RS2AA – RS2MA
Taiwan Semiconductor
1.5A, 50V - 1000V Fast Recovery Surface Mount Rectifier
FEATURES
KEY PARAMETERS
Glass passivated chip junction
Ideal for automated placement
Fast switching for high efficiency
Moisture sensitivity level: level 1, per J-STD-020
RoHS Compliant
Halogen-free according to IEC 61249-2-21
APPLICATIONS
DC to DC converter
Switching mode converters and inverters
Lighting application
Snubber
General purpose
PARAMETER
VALUE
UNIT
IF
1.5
A
VRRM
50 - 1000
V
IFSM
50
A
TJ MAX
150
°C
Package
DO-214AC (SMA)
Configuration
Single die
MECHANICAL DATA
Case: DO-214AC (SMA)
Molding compound meets UL 94V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Meet JESD 201 class 2 whisker test
Polarity: Indicated by cathode band
Weight: 0.060g (approximately)
DO-214AC (SMA)
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
Repetitive peak reverse voltage
VRRM
RS
2AA
RS
2AA
50
Reverse voltage, total rms value
VR(RMS)
35
PARAMETER
SYMBOL
Marking code on the device
RS
2BA
RS
2BA
100
RS
2DA
RS
2DA
200
RS
2GA
RS
2GA
400
RS
2JA
RS
2JA
600
RS
2KA
RS
2KA
800
70
140
280
420
560
RS
UNIT
2MA
RS
2MA
1000
V
700
V
Forward current
Peak forward surge current,
8.3ms single half sine wave
superimposed on rated load
Junction temperature
IF
1.5
A
IFSM
50
A
TJ
- 55 to +150
°C
Storage temperature
TSTG
- 55 to +150
°C
1
Version: H2102
RS2AA – RS2MA
THERMAL PERFORMANCE
PARAMETER
SYMBOL
TYP
UNIT
Junction-to-lead thermal resistance
RӨJL
18
°C/W
Junction-to-ambient thermal resistance
RӨJA
55
°C/W
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
Forward voltage
CONDITIONS
(1)
Reverse current @ rated VR
IF = 1.5A, TJ = 25°C
TJ = 25°C
(2)
Reverse recovery time
1MHz, VR = 4.0V
RS2AA
RS2BA
RS2DA
RS2GA
RS2JA
RS2KA
RS2MA
TYP
MAX
UNIT
VF
1.3
V
5
µA
200
µA
50
pF
150
ns
250
ns
500
ns
IR
TJ = 125°C
Junction capacitance
SYMBOL
IF = 0.5A, IR = 1.0A,
Irr = 0.25A
CJ
trr
Notes:
1. Pulse test with PW = 0.3ms
2. Pulse test with PW = 30ms
ORDERING INFORMATION
ORDERING CODE(1)
PACKAGE
PACKING
RS2xA
DO-214AC (SMA)
7,500 / Tape & Reel
Notes:
1. “x” defines voltage from 50V(RS2AA) to 1000V(RS2MA)
2
Version: H2102
RS2AA – RS2MA
CHARACTERISTICS CURVES
Fig.1 Forward Current Derating Curve
Fig.2 Typical Junction Capacitance
100
1.5
CAPACITANCE (pF)
1.0
0.5
f=1.0MHz
Vsig=50mVp-p
10
0.0
25
50
75
100
125
1
150
10
LEAD TEMPERATURE (°C)
REVERSE VOLTAGE (V)
Fig.4 Typical Forward Characteristics
INSTANTANEOUS FORWARD CURRENT (A)
100
TJ=125°C
1
TJ=25°C
0.1
10
40
50
60
70
80
90
100
10 10
UF1DLW
1
TJ=125°C
TJ=25°C
10.1
0.01
0.1
0.001
0.6
0.3
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
Pulse width 300μs
1% duty cycle
Pulse width
0.8
0.4
0.5
1.0
0.6
1.2
0.7
0.8
1.4
0.9
1.6
1
1.1
FORWARD VOLTAGE (V)
Fig.5 Maximum Non-Repetitive Forward Surge Current
60
PEAK FORWARD SURGE CURRENT (A)
INSTANTANEOUS REVERSE CURRENT (μA)
Fig.3 Typical Reverse Characteristics
10
100
(A)
AVERAGE FORWARD CURRENT (A)
2.0
50
40
30
10
100
NUMBER OF CYCLES AT 60 Hz
3
Version: H2102
1.2
RS2AA – RS2MA
Fig.6 Reverse Recovery Time Characteristic And Test Circuit Diagram
4
Version: H2102
RS2AA – RS2MA
PACKAGE OUTLINE DIMENSIONS
DO-214AC (SMA)
SUGGESTED PAD LAYOUT
MARKING DIAGRAM
5
P/N
= Marking Code
G
= Green Compound
YW
= Date Code
F
= Factory Code
Version: H2102
RS2AA – RS2MA
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf,
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability
for application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
6
Version: H2102
很抱歉,暂时无法提供与“RS2KAHR3G”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+5.21640
- 200+2.08440
- 500+2.01960
- 1000+1.98720
