ABS22TR
ABS22TR
    SMCDIODESOLUTIONS(桑德斯)
    SMD4
    BRIDGE RECT 1PHASE 200V 2A ABS
ABS22TR 数据手册
ABS22 THRU ABS210 Technical Data Data Sheet N1924, Rev. A ABS22 THRU ABS210 SINGLE PHASE 2.0A MP SURFACE MOUNT GLASS PASSIVATED BRIDGE RECTIFIER Features Glass passivated die construction Low forward voltage drop High current capability High surge current capability Designed for surface mount application Plastic material-UL flammability 94V-0 This is a Pb − Free Device “-HF” suffix is for Halogen Free Device All SMC parts are traceable to the wafer lot Additional testing can be offered upon request           ABS Circuit Diagram Mechanical Data     Case: SOPA-4, Molded plastic ABS Terminals: Plated leads solderable per MIL-STD-202, Method 208 Polarity: as marked on case Mounting Position: Any Maximum Ratings and Electrical Characteristics @TA=25°C unless otherwise specified Single Phase half wave 60Hz, resistive or inductive load. For capacitive load current derate by 20%. Type Number Symbol ABS22-HF THRU ABS210-HF Marking Code ABS22 ABS24 ABS26 ABS28 ABS210 ABS22H ABS24H ABS26H ABS28H ABS210H Unit Peak Repetitive Reverse Voltage Working Peak Reverse Voltage DC Blocking Voltage VRRM VRWM VDC 200 400 600 800 1000 V RMS Reverse Voltage VRMS 140 280 420 560 700 V Average Rectified Output Current @TC =100°C Non-Repetitive Peak Forward Surge Current 8.3ms Single half sine-wave superimposed on rated load (JEDEC Method) I2t Rating for Fusing (t < 8.3ms) IO 2.0 A IFSM 60 A I2 t 15 A2 s  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  ABS22 THRU ABS210 Technical Data Data Sheet N1924, Rev. A Electrical Characteristics: Type Number Symbol ABS22-HF THRU ABS210-HF Marking Code Forward Voltage (per element) @IF =1.0A @IF =2.0A Peak Reverse Current @TA = 25°C At Rated DC Blocking Voltage @TA = 125°C ABS22 ABS24 ABS26 ABS28 ABS210 ABS22H ABS24H ABS26H ABS28H ABS210H Unit VF 0.95 1.00 V IR 5.0 200 µA * Pulse width < 300 µs, duty cycle < 2% Thermal-Mechanical Specifications: Type Number Symbol ABS22-HF THRU ABS210-HF Marking Code Typical Thermal Resistance (per leg) Operating and Storage Temperature Range ABS22 ABS24 ABS26 ABS28 ABS210 ABS22H ABS24H ABS26H ABS28H ABS210H Unit RθJA RθJL 62.5 25 °C/W TJ, TSTG -55 to +150 °C Ratings and Characteristics Curves  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  ABS22 THRU ABS210 Technical Data Data Sheet N1924, Rev. A Mechanical Dimensions ABS(Inches/Millimeters)  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  ABS22 THRU ABS210 Technical Data Data Sheet N1924, Rev. A Ordering Information Device ABS22 THRU ABS210 ABS22TR THRU ABS210TR Marking Diagram Package Plating Shipping ABS Pure Sn 5000pcs / reel ABS Pure Sn 5000pcs / reel For information on tape and reel specifications, including part orientation and tape sizes, please refer to our tape and reel packaging specification. Where XXXXX is YYWWL ABS22 ABS22H YY WW L Cautions:Molding resin Epoxy resin UL:94V-0 ABS22-HF ABS22 = Type Number = Marking Code = Year = Week = Lot Number Carrier Tape & Reel Specification ABS A0 Millimeters Min. Max. 5.41 5.21 B0 7.10 7.30 D0 D1 P0 1.50 1.40 3.90 1.60 P1 7.90 8.10 P2 1.95 2.05 E 1.65 1.85 K0 1.55 1.75 F 5.45 5.55 W 11.90 12.10 T 0.24 0.30 10P0 39.80 40.20 SYMBOL  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  1.60 4.10 ABS22 THRU ABS210 Technical Data Data Sheet N1924, Rev. A DISCLAIMER: 1- The information given herein, including the specifications and dimensions, is subject to change without prior notice to improve product characteristics. Before ordering, purchasers are advised to contact the SMC Diode Solutions sales department for the latest version of the datasheet(s). 2- In cases where extremely high reliability is required (such as use in nuclear power control, aerospace and aviation, traffic equipment, medical equipment , and safety equipment) , safety should be ensured by using semiconductor devices that feature assured safety or by means of users’ fail-safe precautions or other arrangement . 3- In no event shall SMC Diode Solutions be liable for any damages that may result from an accident or any other cause during operation of the user’s units according to the datasheet(s). SMC Diode Solution assumes no responsibility for any intellectual property claims or any other problems that may result from applications of information, products or circuits described in the datasheets. 4- In no event shall SMC Diode Solutions be liable for any failure in a semiconductor device or any secondary damage resulting from use at a value exceeding the absolute maximum rating. 5- No license is granted by the datasheet(s) under any patents or other rights of any third party or SMC Diode Solutions. 6- The datasheet(s) may not be reproduced or duplicated, in any form, in whole or part, without the expressed written permission of SMC Diode Solutions. 7- The products (technologies) described in the datasheet(s) are not to be provided to any party whose purpose in their application will hinder maintenance of international peace and safety nor are they to be applied to that purpose by their direct purchasers or any third party. When exporting these products (technologies), the necessary procedures are to be taken in accordance with related laws and regulations..  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com 
ABS22TR 价格&库存
很抱歉,暂时无法提供与“ABS22TR”相匹配的价格&库存,您可以联系我们找货
