TSOD1F1HM - TSOD1F10HM
Taiwan Semiconductor
Small Signal Product
1A, 100V - 1000V Surface Mount Rectifiers
FEATURES
- Glass passivated devices
- Ideal for surface mounted applications
- Low leakage current
- Metallurgical bonded construction
- Compliant to RoHS Directive 2011/65/EU and
in accordance to WEEE 2002/96/EC
SOD-123FL
- Halogen-free according to IEC 61249-2-21
- Packing code with suffix "G" means
green compound (halogen-free)
MECHANICAL DATA
me
nd
ed
- Case: JEDEC SOD-123FL, molded plastic over passivated chip
- Terminals: Solder Plated, solderable per MIL-STD-750, Method 2026
- Weight: 21 ± 0.5mg
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS (TA=25°C unless otherwise noted)
PARAMETER
SYMBOL
Device marking code
TSOD1F TSOD1F TSOD1F TSOD1F TSOD1F TSOD1F
1HM
Maximum RMS voltage
Maximum DC blocking voltage
4HM
6HM
8HM
10HM
UNIT
FD
FG
FJ
FK
FM
VRRM
100
200
400
600
800
1000
V
VRMS
70
140
280
420
560
700
V
VDC
100
200
400
600
800
1000
V
eco
m
FB
Maximum recurrent peak reverse voltage
2HM
I(AV)
1
A
Peak forward surge current 8.3ms single half sine wave
superimposed on rated load
IFSM
25
A
Maximum instantaneous forward voltage at 1A (Note 2)
VF
1.3
V
TA=25°C
TA=125°C
No
Maximum DC reverse current
at rated DC blocking voltage
tR
Maximum average forward rectified current (Note 1)
5
IR
μA
50
Maximum reverse recovery time (Note 3)
trr
Typical junction capacitance (Note 4)
CJ
4
pF
RθJA
180
K/W
TJ , TSTG
-55 to +150
°C
Typical thermal resistance (Note 5)
Junction and Storage Temperature Range
150
250
500
ns
Note 1: Averaged over any 20ms period.
Note 2: Pulse test: 300μs pulse width, 1% duty cycle.
Note 3: Measured with IF=0.5A, IR=1A, Irr=0.25A
Note 4: Measured at 1.0MHz and applied average voltage of 4.0V DC.
Note 5: Thermal resistance junction to ambient, 6.0 mm2 copper pads to each terminal.
Version: B1606
RATINGS AND CHARACTERISTICS CURVES
Fig. 1 FORWARD DERATING CURVE
Fig. 2 TYPICAL FORWARD CHARACTERISTICS
100
FORWARD CURRENT (A)
1
0.8
0.6
0.4
0.2
0.1
Fig.2
Pulse Width=300μs
1% Duty Cycle
0.01
60
90
120
150
AMBIENT TEMPERATURE (°C)
0.6
0.7
0.8
0.9
1.0
1.1
1.2
1.3
1.4
1.5
1.6
FORWARD VOLTAGE (V)
Fig. 3 TYPICAL REVERSE CHARACTERISTICS
Fig. 3
eco
m
Fig. 4 TYPICAL JUNCTION CAPACITANCE
100
10
9
8
tR
10
TJ=125°C
1
No
INSTANTANEOUS REVERSE CURRENT (μA)
10
me
nd
ed
RESISTIVE OR
INDUCTIVE LOAD
0.1
60
80
100
120
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
7
6
5
4
3
2
1
TJ=25°C
0.01
CAPACITANCE (pF)
AVERAGE FORWARD CURRENT (A)
1.2
10
15
30
35
40
REVERSE VOLTAGE (V)
Version: B1606
ORDERING INFORMATION
PART NO.
PACKING CODE
TSOD1FxHM
(Note 1, 2)
R4
PACKING CODE
SUFFIX
G
PACKAGE
PACKING
SOD-123FL
10,000 / 13" reel
Note 1: "x" defines voltage from 100V (TSOD1F1HM) to 1000V (TSOD1F10HM)
Note 2: Whole series with green compound
EXAMPLE
PREFERRED P/N
PART NO.
PACKING CODE
TSOD1F1HM R4G
TSOD1F1HM
R4
PACKING CODE
DESCRIPTION
SUFFIX
G
Green compound
PACKAGE OUTLINE DIMENSIONS
me
nd
ed
SOD-123FL
DIM.
Unit (mm)
Min
Max
Unit (inch)
Min
Max
3.45
3.95
0.136
0.156
B
2.60
3.10
0.102
0.122
C
1.70
2.10
0.067
0.083
D
0.80
1.15
0.031
0.045
E
0.30
0.90
0.012
0.035
eco
m
A
0.10
0.30
0.004
0.012
0.88
1.35
0.035
0.053
No
tR
F
G
SUGGEST PAD LAYOUT
DIM.
Unit (mm)
Unit (inch)
Typ.
Typ.
C
4.00
0.157
G
3.00
0.118
X
1.20
0.047
X1
4.90
0.193
Y
1.20
0.047
Version: B1606
No
tR
eco
m
me
nd
ed
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf,
assumes no responsibility or liability for any errors or inaccuracies.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC's terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
Version: B1606
很抱歉,暂时无法提供与“TSOD1F10HM RVG”相匹配的价格&库存,您可以联系我们找货
