DB151S THRU DB157S
Technical Data
Data Sheet N1476, Rev. C
DB151S THRU DB157S SINGLE-PHASE
GLASS PASSIVATED SILICON BRIDGE RECTIFIERS
Features
Glass passivated die construction
Low forward voltage drop
High current capability
High surge current capability
Designed for surface mount application
Plastic material-UL flammability 94V-0
This is a Pb − Free Device
All SMC parts are traceable to the wafer lot
Additional testing can be offered upon request
DB-S
Circuit Diagram
Mechanical Data
Case: DB-S, molded plastic
Terminals: plated leads solderable per MIL-STD-202,
Method 208
Polarity: as marked on case
Mounting position: Any
Lead Free: For RoHS / Lead Free Version,
Maximum Ratings @TA=25°C unless otherwise specified
Single Phase half wave 60Hz, resistive or inductive load. For capacitive load current derate by 20%.
Symbol
DB
151S
DB
152S
DB
153S
DB
154S
DB
155S
DB
156S
DB
157S
Units
Peak Repetitive Reverse Voltage
Working Peak Reverse Voltage
DC Blocking Voltage
VRRM
VRWM
VR
50
100
200
400
600
800
1000
V
35
70
140
280
420
560
700
V
Characteristic
RMS Reverse Voltage
VRMS
Average Forward Output Current
(Note 1) @ TC =100°C
IF(AV)
1.5
A
Non-Repetitive Peak Forward Surge
Current 8.3ms Single half sine-wave
superimposed on rated load (JEDEC
Method)
IFSM
55
A
I2t
12.6
A2 s
I2t Rating for Fusing (t < 8.3ms)
China - Germany - Korea - Singapore - United States
http://www.smc-diodes.com - sales@ smc-diodes.com
DB151S THRU DB157S
Technical Data
Electrical Characteristics @TA=25°C unless otherwise specified
Characteristic
Symbol
DB
151S
DB
152S
DB
153S
DB
154S
DB
155S
DB
156S
DB
157S
Units
Maximum Forward Voltage Drop*
per Bridge Element @IF =1.5A, TJ=25°C
VF
1.0
V
Peak Reverse Current*
@TA = 25°C
At Rated DC Blocking Voltage* @TA = 125°C
IR
5
200
μA
Typical Junction Capacitance (Note 2)
CJ
25
pF
* Pulse width < 300 µs, duty cycle < 2%
Thermal-Mechanical Specifications @TA=25°C unless otherwise specified
Characteristic
Symbol
DB
151S
DB
152S
DB
153S
DB
154S
DB
155S
DB
156S
DB
157S
Units
Typical Thermal Resistance Junction to
Ambient
RθJA
40
°C/W
Typical Thermal Resistance Junction to Lead
RθJL
15
°C/W
-55 to + 150
°C
Operating Junction and Storage Temperature
TJ ,TSTG
Range
Note: 1. Mounted on glass epoxy PC board with 1.3mm2 solder pad.
2. Measured at 1.0 MHZ and applied reverse voltage of 4.0 VDC
Ratings and Characteristics Curves
DB151S THRU DB157S
Technical Data
Mechanical Dimensions DB-S(Inches/Millimeters)
DB151S THRU DB157S
Technical Data
Ordering Information
Marking Diagram
Device
Package
Plating
Shipping
DB151S
THRU
DB157S
DB-S
(Pb-Free)
Pure Sn
1500pcs / reel
Where XXXXX is YYWWL
DB151S
YY
WW
L
For information on tape and reel specifications, including part
orientation and tape sizes, please refer to our tape and reel
packaging specification.
= Type Number
= Year
= Week
= Lot Number
Cautions:Molding resin
Epoxy resin UL:94V-0
Carrier Tape Specification DB-S
A0
Millimeters
Min.
Max.
8.95
8.65
B0
10.31
10.51
D0
D1
P0
P1
P2
1.50
1.40
3.90
1.60
1.60
11.90
12.10
1.90
2.10
E
1.65
1.85
K0
3.21
3.41
F
7.40
7.60
W
15.70
16.30
T
0.30
0.40
10P0
39.80
40.20
SYMBOL
4.10
DB151S THRU DB157S
Technical Data
DISCLAIMER:
1- The information given herein, including the specifications and dimensions, is subject to change without prior notice to improve product
characteristics. Before ordering, purchasers are advised to contact the SMC Diode Solutions sales department for the latest version of
the datasheet(s).
2- In cases where extremely high reliability is required (such as use in nuclear power control, aerospace and aviation, traffic equipment,
medical equipment , and safety equipment) , safety should be ensured by using semiconductor devices that feature assured safety or by
means of users’ fail-safe precautions or other arrangement .
3- In no event shall SMC Diode Solutions be liable for any damages that may result from an accident or any other cause during
operation of the user’s units according to the datasheet(s). SMC Diode Solution assumes no responsibility for any intellectual property
claims or any other problems that may result from applications of information, products or circuits described in the datasheets.
4- In no event shall SMC Diode Solutions be liable for any failure in a semiconductor device or any secondary damage resulting from use
at a value exceeding the absolute maximum rating.
5- No license is granted by the datasheet(s) under any patents or other rights of any third party or SMC Diode Solutions.
6- The datasheet(s) may not be reproduced or duplicated, in any form, in whole or part, without the expressed written permission of SMC
Diode Solutions.
7- The products (technologies) described in the datasheet(s) are not to be provided to any party whose purpose in their application will
hinder maintenance of international peace and safety nor are they to be applied to that purpose by their direct purchasers or any third
party. When exporting these products (technologies), the necessary procedures are to be taken in accordance with related laws and
regulations..
很抱歉,暂时无法提供与“DB157STR”相匹配的价格&库存,您可以联系我们找货
