TSSW3U45 – TSSW3U60
Taiwan Semiconductor
3A, 45V - 60V Low VF Trench Schottky Surface Mount Rectifier
FEATURES
KEY PARAMETERS
Patented Trench Schottky technology
Excellent high temperature stability
Low forward voltage
Lower power loss/ high efficiency
High forward surge capability
Moisture sensitivity level: level 1, per J-STD-020
RoHS Compliant
Halogen-free according to IEC 61249-2-21
PARAMETER
VALUE
UNIT
IF
3
A
VRRM
45 - 60
V
IFSM
50
A
TJ MAX
150
°C
Package
SOD-123W
Configuration
Single die
APPLICATIONS
● Switching mode power supply (SMPS)
● Adapters
● DC to DC converters
MECHANICAL DATA
Case: SOD-123W
Molding compound meets UL 94V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Meet JESD 201 class 2 whisker test
Polarity: Indicated by cathode band
Weight: 0.016g (approximately)
SOD-123W
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
SYMBOL
Marking code on the device
TSSW3U45
TSSW3U60
W3U45
W3U60
UNIT
Repetitive peak reverse voltage
VRRM
45
60
V
Reverse voltage, total rms value
VR(RMS)
31
42
V
Forward current
Peak forward surge current, 8.3ms single half
sine-wave superimposed on rated load
Junction temperature
IF
3
A
IFSM
50
A
TJ
- 55 to +150
°C
Storage temperature
TSTG
- 55 to +150
°C
1
Version: B2103
TSSW3U45 – TSSW3U60
THERMAL PERFORMANCE
PARAMETER
SYMBOL
TYP
UNIT
Junction-to-lead thermal resistance
RӨJL
°C/W
Junction-to-ambient thermal resistance
RӨJA
75
°C/W
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
CONDITIONS
TSSW3U45
TSSW3U60
TSSW3U45
Forward voltage
TSSW3U60
(1)
TSSW3U45
TSSW3U60
TSSW3U45
TSSW3U60
Reverse current @ rated VR
(2)
SYMBOL
IF = 1A, TJ = 25°C
IF = 3A, TJ = 25°C
VF
IF = 1A, TJ = 125°C
IF = 3A, TJ = 125°C
TJ = 25°C
TJ = 125°C
IR
TYP
MAX
UNIT
0.33
V
0.39
V
0.40
0.47
V
0.49
0.58
V
0.24
V
0.28
V
0.34
0.44
V
0.43
0.52
V
1
mA
50
mA
Notes:
1. Pulse test with PW = 0.3ms
2. Pulse test with PW = 30ms
ORDERING INFORMATION
ORDERING CODE(1)
PACKAGE
PACKING
TSSW3Ux
SOD-123W
10,000 / Tape & Reel
Notes:
1. “x” defines voltage from 45V(TSSW3U45) to 60V(TSSW3U60)
2
Version: B2103
TSSW3U45 – TSSW3U60
CHARACTERISTICS CURVES
Fig.1 Forward Current Derating Curve
Fig.2 Typical Junction Capacitance
1000
3
CAPACITANCE (pF)
2
1
f=1.0MHz
Vsig=50mVp-p
10
25
50
75
100
125
150
0.1
1
LEAD TEMPERATURE (°C)
INSTANTANEOUS FORWARD CURRENT (A)
10
TJ=125°C
0.1
TJ=25°C
0.001
10
40
50
60
70
80
90
100
10 10
TSSW3U45
UF1DLW
1
TJ=125°C TSSW3U60
1
0.1
TJ=25°C
0.01
0.1
0.001
0.2
0.3
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
Pulse width 300μs
1% duty cycle
Pulse width
0.3
0.4
0.4
0.5
0.5
0.6
0.6
0.7
0.8
0.7
0.9
0.8
1
1.1
FORWARD VOLTAGE (V)
Fig.5 Maximum Non-Repetitive Forward Surge Current
60
PEAK FORWARD SURGE CURRENT (A)
INSTANTANEOUS REVERSE CURRENT (mA)
Fig.4 Typical Forward Characteristics
100
0.01
100
REVERSE VOLTAGE (V)
Fig.3 Typical Reverse Characteristics
1
10
(A)
AVERAGE FORWARD CURRENT (A)
4
8.3ms single half sine wave
50
40
30
10
100
NUMBER OF CYCLES AT 60 Hz
3
Version: B2103
1.2
TSSW3U45 – TSSW3U60
PACKAGE OUTLINE DIMENSIONS
SOD-123W
SUGGESTED PAD LAYOUT
MARKING DIAGRAM
4
P/N
= Marking Code
YW
= Date Code
F
= Factory Code
Version: B2103
TSSW3U45 – TSSW3U60
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability
for application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
5
Version: B2103
很抱歉,暂时无法提供与“TSSW3U60 RVG”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+10.683471+1.37731
- 10+6.6907810+0.86257
- 100+4.40616100+0.56804
- 500+3.42305500+0.44130
- 1000+3.106461000+0.40049
- 国内价格 香港价格
- 3000+2.840873000+0.36625
