S12JC M6G
S12JC M6G
    TAIWANSEMICONDUCTOR(台湾半导体)
    DO214AB
    DIODE GEN PURP 600V 12A DO214AB
S12JC M6G 数据手册
S12GCH – S12MCH Taiwan Semiconductor 12A, 400V - 1000V Surface Mount Rectifier FEATURES ● ● ● ● ● ● ● ● KEY PARAMETERS AEC-Q101 qualified Glass passivated chip junction Low forward voltage drop Ideal for automated placement High surge current capability Moisture sensitivity level: level 1, per J-STD-020 RoHS Compliant Halogen-free according to IEC 61249-2-21 PARAMETER VALUE UNIT IF 12 A VRRM 400 - 1000 V IFSM 300 A TJ MAX 150 °C Package DO-214AB (SMC) Configuration Single die APPLICATIONS ● ● ● ● ● DC to DC converter Automotive application Car lighting Snubber General purpose MECHANICAL DATA ● ● ● ● ● ● Case: DO-214AB (SMC) Molding compound meets UL 94V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Meet JESD 201 class 2 whisker test Polarity: Indicated by cathode band Weight: 0.270g (approximately) DO-214AB (SMC) ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER SYMBOL Marking code on the device S12GCH S12JCH S12KCH S12MCH UNIT S12GC S12JC S12KC S12MC Repetitive peak reverse voltage VRRM 400 600 800 1000 V Reverse voltage, total rms value VR(RMS) 280 420 560 700 V Forward current Peak forward surge current, 8.3ms single half sine-wave superimposed on rated load Junction temperature IF 12 A IFSM 300 A TJ - 55 to +150 °C Storage temperature TSTG - 55 to +150 °C 1 Version: A2102 S12GCH – S12MCH Taiwan Semiconductor THERMAL PERFORMANCE PARAMETER SYMBOL TYP UNIT Junction-to-lead thermal resistance RӨJL 9 °C/W Junction-to-ambient thermal resistance RӨJA 44 °C/W ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER Forward voltage CONDITIONS (1) Reverse current @ rated VR IF = 12A, TJ = 25°C (2) Junction capacitance TJ = 25°C SYMBOL TYP MAX UNIT VF - 1.1 V - 1 µA - 250 µA 78 - pF IR TJ = 125°C 1MHz, VR = 4.0V CJ Notes: 1. Pulse test with PW = 0.3ms 2. Pulse test with PW = 30ms ORDERING INFORMATION ORDERING CODE(1) PACKAGE PACKING S12xCH DO-214AB (SMC) 3,000 / Tape & Reel Notes: 1. “x” defines voltage from 400V(S12GCH) to 1000V(S12MCH) 2 Version: A2102 S12GCH – S12MCH Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Forward Current Derating Curve Fig.2 Maximum Non-Repetitive Forward Surge Current 350 PEAK FORWARD SURGE CURRENT (A) 12 8 4 0 0 25 50 75 100 125 8.3ms single half sine wave 300 250 200 150 100 50 0 150 1 AMBIENT TEMPERATURE (°C) INSTANTANEOUS FORWARD CURRENT (A) INSTANTANEOUS REVERSE CURRENT (μA) Fig.4 Typical Forward Characteristics 100 TJ=125°C 1 0.1 TJ=25°C 0.01 10 20 30 40 50 60 70 80 100 NUMBER OF CYCLES AT 60 Hz Fig.3 Typical Reverse Characteristics 10 10 90 100 PERCENT OF RATED PEAK REVERSE VOLTAGE (%) 100 10 10 1 UF1DLW T =125°C TJJ=125°C TJ=25°C 0.1 1 (A) AVERAGE FORWARD CURRENT (A) 16 TJ=25°C 0.01 0.1 0.001 0.4 0.3 Pulse width 300μs 1% duty cycle Pulse width 0.6 0.4 0.5 0.8 0.6 0.7 1.0 0.8 0.9 1.2 1 1.1 FORWARD VOLTAGE (V) 3 Version: A2102 1.2 S12GCH – S12MCH Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS DO-214AB (SMC) SUGGESTED PAD LAYOUT MARKING DIAGRAM 4 P/N = Marking Code G = Green Compound YW = Date Code F = Factory Code Version: A2102 S12GCH – S12MCH Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 5 Version: A2102
S12JC M6G
物料型号:S12GCH至S12MCH系列整流器
器件简介:这些整流器通过了AEC-Q101认证,具有玻璃钝化芯片结,低正向电压降,适合自动化安装,具有高浪涌电流能力,符合RoHS标准,无卤素。
引脚分配:文档中提供了DO-214AB(SMC)封装的引脚图,其中阳极和阴极的位置被清晰标示。
参数特性:关键参数包括正向电流IF为12A,正向电压降VF最大为1.1V,反向电流IR在额定VR时最大为1μA,结电容C在1MHz和4.0V反向电压下为78pF。
功能详解:文档提供了热性能参数,如结到引线热阻ReJL为9°C/W,结到环境热阻ReJA为44°C/W。电气规格包括正向电压、反向电流和结电容等。
应用信息:适用于DC-DC转换器、汽车应用、汽车照明、消振器和一般用途。
封装信息:封装类型为DO-214AB(SMC),重量约为0.270g,符合UL 94V-0可燃性等级,终端为镀锡的引线,符合J-STD-002可焊性标准。
S12JC M6G 价格&库存
很抱歉,暂时无法提供与“S12JC M6G”相匹配的价格&库存,您可以联系我们找货
