ABS6TR
ABS6TR
    SMCDIODESOLUTIONS(桑德斯)
    SMD4
    BRIDGE RECT 1P 600V 500MA ABS
ABS6TR 数据手册
ABS2 THRU ABS10 Technical Data Data Sheet N1693, Rev. A ABS2 THRU ABS10 SINGLE PHASE 0.8AMP SURFACE MOUNT GLASS PASSIVATED BRIDGE RECTIFIER Features          ABS Circuit Diagram Glass passivated die construction Low forward voltage drop High current capability High surge current capability Designed for surface mount application Plastic material-UL flammability 94V-0 This is a Pb − Free Device All SMC parts are traceable to the wafer lot Additional testing can be offered upon request Mechanical Data     Case: SOPA-4, Molded plastic ABS Terminals: Plated leads solderable per MIL-STD-202, Method 208 Polarity: as marked on case Mounting Position: Any unless Characteristics otherwise specified@TA=25°C unless otherwise specified A=25°C Maximum Ratings @T and Electrical Single Phase half wave 60Hz, resistive or inductive load. For capacitive load current derate by 20%. Type Number Symbol ABS2 ABS4 ABS6 ABS8 ABS10 Units Peak Repetitive Reverse Voltage Working Peak Reverse Voltage DC Blocking Voltage VRRM VRWM VDC 200 400 600 800 1000 V RMS Reverse Voltage VRMS 140 280 420 560 700 V Maximum Average Rectified Output Current (Note 1)@TA =30°C (Note 2)@TA =30°C Non-Repetitive Peak Forward Surge Current 8.3ms Single half sine-wave superimposed on rated load (JEDEC Method) I(AV) 0.5 V IFSM 30 A 0.8  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  ABS2 THRU ABS10 Technical Data Data Sheet N1693, Rev. A Electrical Characteristics@TA=25°C unless otherwise specified Type Number Symbol ABS2 ABS4 ABS6 ABS8 ABS10 Units Maximum Forward Voltage (per element) @IF =0.8A VF 1.1 V Maximum Peak Reverse Current @TA = 25°C At Rated DC Blocking Voltage @TA = 125°C IR 5.0 500 µA * Pulse width < 300 µs, duty cycle < 2% Thermal-Mechanical Specifications@TA=25°C unless otherwise specified Type Number Typical Thermal Resistance Operating and Storage Temperature Range Symbol ABS2 ABS4 ABS6 ABS8 ABS10 Units RθJA RθJL 62.5 25 °C/W TJ, TSTG -55 to +150 °C Note: 1. Mounted on glass epoxy PC board with 1.3mm2 solder pad. 2. Mounted on aluminum substrate PC board with 1.3mm2 solder pad. Ratings and Characteristics Curves  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  ABS2 THRU ABS10 Technical Data Data Sheet N1693, Rev. A Mechanical Dimensions ABS(Inches/Millimeters)  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  ABS2 THRU ABS10 Technical Data Data Sheet N1693, Rev. A Pad Layout(Millimeters) Ordering Information Device ABS2 THRU ABS10 Marking Diagram Package Plating Shipping ABS (Pb-Free) Pure Sn 5000pcs / reel Where XXXXX is YYWWL ABS2 YY WW L For information on tape and reel specifications, including part orientation and tape sizes, please refer to our tape and reel packaging specification. = Type Number = Year = Week = Lot Number Cautions:Molding resin Epoxy resin UL:94V-0 Carrier Tape Specification ABS SYMBOL A0 B0 D0 D1 P0 P1 P2 E K0 F W T 10P0 Millimeters Min. Max. 5.41 5.21 7.30 7.10 1.60 1.50 1.60 1.40 4.10 3.90 8.10 7.90 2.05 1.95 1.85 1.65 1.75 1.55 5.55 5.45 12.10 11.90 0.30 0.24 40.20 39.80  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  ABS2 THRU ABS10 Technical Data Data Sheet N1693, Rev. A DISCLAIMER: 1- The information given herein, including the specifications and dimensions, is subject to change without prior notice to improve product characteristics. Before ordering, purchasers are advised to contact the SMC Diode Solutions sales department for the latest version of the datasheet(s). 2- In cases where extremely high reliability is required (such as use in nuclear power control, aerospace and aviation, traffic equipment, medical equipment , and safety equipment) , safety should be ensured by using semiconductor devices that feature assured safety or by means of users’ fail-safe precautions or other arrangement . 3- In no event shall SMC Diode Solutions be liable for any damages that may result from an accident or any other cause during operation of the user’s units according to the datasheet(s). SMC Diode Solution assumes no responsibility for any intellectual property claims or any other problems that may result from applications of information, products or circuits described in the datasheets. 4- In no event shall SMC Diode Solutions be liable for any failure in a semiconductor device or any secondary damage resulting from use at a value exceeding the absolute maximum rating. 5- No license is granted by the datasheet(s) under any patents or other rights of any third party or SMC Diode Solutions. 6- The datasheet(s) may not be reproduced or duplicated, in any form, in whole or part, without the expressed written permission of SMC Diode Solutions. 7- The products (technologies) described in the datasheet(s) are not to be provided to any party whose purpose in their application will hinder maintenance of international peace and safety nor are they to be applied to that purpose by their direct purchasers or any third party. When exporting these products (technologies), the necessary procedures are to be taken in accordance with related laws and regulations..  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com 
ABS6TR 价格&库存
很抱歉,暂时无法提供与“ABS6TR”相匹配的价格&库存,您可以联系我们找货
