值正向浪涌电流(IFRM):在25°C时为12A,150°C时为8A - 非重复峰值正向浪涌电流(IEMAX):在25°C时为100A - i2t值(Ji2dt):在25°C时为2.0A²s - 非重复雪崩能量(EAS):36mJ - 二极管鲁棒性(dV/dt):200V/ns - 功率耗散(PTOT):54W - 工作和储存温度(T,Tstg):-55至175°C
功能详解: - 该二极管具有改善的系统效率、高电压传感、高系统可靠性、太阳能逆变器、电动汽车、高频转换器、电池充电器、AC/DC电源、LED和HID照明等应用。
- 具有零反向恢复电流、易于并联且无热失控、抗并联/自由轮二极管功能,可实现极快的开关。
应用信息: - 适用于需要高效率、高可靠性和高功率密度的系统,如太阳能逆变器、电动汽车、高频转换器、电池充电器、AC/DC电源和照明系统。
封装信息: - 采用TO-220-2封装,具体尺寸和推荐焊盘布局在文档中有详细说明。
文档还包含电气特性表、热/封装特性表、正向特性图、功率降额曲线、电流降额曲线、典型反向特性图、典型结电容与反向电压特性图、典型电容电荷与反向电压特性图、典型电容能量与反向电压特性图、瞬态热阻抗、正向曲线模型方程、封装尺寸图、RoHS和REACH合规性声明、免责声明、相关链接和修订历史。
GC02MPS12-220 价格&库存
很抱歉,暂时无法提供与“GC02MPS12-220”相匹配的价格&库存,您可以联系我们找货
