BZX584B13 RKG
BZX584B13 RKG
    TAIWANSEMICONDUCTOR(台湾半导体)
    SOD-523(SC-79)
    DIODE ZENER 13V 150MW SOD523F
BZX584B13 RKG 数据手册
BZX584B5V1 - BZX584B20 Taiwan Semiconductor 2% Zener Voltage Tolerance SMD Zener Diode FEATURES KEY PARAMETERS ● ● ● ● Wide zener voltage range selection: 5.1V to 20V VZ Tolerance Selection of ± 2% Surface device type mountin Compliant to RoHS directive 2011/65/EU and in accordance to WEEE 2002/96/EC ● Halogen-free according to IEC 61249-2-21 PARAMETER VALUE UNIT VZ 5.1-20 V Test current IZT 5 mA Ptot 150 mW TJ Max. 150 °C APPLICATIONS ● Constant Voltage control Package SOD-523F Configuration Single dice MECHANICAL DATA ● ● ● ● ● ● ● ● Case: SOD-523F Molding compound meets UL 94 V-0 flammability rating Moisture sensitivity level: level 1, per J-STD-020 Packing code with suffix "G" means green compound (halogen-free) Terminal: Matte tin plated leads, solderable per J-STD-002 Meet JESD 201 class 1A whisker test Polarity: Indicated by cathode band Weight: 1.3mg ± 20 % ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER Total power dissipation SYMBOL VALUE UNIT Ptot 150 mW Junction temperature range TJ -55 to +150 °C Storage temperature range TSTG -55 to +150 °C SYMBOL TYP UNIT RӨJA 833 °C/W THERMAL PERFORMANCE PARAMETER Junction-to-ambient thermal resistance 1 Version:C1711 BZX584B5V1 - BZX584B20 Taiwan Semiconductor ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PART MARKING NUMBER CODE Min. TYPICAL ZENER TEST REGULAR TEST LEAKAGE VOLTAGE CURRENT IMPEDANCE CURRENT CURRENT IZK IR @ VR VZ @ IZT IZT ZZT @ IZT V mA Ω ZZK @ IZK Ω µA mA TEMPERATURE COEFFICIENT TC@IZT V mV/°C Nom. Max. Max. Max. Min. Max. BZX584B5V1 2Z2 5.00 5.1 5.20 5 60 480 1 Max. 2 2.0 -2.7 1.2 BZX584B5V6 2Z3 5.49 5.6 5.71 5 40 400 1 1 2.0 -2.0 2.5 BZX584B6V2 2Z4 6.08 6.2 6.32 5 10 150 1 3 4.0 0.4 3.7 BZX584B6V8 2Z5 6.66 6.8 6.94 5 15 80 1 2 4.0 1.2 4.5 BZX584B7V5 2Z6 7.35 7.5 7.65 5 15 80 1 1 5.0 2.5 5.3 BZX584B8V2 2Z7 8.04 8.2 8.36 5 15 80 1 0.7 5.0 3.2 6.2 BZX584B9V1 2Z8 8.92 9.1 9.28 5 15 100 1 0.5 6.0 3.8 7.0 BZX584B10 2Z9 9.80 10 10.20 5 20 150 1 0.2 7.0 4.5 8.0 BZX584B11 2Y1 10.78 11 11.22 5 20 150 1 0.1 8.0 5.4 9.0 BZX584B12 2Y2 11.76 12 12.24 5 25 150 1 0.1 8.0 6.0 10.0 BZX584B13 2Y3 12.74 13 13.26 5 30 170 1 0.1 8.0 7.0 11.0 BZX584B15 2Y4 14.70 15 15.30 5 30 200 1 0.1 10.5 9.2 13.0 BZX584B16 2Y5 15.68 16 16.32 5 40 200 1 0.1 11.2 10.4 14.0 BZX584B18 2Y6 17.64 18 18.36 5 45 225 1 0.1 12.6 12.4 16.0 BZX584B20 2Y7 19.60 20 20.40 5 55 225 1 0.1 14.0 14.4 18.0 ORDERING INFORMATION PART NO. BZX584Bxxx (Note1&2) PACKING PACKING CODE CODE SUFFIX RS G PACKAGE PACKING SOD-523F 8K / 7" Reel Notes: 1. "xxx" defines voltage from 5.1V (BZX584B5V1) to 20V (BZX584B20) 2. Whole series with green compound EXAMPLE EXAMPLE P/N PART NO. PACKING CODE BZX584B5V1 RSG BZX584B5V1 RS 2 PACKING CODE SUFFIX G DESCRIPTION Green compound Version:C1711 BZX584B5V1 - BZX584B20 Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Typical Forward Characteristics Fig. 2 Reverse Current vs Reverse Voltage 100 100 90 10 Reverse Current (mA) Forward Current (mA) 80 Ta=100°C Ta=10 Ta=25° Ta=25°C 1 70 Ta=25°C 60 50 40 30 20 Ta=100°C 10 0.1 200 300 400 500 600 700 800 0 900 1000 0 4 6 8 10 12 14 16 18 20 Reverse Voltage (V) Fig.3 Admissible Power Dissipation Curve Fig.4 Typical Capacitance Characteristics 200 50 Capacitance Between Terminals (pF) Power Dissipation(mW) 2 Forward Voltage (mV) 150 100 50 40 f=1MHz 30 20 10 0 0 0 25 50 75 100 125 0 150 2 4 6 8 10 12 14 Reverse Voltage Ambient Temperature (°C) 3 Version:C1711 BZX584B5V1 - BZX584B20 Taiwan Semiconductor PACKAGE OUTLINE DIMENSION SOD-523F DIM. Unit(mm) Unit(inch) Min Max Min Max A 0.70 0.90 0.028 0.035 B 1.50 1.70 0.059 0.067 C 0.25 0.40 0.010 0.016 D 1.10 1.30 0.043 0.051 E 0.50 0.77 0.020 0.030 F 0.07 0.20 0.003 0.008 SUGGEST PAD LAYOUT DIM. 4 Unit(mm) Unit(inch) Typ. Typ. X 0.60 0.024 X1 2.30 0.091 Y 0.80 0.031 Version:C1711 BZX584B5V1 - BZX584B20 Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 5 Version:C1711
BZX584B13 RKG 价格&库存
很抱歉,暂时无法提供与“BZX584B13 RKG”相匹配的价格&库存,您可以联系我们找货
