UF4004GTA
UF4004GTA
    SMCDIODESOLUTIONS(桑德斯)
    DO-204AL
    RECOVERY RECTIFIERS 400V DO-41
UF4004GTA 数据手册
UF4001G THRU UF4007G Technical Data Data Sheet N1660, Rev. B UF4001G THRU UF4007G ULTRA FAST RECITIFIERS Features Super fast switching for high efficiency Low leakage current High forward surge capability Solder dip 260 °C, 40 s Component in accordance to RoHS 2002/95/EC and WEEE 2002/96/EC Glass Passivated Die Construction This is a Pb − Free Device All SMC parts are traceable to the wafer lot Additional testing can be offered upon request           DO-41 Circuit Diagram Mechanical Data      Case: JEDEC DO-41 molded plastic body Terminals: Plated axial leads, solderable per MIL-STD-750, Method 2026 Polarity: Color band denotes cathode end Mounting Position: Any Weight: 0.33 grams Maximum Ratings and Electrical Characteristics @TA=25°C unless otherwise specified SYMBOLS UF 4001G UF 4002G UF 4003G UF 4004G UF 4005G UF 4006G UF 4007G UNIS Maximum repetitive peak reverse voltage VRRM 50 100 200 400 600 800 1000 V Maximum RMS voltage VRMS 35 70 140 280 420 560 700 V Maximum DC blocking voltage Maximum average forward rectified current 0.375"( 9.5mm ) lead length at TA=55℃ Peak forward surge current 8.3ms single half sine-wave superimposed on rated load ( JEDEC Method) Maximum instantaneous forward voltage at 1.0A Maximum DC reverse current TA=25℃ at rated DC blocking voltage TA=100℃ VDC 50 100 200 400 600 800 1000 V Maximum reverse recovery time (Note 1) Typical junction capacitance ( Note 2) Typical thermal resistance ( Note 3) Operating junction and storage temperature range I(AV) 1.0 A IFSM 30.0 A VF 1.0 1.70 5.0 50.0 IR trr CJ RCJA TJ,TSTG 50 V μA 15.0 50.0 75 ns pF ℃/W -65 to +150 ℃ Note: 1. Reverse recovery condition IF=0.5A, IR=1.0A. Irr=0.25A 2. Measured at 1MHz and applied reverse voltage of 4.0V D.C. 3. Thermal resistance from junction to ambient at 0.375”(9.5mm) lead length, P.C.B mounted.  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  UF4001G THRU UF4007G Technical Data Data Sheet N1660, Rev. B Ratings and Characteristics Curves  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  UF4001G THRU UF4007G Technical Data Data Sheet N1660, Rev. B Mechanical Dimensions DO-41 Millimeters SYMBOL Ordering Information Device UF4001G THRU UF4007G Inches Min. Max. Min. Max. A 25.4 - 1.000 - B 4.06 5.21 0.160 0.205 C 0.71 0.864 0.028 0.034 D 2.00 2.72 0.079 0.107 Marking Diagram Package Shipping DO-41 (Pb-Free) 5000pcs /Tape For information on tape and reel specifications, including part orientation and tape sizes, please refer to our tape and reel packaging specification. UF4001G = Part Name Carrier Tape Specification DO-41 SYMBOL Millimeters Min. Max. A 4.50 5.50 B 50.9 53.9 Z - 1.20 T 5.60 6.40 E - 0.80 IL1-L2I - 1.0  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  UF4001G THRU UF4007G Technical Data Data Sheet N1660, Rev. B DISCLAIMER: 1- The information given herein, including the specifications and dimensions, is subject to change without prior notice to improve product characteristics. Before ordering, purchasers are advised to contact the SMC - Sangdest Microelectronics (Nanjing) Co., Ltd sales department for the latest version of the datasheet(s). 2- In cases where extremely high reliability is required (such as use in nuclear power control, aerospace and aviation, traffic equipment, medical equipment , and safety equipment) , safety should be ensured by using semiconductor devices that feature assured safety or by means of users’ fail-safe precautions or other arrangement . 3- In no event shall SMC - Sangdest Microelectronics (Nanjing) Co., Ltd be liable for any damages that may result from an accident or any other cause during operation of the user’s units according to the datasheet(s). SMC - Sangdest Microelectronics (Nanjing) Co., Ltd assumes no responsibility for any intellectual property claims or any other problems that may result from applications of information, products or circuits described in the datasheets. 4- In no event shall SMC - Sangdest Microelectronics (Nanjing) Co., Ltd be liable for any failure in a semiconductor device or any secondary damage resulting from use at a value exceeding the absolute maximum rating. 5- No license is granted by the datasheet(s) under any patents or other rights of any third party or SMC - Sangdest Microelectronics (Nanjing) Co., Ltd. 6- The datasheet(s) may not be reproduced or duplicated, in any form, in whole or part, without the expressed written permission of SMC - Sangdest Microelectronics (Nanjing) Co., Ltd. 7- The products (technologies) described in the datasheet(s) are not to be provided to any party whose purpose in their application will hinder maintenance of international peace and safety nor are they to be applied to that purpose by their direct purchasers or any third party. When exporting these products (technologies), the necessary procedures are to be taken in accordance with related laws and regulations..  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com 
UF4004GTA 价格&库存
很抱歉,暂时无法提供与“UF4004GTA”相匹配的价格&库存,您可以联系我们找货
