PMEG100T030ELPEZ
PMEG100T030ELPEZ
    NEXPERIA(安世)
    TO-277
    DIODE SCHOTTKY 100V 3A CFP15B
PMEG100T030ELPEZ 数据手册
PMEG100T030ELPE 100 V, 3 A low leakage current Trench MEGA Schottky barrier rectifier 3 December 2020 Product data sheet 1. General description Trench Maximum Efficiency General Application (MEGA) Schottky barrier rectifier encapsulated in a CFP15B (SOT1289B) power and flat lead Surface-Mounted Device (SMD) plastic package. 2. Features and benefits • • • • • • Low forward voltage Low Qrr and low IRM Low leakage current High power capability due to clip-bonding technology Small and flat lead SMD power plastic package AEC-Q101 qualified 3. Applications • • • • • • High efficiency DC-to-DC conversion Automotive LED lighting Switch mode power supply Freewheeling application Reverse polarity protection OR-ing 4. Quick reference data Table 1. Quick reference data Symbol Parameter Conditions Min Typ Max Unit - - 3 A IF(AV) average forward current δ = 0.5; square wave; f = 20 kHz; Tsp ≤ 169 °C VR reverse voltage Tj = 25 °C - - 100 V VF forward voltage IF = 3 A; pulsed; Tj = 25 °C [1] - 650 710 mV IR reverse current VR = 100 V; pulsed; Tj = 25 °C [1] - 0.4 2.5 µA VR = 100 V; pulsed; Tj = 125 °C [1] - 0.6 3 mA [1] Very short pulse, in order to maintain a stable junction temperature. PMEG100T030ELPE Nexperia 100 V, 3 A low leakage current Trench MEGA Schottky barrier rectifier 5. Pinning information Table 2. Pinning information Pin Symbol Description 1 A anode 2 A anode 3 K cathode Simplified outline Graphic symbol A A K 1 3 aaa-009063 2 CFP15B (SOT1289B) 6. Ordering information Table 3. Ordering information Type number Package PMEG100T030ELPE Name Description Version CFP15B plastic, thermal enhanced ultra thin SMD package; 3 leads; 2.13 mm pitch; 5.8 x 4.3 x 0.95 mm body SOT1289B 7. Marking Table 4. Marking codes Type number Marking code PMEG100T030ELPE 100T L03E 8. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC60134). Symbol Parameter Conditions Min Max Unit VR reverse voltage Tj = 25 °C - 100 V IF forward current δ = 1; Tsp ≤ 166 °C - 4.2 A IF(AV) average forward current δ = 0.5; square wave; f = 20 kHz; Tsp ≤ 169 °C - 3 A IFSM non-repetitive peak forward current tp = 8.3 ms; half sine wave; Tj(init) = 25 °C - 100 A Ptot total power dissipation Tamb ≤ 25 °C [1] - 1.66 W [2] - 2.15 W Tj junction temperature - 175 °C Tamb ambient temperature -55 175 °C Tstg storage temperature -65 175 °C [1] [2] Device mounted on an FR4 Printed-Circuit Board (PCB), single-sided copper, tin-plated and standard footprint. 2 Device mounted on an FR4 PCB, single-sided copper, tin-plated, mounting pad for cathode 1 cm . PMEG100T030ELPE Product data sheet All information provided in this document is subject to legal disclaimers. 3 December 2020 © Nexperia B.V. 2020. All rights reserved 2 / 13 PMEG100T030ELPE Nexperia 100 V, 3 A low leakage current Trench MEGA Schottky barrier rectifier 9. Thermal characteristics Table 6. Thermal characteristics Symbol Parameter Rth(j-a) Rth(j-sp) [1] [2] [3] [4] Conditions Min Typ Max Unit thermal resistance from in free air junction to ambient [1] [2] - - 90 K/W [1] [3] - - 70 K/W thermal resistance from junction to solder point [4] - - 7 K/W For Schottky barrier diodes thermal runaway has to be considered, as in some applications the reverse power losses PR are a significant part of the total power losses. Device mounted on an FR4 PCB, single-sided copper, tin-plated and standard footprint. 2 Device mounted on an FR4 PCB, single-sided copper, tin-plated, mounting pad for cathode 1 cm . Soldering point of cathode tab. 102 aaa-032290 duty cycle = 1 0.75 0.50 Zth(j-a) (K/W) 0.33 0.25 10 0.20 0.10 0.05 0.02 0.01 0 1 -3 10 10-2 10-1 1 10 102 tp (s) 103 FR4 PCB, standard footprint Fig. 1. Transient thermal impedance from junction to ambient as a function of pulse duration; typical values aaa-032291 102 duty cycle = 1 0.75 Zth(j-a) (K/W) 0.50 0.33 0.25 10 0.20 0.10 0.05 0.02 0.01 0 1 10-3 10-2 10-1 FR4 PCB, mounting pad for cathode 1 cm Fig. 2. 1 10 102 tp (s) 2 103 Transient thermal impedance from junction to ambient as a function of pulse duration; typical values PMEG100T030ELPE Product data sheet All information provided in this document is subject to legal disclaimers. 3 December 2020 © Nexperia B.V. 2020. All rights reserved 3 / 13 PMEG100T030ELPE Nexperia 100 V, 3 A low leakage current Trench MEGA Schottky barrier rectifier 10. Characteristics Table 7. Characteristics Symbol Parameter Conditions V(BR)R reverse breakdown voltage IR = 1 mA; Tj = 25 °C VF forward voltage IR reverse current Min Typ Max Unit [1] 100 - - V IF = 0.5 A; pulsed; Tj = 25 °C [1] - 460 560 mV IF = 1 A; pulsed; Tj = 25 °C [1] - 510 580 mV IF = 2 A; pulsed; Tj = 25 °C [1] - 580 650 mV IF = 3 A; pulsed; Tj = 25 °C [1] - 650 710 mV IF = 3 A; pulsed; Tj = -40 °C [1] - 660 720 mV IF = 3 A; pulsed; Tj = 125 °C [1] - 550 610 mV IF = 3 A; pulsed; Tj = 150 °C [1] - 520 580 mV VR = 60 V; pulsed; Tj = 25 °C [1] - 0.15 0.63 µA VR = 100 V; pulsed; Tj = 25 °C [1] - 0.4 2.5 µA VR = 100 V; pulsed; Tj = 125 °C [1] - 0.6 3 mA VR = 100 V; pulsed; Tj = 150 °C [1] - 2.3 12 mA VR = 1 V; f = 1 MHz; Tj = 25 °C - 410 - pF VR = 10 V; f = 1 MHz; Tj = 25 °C - 120 - pF reverse recovery time step recovery IF = 0.5 A; IR = 0.5 A; IR(meas) = 0.1 A; Tj = 25 °C - 12 - ns reverse recovery time ramp recovery dIF/dt = 200 A/µs; IF = 6 A; VR = 26 V; Tj = 25 °C - 12 - ns IRM peak reverse recovery current dIF/dt = 200 A/s; IF = 6 A; VR = 26 V; Tj = 25 °C - 1.3 - A Qrr reverse recovery charge - 9.5 - nC VFRM peak forward recovery voltage - 460 - mV Cd diode capacitance trr [1] IF = 0.5 A; dIF/dt = 20 A/µs; Tj = 25 °C Very short pulse, in order to maintain a stable junction temperature. PMEG100T030ELPE Product data sheet All information provided in this document is subject to legal disclaimers. 3 December 2020 © Nexperia B.V. 2020. All rights reserved 4 / 13 PMEG100T030ELPE Nexperia 100 V, 3 A low leakage current Trench MEGA Schottky barrier rectifier aaa-032292 10 IR (A) IF (A) aaa-032293 10-2 (1) 10-3 (2) (3) 10-4 1 (4) (5) 10-5 10-1 10-6 (2) (4) (1) (3) (5) 10-2 10-7 (6) (7) (6) 10-8 (7) 10-9 10-3 0 0.2 0.4 0.6 0.8 VF (V) 10-10 1.0 pulsed condition (1) Tj = 175 °C (2) Tj = 150 °C (3) Tj = 125 °C (4) Tj = 100 °C (5) Tj = 85 °C (6) Tj = 25 °C (7) Tj = -40 °C Fig. 3. 0 20 40 60 80 VR (V) 100 pulsed condition (1) Tj = 175 °C (2) Tj = 150 °C (3) Tj = 125 °C (4) Tj = 100 °C (5) Tj = 85 °C (6) Tj = 25 °C (7) Tj = -40 °C Forward current as a function of forward voltage; typical values Fig. 4. aaa-032294 600 Reverse current as a function of reverse voltage; typical values aaa-032314 3 Cd (pF) (5) PF(AV) (W) 400 (4) 2 (3) (2) 200 0 1 0 20 40 60 80 VR (V) 0 100 f = 1 MHz; Tamb = 25 °C Fig. 5. Fig. 6. Product data sheet 0 1 2 3 4 5 IF(AV) (A) Tj = 100 °C (1) δ = 0.1 (2) δ = 0.2 (3) δ = 0.5 (4) δ = 1; DC Diode capacitance as a function of reverse voltage; typical values PMEG100T030ELPE (1) Average forward power dissipation as a function of average forward current; typical values All information provided in this document is subject to legal disclaimers. 3 December 2020 © Nexperia B.V. 2020. All rights reserved 5 / 13 PMEG100T030ELPE Nexperia 100 V, 3 A low leakage current Trench MEGA Schottky barrier rectifier aaa-032296 14 PR(AV) (W) 12 aaa-032315 5 IF(AV) (A) (1) 4 (1) 10 (2) 8 6 (3) 3 (2) 2 (3) 4 (4) 1 (4) 2 (5) 0 0 20 40 60 80 VR (V) 0 100 Tj = 100 °C (1) δ = 1; DC (2) δ = 0.9 (3) δ = 0.8 (4) δ = 0.5 (5) δ = 0.2 Fig. 7. Fig. 8. aaa-032316 5 aaa-032317 (1) 4 (2) 3 (2) 2 (3) 2 (3) (4) (4) 1 1 0 50 100 Average forward current as a function of ambient temperature; typical values PMEG100T030ELPE Product data sheet 0 150 200 Tamb (°C) 2 FR4 PCB, mounting pad for cathode 1 cm Tj = 175 °C (1) δ = 1; DC (2) δ = 0.5; f = 20 kHz (3) δ = 0.2; f = 20 kHz (4) δ = 0.1; f = 20 kHz Fig. 9. 150 200 Tamb (°C) 5 3 0 100 Average forward current as a function of ambient temperature; typical values IF(AV) (A) (1) 4 50 FR4 PCB, standard footprint Tj = 175 °C (1) δ = 1; DC (2) δ = 0.5; f = 20 kHz (3) δ = 0.2; f = 20 kHz (4) δ = 0.1; f = 20 kHz Average reverse power dissipation as a function of reverse voltage; typical values IF(AV) (A) 0 0 50 100 150 Tsp (°C) 200 Tj = 175 °C (1) δ = 1; DC (2) δ = 0.5; f = 20 kHz (3) δ = 0.2; f = 20 kHz (4) δ = 0.1; f = 20 kHz Fig. 10. Average forward current as a function of solder point temperature; typical values All information provided in this document is subject to legal disclaimers. 3 December 2020 © Nexperia B.V. 2020. All rights reserved 6 / 13 PMEG100T030ELPE Nexperia 100 V, 3 A low leakage current Trench MEGA Schottky barrier rectifier aaa-032300 120 aaa-032301 120 VR (V) VR (V) 80 80 40 40 0 0 50 100 150 Tj (°C) 0 200 FR4 PCB, standard footprint Rth = 90 K/W 0 50 100 150 Tj (°C) 200 FR4 PCB, mounting pad for cathode 1 cm Rth = 70 K/W 2 Fig. 11. Derated maximum reverse voltage as a function Fig. 12. Derated maximum reverse voltage as a function of junction temperature; typical values of junction temperature; typical values aaa-032302 120 VR (V) 80 40 0 0 50 100 150 Tj (°C) 200 Soldering point of cathode tab Rth = 7 K/W Fig. 13. Derated maximum reverse voltage as a function of junction temperature; typical values PMEG100T030ELPE Product data sheet All information provided in this document is subject to legal disclaimers. 3 December 2020 © Nexperia B.V. 2020. All rights reserved 7 / 13 PMEG100T030ELPE Nexperia 100 V, 3 A low leakage current Trench MEGA Schottky barrier rectifier 11. Test information IF IR(meas) time IR trr 006aad022 Fig. 14. Reverse recovery definition; step recovery IF dlF dt trr time 25 % 100 % Qrr IR IRM 003aac562 Fig. 15. Reverse recovery definition; ramp recovery IF time VF VFRM VF time 001aab912 Fig. 16. Forward recovery definition PMEG100T030ELPE Product data sheet All information provided in this document is subject to legal disclaimers. 3 December 2020 © Nexperia B.V. 2020. All rights reserved 8 / 13 PMEG100T030ELPE Nexperia 100 V, 3 A low leakage current Trench MEGA Schottky barrier rectifier P t2 duty cycle δ = t1 t2 t1 t 006aaa812 Fig. 17. Duty cycle definition The current ratings for the typical waveforms are calculated according to the equations: IF(AV)=IM×δ with IM defined as peak current IRMS=IF(AV) at DC, and IRMS=IM×√δ with IRMS defined as RMS current. Quality information This product has been qualified in accordance with the Automotive Electronics Council (AEC) standard Q101 - Stress test qualification for discrete semiconductors, and is suitable for use in automotive applications. PMEG100T030ELPE Product data sheet All information provided in this document is subject to legal disclaimers. 3 December 2020 © Nexperia B.V. 2020. All rights reserved 9 / 13 PMEG100T030ELPE Nexperia 100 V, 3 A low leakage current Trench MEGA Schottky barrier rectifier 12. Package outline 4.4 4.2 2.13 1.3 1.1 0.6 0.4 2 0.99 0.91 1.44 1.04 1 5.9 5.7 4.2 4.96 3.8 4.56 3 6.9 6.7 0.6 0.4 2.15 1.95 0.24 0.16 3.5 3.1 Dimensions in mm 19-01-10 Fig. 18. Package outline CFP15B (SOT1289B) 13. Soldering Footprint information for reflow soldering of CFP15B package SOT1289B 1.8 1.6 1.4 4.6 0.33 0.53 2.13 1.74 1.54 1.34 0.4 0.6 2.83 7.7 1.07 5.26 5.06 0.4 occupied area solder resist solder lands solder paste Issue date 19-06-13 20-02-05 Dimensions in mm 1.93 1.3 0.4 3.8 recommended stencil thickness: 0.1 mm sot1289b_fr Fig. 19. Reflow soldering footprint for CFP15B (SOT1289B) PMEG100T030ELPE Product data sheet All information provided in this document is subject to legal disclaimers. 3 December 2020 © Nexperia B.V. 2020. All rights reserved 10 / 13 PMEG100T030ELPE Nexperia 100 V, 3 A low leakage current Trench MEGA Schottky barrier rectifier 14. Revision history Table 8. Revision history Data sheet ID Release date Data sheet status Change notice Supersedes PMEG100T030ELPE v.2 20201203 Product data sheet - PMEG100T030ELPE v.1 Modifications: • PMEG100T030ELPE v.1 20201019 - - PMEG100T030ELPE Product data sheet Product status changed Preliminary data sheet All information provided in this document is subject to legal disclaimers. 3 December 2020 © Nexperia B.V. 2020. All rights reserved 11 / 13 PMEG100T030ELPE Nexperia 100 V, 3 A low leakage current Trench MEGA Schottky barrier rectifier equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer's own risk. 15. Legal information Data sheet status Document status [1][2] Product status [3] Definition Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the internet at https://www.nexperia.com. Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use in automotive applications — This Nexperia product has been qualified for use in automotive applications. Unless otherwise agreed in writing, the product is not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or PMEG100T030ELPE Product data sheet All information provided in this document is subject to legal disclaimers. 3 December 2020 © Nexperia B.V. 2020. All rights reserved 12 / 13 PMEG100T030ELPE Nexperia 100 V, 3 A low leakage current Trench MEGA Schottky barrier rectifier Contents 1. General description...................................................... 1 2. Features and benefits.................................................. 1 3. Applications.................................................................. 1 4. Quick reference data....................................................1 5. Pinning information......................................................2 6. Ordering information....................................................2 7. Marking.......................................................................... 2 8. Limiting values............................................................. 2 9. Thermal characteristics............................................... 3 10. Characteristics............................................................ 4 11. Test information.......................................................... 8 12. Package outline........................................................ 10 13. Soldering................................................................... 10 14. Revision history........................................................11 15. Legal information......................................................12 © Nexperia B.V. 2020. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 3 December 2020 PMEG100T030ELPE Product data sheet All information provided in this document is subject to legal disclaimers. 3 December 2020 © Nexperia B.V. 2020. All rights reserved 13 / 13
PMEG100T030ELPEZ
物料型号:PMEG100T030ELPE
器件简介: - 这是一款封装在CFP15B (SOT1289B) 功率和平面引线表面贴装设备(SMD)塑料封装中的沟槽最大效率通用应用(MEGA)肖特基势垒整流器。
引脚分配: - 引脚1和引脚2标为A(阳极)。 - 引脚3标为K(阴极)。
参数特性: - 快速参考数据显示,该器件在20kHz频率下,平均正向电流为3A时,反向电压为100V,正向电压在650mV到710mV之间,反向电流在0.4uA到2.5uA之间。 - 极限值表显示,反向电压为100V,正向电流为4.2A,非重复峰值正向电流为100A。
功能详解: - 该整流器具有低正向电压、低Qrr和低IRM、低漏电流、高功率能力(由于夹结技术)、小而平坦的引线SMD功率塑料封装。 - 符合汽车电子委员会(AEC)标准Q101,适用于汽车应用。
应用信息: - 适用于高效率DC-DC转换、汽车LED照明、开关模式电源、自由轮应用、反极性保护、或-ing。
封装信息: - 封装类型为CFP15B,塑料,热增强超薄SMD封装;3引线;2.13mm间距;5.8 x 4.3 x 0.95mm封装体。
其他信息: - 热特性表显示,从结到环境的热阻在自由空气中为90K/W,焊接点的热阻为7K/W。 - 特性表提供了详细的电气特性,如反向击穿电压、正向电压、反向电流、二极管电容、反向恢复时间、反向恢复电流、反向恢复电荷等。
订购信息: - 型号PMEG100T030ELPE,封装为CFP15B。
标记代码: - 型号PMEG100T030ELPE的标记代码为100T和LO3E。
修订历史: - 最近一次修订是在2020年12月3日,将产品状态更改为产品数据表。
法律信息: - 文档包含免责声明,强调信息的准确性和可靠性,但Nexperia不对信息的准确性或完整性提供任何明示或暗示的保证。
PMEG100T030ELPEZ 价格&库存
很抱歉,暂时无法提供与“PMEG100T030ELPEZ”相匹配的价格&库存,您可以联系我们找货
PMEG100T030ELPEZ
  • 5000+1.563725000+0.20328
  • 15000+1.3777515000+0.17911
库存:8579
PMEG100T030ELPEZ
  • 50+3.40637
  • 500+3.32514
  • 1000+3.24496
  • 2500+3.16789
库存:4875
PMEG100T030ELPEZ
    PMEG100T030ELPEZ
    • 1+7.146121+0.92898
    • 10+4.4103310+0.57333
    • 50+3.2281350+0.41965
    • 100+2.84277100+0.36955
    • 500+2.16553500+0.28152
    库存:8579
    PMEG100T030ELPEZ
    • 25+3.49072
    • 50+3.40637
    • 500+3.32514
    • 1000+3.24496
    • 2500+3.16789
    库存:4875
